Sent: Friday, November 11, 2005 8:48 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Re: External clock on LPC2131
Hi, Dave B.
Is your external 12.28Mhz clock source working fine with the Lpc2xxx
internal clock multiplier? Did you turn on Clock PLL on the LPC2131?
Thanks in Advance.
--- In lpc2000@yahoogroups.com, "drb5599" <dbutler@c...> wrote:
> Hi Marcio,
> Yes, that mode of operation is supported. I have been running a
> LPC2131 with an external 12.288MHz clock that is buffered and
feeds
> everything on my board. Works fine.
> See page 31/32 of the manual. There is some info there although I
> agree it is not very clear. Just leave the unused pin 61 (XTAL2)
> open. Also, make sure you use the recommended (100pF) coupling
cap
> for XTAL1.
> See figure 7a for slave mode.
> Good Luck,
> Dave B.
> --- In lpc2000@yahoogroups.com, "atmelbr" <atmelbr@y...> wrote:
> > Hi all,
> > If I put an external clock on XTAL1 input (instead of quartz
> > crystal) everything will run ok ? I can´t find the answer on
> datasheet.
> > Thanks,
> > Marcio
SPONSORED LINKS
Microprocessor <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g> Microcontrollers <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg> Pic <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ> microcontrollers
8051 <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A> microprocessor
_____
YAHOO! GROUPS LINKS
* Visit your group " lpc2000 <http://groups.yahoo.com/group/lpc2000> " on the web.
* To unsubscribe from this group, send an email to:
lpc2000-unsubscribe@yahoogroups.com <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
