Lpc2000
Non-aligned access?
Non-aligned access?
2005-11-08 by ee_gary
Hello,
I'm having a problem where my code goes into the bushes after ~10
seconds.  Running it in the simulator results in a "Non-aligned
Access" error, ARM Instruction at 00000200H, Memory Access at
40000241H.  Any idea what that means?  Simple code, just an interrupt
driven timer and interrupt driven SPI…
Any help is greatly appreciated.  Thanks!
Gary
Re: [lpc2000] Non-aligned access?
2005-11-08 by Tom Walsh
ee_gary wrote:
>Hello,
>driven timer and interrupt driven SPI\ufffd
You can run into this when mixing Thumb with ARM code. When interrupt
routines are entered, the processor is in ARM mode, either write your
handlers in ARM or switch to THUMB mode, process the interrupt, then
exit THUMB mode and return from interrupt.
FWIW, Thumb, and thumb-internetworking, is too much trouble to deal
with, I run strictly ARM mode.
TomW
2005-11-08 by Charles Manning
On Tuesday 08 November 2005 14:40, Tom Walsh wrote:
> ee_gary wrote:
> >Hello,
What instruction was this accessing?
The following things can give you non-aligned accesses:
1) Trying to read a U32 on a non-4-byte boundary or a U16 on a non-2byte
boundary. This might raise a data abort.
2) Trying to execute an ARM instruction at a non-4-byte location or a thumb
instruction at a non-2-byte location. This might raise a prefetch abort.
Yes, this is possible since thumb addresses are marked by setting the least
significant bit.  If you try executing the address by using a regular branch
or bl then this will break. You need to use a bx.
To each their own, but I strongly disagree. I use thumb and interworking a
lot. gcc support for this is great.
I always write all my assembly with interworking (ie using bx) regardless.
For an example you might look at the example stuff I posted on the AT91SAM7
group.
>group.
Doing the Internetworking is a new thing for me, newlib and gcc were at
odds with each other over thumb code linking so I removed the ability.
I've got a lot of code to write and plenty of room to work with right
now, perhaps later I will consider moving into Thumb.
TomW
Re: Non-aligned access?
2005-11-08 by embeddedjanitor
deal
interworking a
regardless.
AT91SAM7
> >group.
at
ability.
right
Yup I agree with your basic strategy. If it ain't broke... :-).
The trick to getting interworking right is to use the correct
libraries and the correct flags.
Some older versions of gcc are a bit broken too. I would not use
anything before 3.4.1
RE: [lpc2000] Non-aligned access?
2005-11-08 by Dan Beadle
The basic cause of this error is having an program fetch that is not
aligned on a multiple of 4. (the 241H in your example).
So how did you do this?  This can happen by corrupting the stack or
altering the stack pointer.  (Set the SP to 4000 0241 and do a return
will generate the error).  The other way is to walk on the stack and
alter a return address to point to a non-multiple of 4 and do a return.
Yet another way is attempt to do a word or half word load (set rx = 4000
0241, followed by a ldr rm,[rx]).  You could do this from assembler, but
you can also do it with pointers. Eg.  Int *pword; pword = 0x40000241; y
= *pword does a fetch from a non-aligned address...)
So many opportunities!
Dan
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of Tom Walsh
Sent: Monday, November 07, 2005 5:41 PM
To: lpc2000@yahoogroups.com
Subject: Re: [lpc2000] Non-aligned access?
ee_gary wrote:
>Hello,
>driven timer and interrupt driven SPI...
TomW
Yahoo! Groups Links
> > ee_gary wrote:
> > >Hello,
The instruction at 200H was:
LDR R3,[R1]
It was part of this function:
void wait (void)  {
  unsigned long i;
  i = timeval;
  while ((i + 10) != timeval);
where 'timeval' is incremented by an ISR.
non-2byte
a thumb
the least
regular branch
interworking a
regardless.
