Lpc2000
custom bootloader
custom bootloader
2005-11-15 by Joel Winarske
Has anyone replaced the LPC214x boot loader with their own code? If so how
much of a hassle is it?
Is Phillip's planning on coming out with a boot loader upgrade to support
USB?  Perhaps via CDC serial emulation, similar to the Atmel?  This would
require no change to their PC software, and no PC side driver.
Joel
Re: [lpc2000] custom bootloader
2005-11-15 by Richard Duits
Hi Joel,
I did write my own bootloader and programmed in sector 0. So I did not
replace the philips bootloader, but just added an extra bootloader.
Sorry, but I cannot share the source. Because the flash hardware is not
documented, you would have to reverse engineer the philips bootloader to
write a replacement.
I would like it if philips would create some kind of bootloader
extension interface, so you could add your own IO routines to the
bootloader. I would immagine this could work like the PC BIOS extension
interface: the PC BIOS looks every 16KB boundary for a ROM signature and
calls the ROM extension if a signature is found.
Richard Duits
> Joel
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
RE: [lpc2000] custom bootloader
It seems the only special thing about the boot loader is location.
Has anyone written or updated boot loader via JTAG, or via IAP?
Joel
