REG: Memory Storage on LPC
2005-11-14 by rockraj_2003
Dear Friends, Now i am doing a prototype of Wireless Data Acquisiton System. I am using Lpc 2148. It has 512KB flash. I want to use the Flash for Data Storage. Is it Possible to use the Flash for Storing the Current receiving Data. I am using the compiler of IAR Embedded WorkBench. 32K limit(Evaluation Version) If it is Possible then how to store in Flash. some Doubts on memory: If i am declaring an Array int COUNT[1000] in my program, where the 2000 bytes of memory will be allocated. Is it allocated in Flash or in RAM. kindly clarify my doubt. One more question on File Handling. How to handle Files in IAR. can any one send some example codes on Files and Assembly Program, which works on LPC 2106. with regards, Rajendra
