Marko Panger wrote:
>Hi,
>Thanks for your reply. Could you explain me what do you mean by
>"When a debugger backtraces off the end of the callstack"
They are probably referring to sucking in part of the stack frame from
the processor to display / analyze in the debugging tool.
TomW
>I don't get it very well. Anyway I have to check how to disable this in
>my debugger.
>Regards,
>marko
>>Hi Marko,
>>When a debugger backtraces off the end of the callstack it may
>>unwittingly reference peripheral registers - could you be affected by
>>this? We've stopped CrossStudio accessing peripheral registers when
>>backtracing to handle this case.
>>Regards
>>Michael
>>>Hi,
>>>I am aware that reading periphery in some windows could clear some flags, but I don't have any "periphery window" opened....
>>>marko
>>>>Od: "Dan Beadle" <dan.beadle@...>
>>>>Datum: 2005/11/15 Tor PM 04:06:02 CET
>>>>Za: <lpc2000@yahoogroups.com>
>>>>Zadeva: RE: [lpc2000] Breakpoint not stopping timer
>>>>I have seen this when I have the VIC registers open in a window.
>>>>As I recall, the issue is something like this: When I hit the first
>>>>interrupt, another hit while stopped in the IRQ, then reading the VIC in
>>>>the debugger clears then pending timer int. Then no more interrupts.
>>>>Generally, I keep the VIC register window closed.
>>>>_____
>>>>From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
>>>>Of Marko Panger
>>>>Sent: Tuesday, November 15, 2005 6:26 AM
>>>>To: lpc2000@yahoogroups.com
>>>>Subject: [lpc2000] Breakpoint not stopping timer
>>>>Hi all,
>>>>I am facing a strange problem when debugging applications with match
>>>>compare timer interrupts enabled.
>>>>Hi all,
>>>>I have a timer match IRQ which fires every 1ms. Basically a ticker.
>>>>Because the timer is used also for other purposes I add a value of
>>>>1000 to the timer match register to get the next interrupt after 1ms
>>>>(timer clock is 1Mhz). I do also increment a variable in the match IRQ.
>>>>I have noticed that if I a put a breakpoint (it doesn't mater where,
>>>>IRQ or main loop) the IRQ isn't hit anymore. After playing around I
>>>>noticed that when the breakpoint is hit the timer still goes on for
>>>>some time, but without hitting the IRQ. Because of this the timer
>>>>count register goes ahead of the match register and the match does not
>>>>occur anymore. Further I discovered that when single stepping the
>>>>global ticker variable is incremented which means that single stepping
>>>>takes more than 1ms.
>>>>I am wondering that the internal JTAG logic has some flavors or is
>>>>this my debugger issue ? Has anybody else noticed such a behavior ?
>>>>Regards,
>>>>marko
>>>>SPONSORED LINKS
>>>>Microprocessor
>>>><http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2
>>>>=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=9
>>>>3&.sig=tsVC-J9hJ5qyXg0WPR0l6g> Microcontrollers
>>>><http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&
>>>>w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s
>>>>=93&.sig=DvJVNqC_pqRTm8Xq01nxwg> Pic microcontrollers
>>>><http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microproces
>>>>sor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c
>>>>=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
>>>>8051 microprocessor
>>>><http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocess
>>>>or&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=
>>>>4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
>>>>_____
>>>>YAHOO! GROUPS LINKS
>>>>* Visit your group "lpc2000
>>>><http://groups.yahoo.com/group/lpc2000> " on the web.
>>>>* To unsubscribe from this group, send an email to:
>>>> lpc2000-unsubscribe@yahoogroups.com
>>>><mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>>>>* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>>>>Service <http://docs.yahoo.com/info/terms/> .
>>>>_____
>>>>[Non-text portions of this message have been removed]
>>>>Yahoo! Groups Links
>>>Yahoo! Groups Links
>>Yahoo! Groups Links
>Yahoo! Groups Links