I'm using all ARM code, with the interworking option enabled in the
compiler/linker.
AT91SAM7
> group.
2005-11-08 by Guillermo Prandi
Just an idea: perhaps interrupt routines are not saving/restoring all
the registers correctly?
Guille
> > > ee_gary wrote:
> > > >Hello,
~10
interrupt
> LDR R3,[R1]
> void wait (void)  {
>   unsigned long i;
>   i = timeval;
> non-2byte
or
> a thumb
abort.
interrupt
write your
then
> the least
> regular branch
deal
> interworking a
> regardless.
> compiler/linker.
> AT91SAM7
> > group.
Re: [lpc2000] Re: Non-aligned access?
That would be my first though too.
Either that or a stack corruption causing the register to be nuked, but that
would probably be less likely.
Is 40000241H within the RAM address space? If not, what does it correspond to?
If you can figure out how R1 got to have this value you're well on your way to
solving the problem.
> Guille
> > > > ee_gary wrote:
> > > > >Hello,
> ~10
> interrupt
> > LDR R3,[R1]
> > void wait (void)  {
> >   unsigned long i;
> >   i = timeval;
> > non-2byte
> or
> > a thumb
> abort.
> interrupt
> write your
> then
> > the least
> > regular branch
> deal
> > interworking a
> > regardless.
> > compiler/linker.
> > AT91SAM7
> > > group.
2005-11-09 by Tom Walsh
I had that, I grapped some project source of an example program and used
that as the foundation for my project. I got bit by an "__attribute__
((naked))" definition of an ISR handler.
TomW
>>Guille
>>>>>ee_gary wrote:
>>>>>>Hello,
>>~10
>>interrupt
>>>LDR R3,[R1]
>>>void wait (void)  {
>>>  unsigned long i;
>>>  i = timeval;
>>>non-2byte
>>or
>>>a thumb
>>abort.
>>interrupt
>>write your
>>then
>>>the least
>>>regular branch
>>deal
>>>interworking a
>>>regardless.
>>>compiler/linker.
>>>AT91SAM7
>>>>group.
>>Yahoo! Groups Links
>Yahoo! Groups Links
2005-11-09 by ee_gary
Definitely seems interrupt related... When I disable the timer
interrupt, the interrupt driven spi works great.  When I disable the
spi interrupt, the interrupt driven timer works great.  When both are
enabled, I get about 10 seconds of run time and then the program runs
 off into the bushes.  I'm using Keil w/ GCC, ARM-mode.  What's
special about having two interrupts active that might cause this?
Gary
but that
correspond to?
your way to
used
> TomW
> >>Guille
> >>>>>ee_gary wrote:
> >>>>>>Hello,
> >>~10
> >>interrupt
> >>>LDR R3,[R1]
> >>>void wait (void)  {
> >>>  unsigned long i;
> >>>  i = timeval;
> >>>non-2byte
> >>or
> >>>a thumb
> >>abort.
> >>interrupt
> >>write your
> >>then
> >>>the least
> >>>regular branch
> >>deal
> >>>interworking a
> >>>regardless.
> >>>compiler/linker.
> >>>AT91SAM7
> >>>>group.
> >>Yahoo! Groups Links
> >Yahoo! Groups Links
2005-11-09 by rtstofer
> Thanks,
> Gary
Maybe the stack size?
Richard
2005-11-09 by Charles Manning
How are you processing interrupts? Perhaps posting your wrapper code (ie the
assembler calling the C ISRs).
There are two things that I can see causing problems here:
1) If you are reenabling interrupts during the ISR then you can get stack
overflows or the second ISR starting processing before the isr is completely
done.
2) If you have not allowed enough stack for the ISR then stack mashing can be
bad for you.
I suggest doing non-nested interrupt handling first.
Here's what I do for a SAM7, the Philips should be identical except maybe for
IVR acknowledgment.
The C functions are regular C functions with no attributes.
