Lpc2000
Can I run the core voltage at 1.5 volts
2005-11-08 by pfwilliamsmts
I am starting a new design with the LPC2106. I will also have an FPGA
running at 1.5 volts. I would like to use the 1.5 volts for the LPC
core voltage. The data sheet shows a some range in the core voltage
but I have not seen any other postings in this regard. Does anyone
have experience with this topic.
Re: [lpc2000] Can I run the core voltage at 1.5 volts
2005-11-08 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Tuesday, November 08, 2005 6:33 PM
Subject: [lpc2000] Can I run the core voltage at 1.5 volts
FPGAs can take very large peak currents, several amps in many cases. It
would be a good idea to have separate regulators.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Re: Can I run the core voltage at 1.5 volts
2005-11-08 by rtstofer
--- In lpc2000@yahoogroups.com, "pfwilliamsmts" <pfwilliams@h...>
FPGA
LPC
voltage
The datasheet, in section 8 table 9 lists the range of voltages as:
VDD1.8 1.65V MIN, 1.8V, 1.95V MAX
VDD3.3 3.0V MIN, 3.3V, 3.6V MAX
I think you are out of luck.  I would design for the middle value
and hope to remain within the boundaries.
Richard
