Lpc2000
A/D converter: a conversion is never completed
2005-11-09 by Joerg Sommer
I have a LPC2292 and want to use some analog input channels (Ain0, Ain1,
Ain6) to get data from analog sensors. I use this routine to initialize
the sensors:
#v+
void sensors_init(void)
    /* setup the A/D converter
     * use Ain0, Ain1, Ain6: 0x1 + 0x2 + 0x40
     * divide the PCLK by 13+1 to get 4.5MHz: 0xD00
     * repeat the evaluation: 0x10000
     * 11 bits accuracy: bit 17--19 cleared
     * enable: 0x200000
     * start with timer 0 match 2: 0x2000000 (configured in rtc.c)
    write_reg(ADCR, 0x2210D43);
    /* set the usage of P0.27--P0.28 as Ain for brightness and temperature */
    write_reg(PINSEL1, (read_reg(PINSEL1) & 0xFC3FFFFF) | 0x1400000);
    /* no need to set the usage of P3.29 as Ain6 for voltage, because this is
       done by the fix BOOT value of 01 */
    /* P1.24 and P1.25 are GPIO input pins by default; nothing to change */
    /* set the interrupt routine */
    write_reg(VICVectCntl12, 0x32);
    write_reg(VICVectAddr12, (uint32_t)interrupt_handler);
    write_reg(VICIntEnable, 0x40000);	  /* enable A/D conv. interrupt line */
#v-
and this routine as interrupt handler:
#v+
static void
#if defined(__arm__) && defined(__GNUC__)
  __attribute__ ((interrupt ("IRQ") ))
#endif
    interrupt_handler(void)
    uint32_t reg = read_reg(ADDR);
    if ( (reg & 1<<31) != 0 ) {
        /* no value available, the A/D converter need some time */
        update_VIC();
        return;
    uint16_t val = (reg >> 6) & 0x3FF;
    switch ( (reg >> 24) & 0x7 ) {
      case 0:
        if (sensors_get_brightness() != val) {
            uint8_t tmp = sensors_get_brightness();
            sensors_last_brightness = val;
            if ( ! sensors_is_standby() && (tmp / 32) != (val / 32) )
              display_set_dimming( nvram_sensors_cfg->dim_level[val/32] );
        break;
      case 1:
        if (sensors_get_temperature() != val) {
            sensors_last_temp = val;
            if (val > nvram_sensors_cfg->temp_threshold)
              display_set_dimming( 0 );
        break;
      case 6:
        if (sensors_get_voltage() != val) {
            sensors_last_voltage = val;
        break;
    update_VIC();
#v-
If I poll the ADDR register I see the DONE bit is never set. The Match
0.1 works, because this triggers an interrupt and I get this one. What is
wrong? Why the DONE bit is never set and the interrupt handler is never
called. Any ideas?
Bye, Joerg.
And 1.1.81 is officially BugFree(tm), so if you receive any bug-reports
on it, you know they are just evil lies.
         -- Linus Torvalds
RE: [lpc2000] A/D converter: a conversion is never completed
2005-11-10 by Gromann, Klaus
Hi Joerg,
you have set the BURST-bit (0x00010000)in the ADCR. I never tried this
but the manual says that if this bit is set the ADC does repeated
conversions at a rate defined by the CLKS bits (000 = 11 clock cycles).
I think that the DONE bit will be never set in this mode.
Second suggestion : Try to set the START bits to "start conversion now"
(001) by your code to see if the interrupt handler works as you want. I
use this mode and do a polling of the DONE bit and everything works
fine.
My configuration :
PINSEL the same as yours.
ADCR = 0x1200401;
regards
Klaus
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of Joerg Sommer
Sent: Wednesday, November 09, 2005 11:25 PM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] A/D converter: a conversion is never completed
the sensors:
#v+
     * enable: 0x200000
temperature */
this is
line */
#v-
#v+
static void
#endif
        update_VIC();
        return;
      case 0:
        break;
      case 1:
        break;
      case 6:
        break;
    update_VIC();
#v-
is wrong? Why the DONE bit is never set and the interrupt handler is
never called. Any ideas?
Bye, Joerg.
         -- Linus Torvalds
Yahoo! Groups Links
Re: [lpc2000] A/D converter: a conversion is never completed
2005-11-10 by Tom Walsh
Gromann, Klaus wrote:
>Hi Joerg,
This is my ADC routines on the LPC2138:
============ begin setup ===============
void initADC(void)
{ // setup converter to run continuously.
      // connect VIC to A/D Convertor.
   VICVectAddr1 = (uint32_t)adc0ISR;    // address of the ISR
   VICVectCntl1 = VIC_ENABLE | VIC_ADC0;
   VICIntSelect &= ~VIC_BIT(VIC_ADC0);  // ADC0 selected as IRQ
   VICIntEnable = VIC_BIT(VIC_ADC0);    // ADC0 interrupt enabled
      // set pins for AD0.0 .. AD0.3 to A/D function.
   PINSEL1 = (PINSEL1 & 0xc03fffff) | (0x15400000);
      // accuracy to 10bits.
   adcSetValue = (
      (ADC_CHN_0 | ADC_CHN_1 | ADC_CHN_2 | ADC_CHN_3) |
      (ADC_CLK_DIVISOR(14)) |    /* approx 4.2MHz conversion rate. */
      (ADC_BURST_ON) |        /* run continuously. */
      (ADC_RESOLVE_10) |      /* 10 bit resolution. */
      (ADC_POWER_ON) |        /* enabled. */
      (ADC_START_0)) &        /* no, we are bursting. */
      (~ADC_RESERVED_CONTROL_BITS); /* write 0's to reserverd bits. */
   ADCR0 = adcSetValue;
============ snip ================
=========== begin ISR ==============
unsigned int adcData [4];
void adc0ISR(void)
{// keep continuous update of A/D pin values.
unsigned int temp;
   temp = ADDR0;     // read conversion info.
   switch (ADC_CHANNEL(temp)) {
      case 0:
         adcData[0] = ADC_VALUE(temp);
         break;
      case 1:
         adcData[1] = ADC_VALUE(temp);
         break;
      case 2:
         adcData[2] = ADC_VALUE(temp);
         break;
      case 3:
         adcData[3] = ADC_VALUE(temp);
         break;
      default:    // do nothing on overranges.
         break;
   VICVectAddr = 0x00000000;             // clear this interrupt from
the VIC
=========== snip =================
=========== begin Macros ===========
#define  ADC_VALUE_MASK    (0x0000ffc0)
#define  ADC_VALUE(A)      ((A >> 6) & 0x3ff)
#define  ADC_CHANNEL_MASK  (0x07000000)
#define  ADC_CHANNEL(A)    ((A >> 24) & 0x7)
#define  ADC_OVERRUN_MASK  (0x40000000)
#define  ADC_DONE_MASK     (0x80000000)
Hope this helps.
TomW