@  IRQ wrappers.
@  These call a C function.
@  We switch to supervisor mode and reenable interrupts to allow nesting.
  .text
  .code 32
  .align   2
@  Macros
  .macro   irq_wrapper_nested, C_function
@ Save registers on stack
  sub r14,r14,#4 @ fix up for return
  stmfd r13!,{r14}
  mrs  r14,spsr
  stmfd r13!,{r14}
@ Acknowledge the IVR for debugging to support Protected Mode
  ldr   r14,=0xFFFFF100
  str   r14,[r14]
 @ swich to system mode and enable IRQ, but not FIQ
  msr cpsr_c,#0x5F
  @push stack
  stmfd r13!,{r0-r12,r14}
@ Call the function
  ldr r0,=\C_function
  mov lr,pc
  bx  r0
  @ pop stack
   ldmfd r13!,{r0-r12,r14}
 @ swich to interrupt mode and disable IRQs and FIQs
  msr cpsr_c,#0xD2
@End of interrupt by doing a write to AIC_EOICR
  ldr  r14,=0xFFFFF130
  str  r14,[r14]
  @ Unstack the saved spsr
  ldmfd r13!,{r14}
  msr  spsr_all,r14
  @ Return from interrupt (unstacking the modified r14)
  ldmfd r13!,{pc}^
  .endm
  .macro   irq_wrapper_not_nested, C_function
  stmfd r13!,{r0-r3,r14}
  ldr   r14,=0xFFFFF100
  str   r14,[r14]
@ Call the function
  ldr r0,=\C_function
  mov lr,pc
  bx  r0
  ldr  r14,=0xFFFFF130
  str  r14,[r0]
  ldmfd r13!,{r0-r3,12,pc}^
  .endm
@	ISRs
	.global spurious_isr
	.global default_isr
	.global default_fiq
default_fiq:
spurious_isr:
default_isr:
	b default_isr
  .extern systick_isr_C
  .global systick_isr_entry
systick_isr_entry:
  irq_wrapper_nested systick_isr_C
  .extern udp_isr_C
  .global udp_isr_entry
udp_isr_entry:
  irq_wrapper_nested udp_isr_C
  .extern uart_isr_C_0
  .global uart_isr_entry_0
uart_isr_entry_0:
  irq_wrapper_nested uart_isr_C_0
  .extern uart_isr_C_1
  .global uart_isr_entry_1
uart_isr_entry_1:
  irq_wrapper_nested uart_isr_C_1
> Thanks,
> Gary
> but that
> correspond to?
> your way to
> used
> > TomW
> > >>Guille
> > >>>>>ee_gary wrote:
> > >>>>>>Hello,
> > >>~10
> > >>interrupt
> > >>>LDR R3,[R1]
> > >>>void wait (void)  {
> > >>>  unsigned long i;
> > >>>  i = timeval;
> > >>>non-2byte
> > >>or
> > >>>a thumb
> > >>abort.
> > >>interrupt
> > >>write your
> > >>then
> > >>>the least
> > >>>regular branch
> > >>deal
> > >>>interworking a
> > >>>regardless.
> > >>>compiler/linker.
> > >>>AT91SAM7
> > >>>>group.
> > >>Yahoo! Groups Links
> > >Yahoo! Groups Links
2006-01-21 by Guillermo Prandi
Gary, I wonder if you could solve your problem. I am facing the same
problem here too. :(
Guille
are
runs
> Thanks,
> Gary
nuked,
> but that
> correspond to?
on
> your way to
and
> used
an "__attribute__
> > TomW
> > >>Guille
<manningc2@a...>
> > >>>>>ee_gary wrote:
> > >>>>>>Hello,
after
> > >>~10
aligned
at
> > >>interrupt
> > >>>LDR R3,[R1]
> > >>>void wait (void)  {
> > >>>  unsigned long i;
> > >>>  i = timeval;
> > >>>non-2byte
location
> > >>or
> > >>>a thumb
prefetch
> > >>abort.
