Lpc2000
New to microprocessor
2005-11-08 by valis_eric_ykchan
I'm new to microprocessor.
I have a LPC2114 inserted on a RedHat 9.0 via Moschip PCI product. I
have to make some communication between the programs on the chip and
the linux. Can I simply use printf and scanf and "SWI" to communicate
via the serial port?
Thanks.
Eric
Re: [lpc2000] New to microprocessor
2005-11-08 by David Hawkins
Hi Eric,
If the board has the serial port available, then yes you should
be able to talk to the processor over the serial port - but
only once it is programmed.
So the real question is;
1) How does Moschip expect you to program the device; over PCI,
    or over serial using the bootloader, or both?
2) Does Moschip supply a device driver, or at least enough
    data to write your own driver.
3) What is used as the PCI-to-micro interface, I don't think
    that this chip has an external memory interface, so have
    they made it an SPI or I2C target, or built a bit-bang interface.
4) What is the PCI chipset used on the board; PLX, AMCC, TI?
Send a link to the board data sheet and I'll tell you what I think.
Dave
Re: New to microprocessor
2005-11-09 by Eric
> Hi Eric,
> Dave
Thanks for your reply. The only *driver* of Moschip is to set the
serial port to the PCI
(http://www.moschip.com/data/products/NM/linux.zip).
I don't know the exact model of the PCI chipset (Nm9715, Nm9755,
Nm9805, Nm9820, Nm9835, Nm9845, etc)
http://www.moschip.com/html/data_sheets.html
I don't have a JTAG debugger, I also don't have Angel Debug Monitor. I
can only load the sample program to the LPC2114. If nothing comes out,
then I don't know what's wrong. Probably I'll have to tell my boss
about this mission impossible when he come back...
Help! My Keil MCB2130board has stoped talking to the Philips flash utility.
2005-11-09 by Peter Homann
I've managed to stuff up something, so that my MCB2130 board won't
communicate with the Philips download utility. I'm not sure what I've
done. I may have downloaded a hex file for an incorrect processor. Or
maybe erasing the whole chip erases the boot loader.
Is there something I can do to get it working again?
Peter.
Web:   www.homanndesigns.com
email: homann@...
Phone: +61 421 601 665
www.homanndesigns.com/ModIO.html         - Modbus Interface Unit
www.homanndesigns.com/DigiSpeedDeal.html - DC Spindle control
www.homanndesigns.com/TurboTaig.html     - Taig Mill Upgrade board
Re: [lpc2000] Re: New to microprocessor
2005-11-09 by David Hawkins
Well, according the PDF in the zip file refers to 9835 and 9735,
and the data sheet link says that a 9835 is a PCI UART + parallel
port, i.e., seems like the chip is destined for use in boards
that add a parallel and serial port to your PC. In this case,
the serial port has been attached to the LPC.
Well, if you can load programs to the LPC2114, you clearly have
flash downloading etc working. You can get by without a debugger
pretty easily. I've never used one with the LPC parts.
Start out with a startup file that sets up the vectors correctly
and turn on an LED. Then work on a startup file that sets up the
C environment and write a main.c that turns on an LED, ... small
steps, make sure you understand each step. Then you'll understand
how things work.
Don't blindly assume that you can just take GNUARM tools and
get things to work on your processor.
If you don't understand the above comments - ask more!
Dave
LPC2138 won't communicate with the Philips flash utility.
Can anyone help me with getting my LPC2138 processor to start talking to
  the Philips Flash utility again.
A previously explained, it appears to have locked up and I can no longer
program it.
Is it possible to screw up the boot loader.
I'd really appreciate some help here.
Peter.
Peter Homann wrote:
> Hi,
> Cheers,
> Peter.
email: homann@...
Re: [lpc2000] LPC2138 won't communicate with the Philips flash utility.
2005-11-09 by Tom Walsh
Peter Homann wrote:
>Hi,
>program it.
>Cheers,
>Peter.
>Peter Homann wrote:
>>Hi,
Hold P0.14 low and reset the chip.  You are probably have a valid
checksum in the Flash and it is jump to that program instead of the
bootloader.  So, you have to "force" it into the loader.
TomW
Hi Tom,
Thanks for the reply. The circuit diagram has P0.14 connected to the com
port via a jumper. I'll try holding it low manually as suggested by Zdravko.
Do I need to release it before programming? Or, can I leave it tied low
for the duration of the programming?
Peter.
Tom Walsh wrote:
> Peter Homann wrote:
>>Hi,
>>program it.
>>Cheers,
>>Peter.
>>Peter Homann wrote:
>>>Hi,
> TomW
email: homann@...
2005-11-10 by Tom Walsh
Peter Homann wrote:
>Hi Tom,
You can release it once it enters the bootloader, it is only necessary
to hold it low to notify the processor that you wish it to run the
bootloader.
TomW
2005-11-11 by Eric
> how things work.
> Dave
Thanks for your reply. I'm not using an evaluation board, probably I
won't have any LED :p
2005-11-11 by David Hawkins
But the board has to be doing I/O of some sort, otherwise its
kind of a waste :)
If you have a schematic of your board, then you can always
configure an I/O pin as output and then drive an LED.
Just make sure that the I/O pin is not being driven
by something.
If you want more help just ask, I'll take a look at the
schematic, or board docs and suggest what you can do.
Dave
2005-11-11 by Eric
> kind of a waste :)
> by something.
> Dave
Thanks for you reply. I'll take a look at what I have and what I can do :)