> > >>interrupt
> > >>write your
interrupt,
> > >>then
setting
> > >>>the least
> > >>>regular branch
to
> > >>deal
> > >>>interworking a
> > >>>regardless.
in the
> > >>>compiler/linker.
on the
> > >>>AT91SAM7
> > >>>>group.
> > >>Yahoo! Groups Links
> > >Yahoo! Groups Links
2006-01-22 by Daniel Gelbgras
My guess is that you may want  to increase
the (normal) interrupt stack *size*
and FIQ interrupt stack *size*
in your cpu startup (initialization) file
For example in  Keil startup.s file,  these constants are
IRQ_Stack_Size   and    USR_Stack_Size
(When you use only a single interrupt, either FIQ or normal interrupt,
it is working because there is some allocated stack space,
but I suppose that one of these 2 constants is too small,
so you use the same memory space for both isr's
If you enable both interrupts together,
one isr can corrupt the register values saved by the other isr,
and the program crashes after a variable amount of time)
HTH
kind regards
daniel
  Sent: Saturday, January 21, 2006 10:34 PM
  Subject: [lpc2000] Re: Non-aligned access?
  Guille
  are
  runs
  > Thanks,
  > Gary
  nuked,
  > but that
  > correspond to?
  on
  > your way to
  and
  > used
  an "__attribute__
  > > TomW
  > > >>Guille
  <manningc2@a...>
  > > >>>>>ee_gary wrote:
  > > >>>>>>Hello,
  after
  > > >>~10
  aligned
  at
  > > >>interrupt
  > > >>>LDR R3,[R1]
  > > >>>void wait (void)  {
  > > >>>  unsigned long i;
  > > >>>  i = timeval;
  > > >>>non-2byte
  location
  > > >>or
  > > >>>a thumb
  prefetch
  > > >>abort.
  > > >>interrupt
  > > >>write your
  interrupt,
  > > >>then
  setting
  > > >>>the least
  > > >>>regular branch
  to
  > > >>deal
  > > >>>interworking a
  > > >>>regardless.
  in the
  > > >>>compiler/linker.
  on the
  > > >>>AT91SAM7
  > > >>>>group.
  > > >>Yahoo! Groups Links
  > > >Yahoo! Groups Links
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
        Pic microcontrollers
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2006-01-22 by Guillermo Prandi
Thanks, Daniel. In my case I am not using nested interrupts, and my
stacks are pretty generous (LPC2138=32K RAM). That's why I am
puzzled. I am using FreeRTOS/GCC4.0.1. This is an excerpt of my
startup code:
// Stack Sizes
.set  UND_STACK_SIZE, 0x00000040
.set  ABT_STACK_SIZE, 0x00000040
.set  FIQ_STACK_SIZE, 0x00000040
.set  IRQ_STACK_SIZE, 0x00000400
.set  SVC_STACK_SIZE, 0x00000400
// Initialize Interrupt System
// - Set stack location for each mode
// - Leave in Supervisor Mode with Interrupts Disabled
ldr   r0,=_stack // 0x40008000 minus 32 bytes for IAP.
msr   CPSR_c,#MODE_UND|I_BIT|F_BIT
mov   sp,r0
sub   r0,r0,#UND_STACK_SIZE
msr   CPSR_c,#MODE_ABT|I_BIT|F_BIT
mov   sp,r0
sub   r0,r0,#ABT_STACK_SIZE
msr   CPSR_c,#MODE_FIQ|I_BIT|F_BIT
mov   sp,r0
sub   r0,r0,#FIQ_STACK_SIZE
msr   CPSR_c,#MODE_IRQ|I_BIT
mov   sp,r0
sub   r0,r0,#IRQ_STACK_SIZE
msr   CPSR_c,#MODE_SVC|I_BIT|F_BIT
mov   sp,r0
sub   r0,r0,#SVC_STACK_SIZE
msr   CPSR_c,#MODE_SYS|I_BIT|F_BIT
mov   sp,r0
// (This is from FreeRTOS)
// We want to start in supervisor mode.
// Operation will switch to system
// mode when the first task starts.
// Initialization and startup follows
FIQs are not a concern; I use them as a "specialized" reset button
via EINT3 (it does little more than reset). They are not normally
triggered.
I even added a check before each interrupt routine. Check it out:
#define	INTERRUPT_CHECK \
{ register int _sp asm("sp"); \
 asm volatile ("mov r0,#0x40000000" ); \
 asm volatile ("orr r0,r0,#0x000000e0" ); \
 asm volatile ("orr r0,r0,#0x00007f00" ); \
 asm volatile ("cmp r0,sp" ); \
 asm volatile ("blo 0f" ); \
 asm volatile ("sub r0,r0,#0x00000100" ); \
 asm volatile ("blo 1f" ); \
 asm volatile ("0:" ); \
 error_n1("OUT OF STACK!",_sp); \
 asm volatile ("1:" ); \
void MyFunc(void) __attribute__ ((interrupt("IRQ")));
void MyFunc(void)
INTERRUPT_CHECK
/* my code here */
The IRQ stack should be below 0x40007fe0 and is 512 bytes long. The
error function enters a safe-mode (IRQs disabled, initializes
hardware, outputs given string or "bad pointer" if problems with the
string). The error_n1() function has been tested several times in
other circumstances and it works like a charm (for instance, it is
called from the pabt, dabt and undf handlers which DO trigger!).
The stack check from above never fires (except when I tamper with the
values just to verify that it WOULD trigger). On the other hand, I
keep getting undf, dabt and pabt everywhere (i.e., r15 pointing to
RAM or some weird location) when I start using any SPI interrupt
routine. I rewritten my program several times, tried many ways, but
every time the SPI interrupt service routine starts executing, I get
a crash sooner or later (within 10 seconds is a good average). This
doesn't happen with my other interrupt routines, like my two UARTs or
the OS timer tick. They work fine. I just don't know what to check
next. Sometimes the problem doesn't show up for hours if I compile
with no optimization (-O0) and sometimes it seems to work a little
longer if I set the processor to run at 10x5 MHz (I usually run it at
10x1 MHz). The system crashed with IRQ routines as simple as this:
static void dummySPIIRQ(void) __attribute__ ((interrupt("IRQ")));
 tdSPI++;
 if( S0SPSR & S0SPSR_SPIF )
   IOSET0 = PIN7BIT; // Remove /CS from target SPI device
   short rddata = S0SPDR;
   tdSPIRDY = (0xffff & (int) rddata) | 0x80000000;
 S0SPINT = 0x01;
 VICVectAddr = 0x00000000;
To worsen things even more, I don't have a JTAG connector on my
board. Any suggestions will be greately appreciated.
Guille
--- In lpc2000@yahoogroups.com, "Daniel Gelbgras"
<daniel.gelbgras@e...> wrote:
> Hi,
interrupt,
isr,
> HTH
> kind regards
> daniel
>   ----- Original Message -----
>   From: Guillermo Prandi
same
>   Guille
disable the
both
>   are
program
>   runs
this?
>   > Thanks,
>   > Gary
>   nuked,
>   > but that
it
>   > correspond to?
well
>   on
>   > your way to
program
>   and
>   > used
>   an "__attribute__
>   > > TomW
>   > > >>Guille
>   <manningc2@a...>
>   > > >>>>>ee_gary wrote:
>   > > >>>>>>Hello,
>   after
>   > > >>~10
>   aligned
Access
>   at
just an
>   > > >>interrupt
>   > > >>>LDR R3,[R1]
>   > > >>>void wait (void)  {
>   > > >>>  unsigned long i;
>   > > >>>  i = timeval;
on a
>   > > >>>non-2byte
>   location
>   > > >>or
>   > > >>>a thumb
>   prefetch
>   > > >>abort.
When
>   > > >>interrupt
either
>   > > >>write your
>   interrupt,
>   > > >>then
>   setting
>   > > >>>the least
using a
>   > > >>>regular branch
trouble
>   to
>   > > >>deal
and
>   > > >>>interworking a
using bx)
>   > > >>>regardless.
enabled
>   in the
>   > > >>>compiler/linker.
posted
>   on the
>   > > >>>AT91SAM7
>   > > >>>>group.
>   > > >>Yahoo! Groups Links
>   > > >Yahoo! Groups Links
microprocessors
>   YAHOO! GROUPS LINKS
of Service.
Re: Non-aligned access? - and bug in FreeRTOS LPC2106 GCC port
2006-01-25 by Guillermo Prandi
OK, mine was a mewbie mistake. I FORGOT TO READ the FreeRTOS LPC2xxx
port notes, and therefore I missed the importance of starting/ending
every ISR function that might perform a task switch (e.g., via
xQueueSendFromISR) with the portENTER_SWITCHING_ISR() /
portEXIT_SWITCHING_ISR() pair of macros. I also started my project
from a WinARM demo example instead of a FreeRTOS example. Shame on me.
On the other hand, someone might find interesting that after
correcting this I bumped into this bug in the FreeRTOS LPC2106 GCC
port that seems to show up *sometimes* with GCC 4.01. There's already
a patch available and it will be fixed in the next release of
FreeRTOS. Read the thread here:
http://sourceforge.net/forum/message.php?msg_id=3537580
Guille
--- In lpc2000@yahoogroups.com, "Guillermo Prandi"
> startup code:
> // Stack Sizes
> mov   sp,r0
> mov   sp,r0
> mov   sp,r0
> mov   sp,r0
> mov   sp,r0
> mov   sp,r0
> triggered.
> void MyFunc(void)
> INTERRUPT_CHECK
> /* my code here */
get
or
at
>  tdSPI++;
>  S0SPINT = 0x01;
> Guille
> > Hi,
> interrupt,
> isr,
> > HTH
> > kind regards
> > daniel
> same
> >   Guille
> disable the
> both
> >   are
> program
> >   runs
What's
> this?
> >   > Thanks,
> >   > Gary
be
> >   nuked,
> >   > but that
does
> it
> >   > correspond to?
> well
> >   on
> >   > your way to
> program
> >   and
> >   > used
> >   an "__attribute__
> >   > > TomW
> >   > > >>Guille
> >   <manningc2@a...>
> >   > > >>>>>ee_gary wrote:
> >   > > >>>>>>Hello,
bushes
> >   after
> >   > > >>~10
a "Non-
> >   aligned
> Access
> >   at
> just an
> >   > > >>interrupt
> >   > > >>>LDR R3,[R1]
> >   > > >>>void wait (void)  {
> >   > > >>>  unsigned long i;
> >   > > >>>  i = timeval;
U16
> on a
> >   > > >>>non-2byte
> >   location
> >   > > >>or
> >   > > >>>a thumb
a
> >   prefetch
> >   > > >>abort.
> When
> >   > > >>interrupt
> either
> >   > > >>write your
> >   interrupt,
> >   > > >>then
by
> >   setting
> >   > > >>>the least
> using a
> >   > > >>>regular branch
> trouble
> >   to
> >   > > >>deal
> and
> >   > > >>>interworking a
> using bx)
> >   > > >>>regardless.
> enabled
> >   in the
> >   > > >>>compiler/linker.
> posted
> >   on the
> >   > > >>>AT91SAM7
> >   > > >>>>group.
> >   > > >>Yahoo! Groups Links
> >   > > >Yahoo! Groups Links
> microprocessors
> >   YAHOO! GROUPS LINKS
> of Service.
