Yes. You have to have a common ground.
/Ake
bhimanipankaj wrote:
> Dear all,
> If I am connecting 5V lcd directly with lpc2214, should I common all
> the grounds for 5V for LCD supply as well as 3.3V for controller supply.
> Pankaj
> --- In lpc2000@yahoogroups.com, "Dan Beadle" <dan.beadle@i...> wrote:
> > Check the IO levels on the LCD and the minimum output high level on the
> > 2114. The odds are good that you can directly connect the LCD to the
> > '14 directly with no pull-ups. For example:
> > the VOH min level on the 2148 is V3.3-0.4V or 2.9V MINIMUM... This is
> > the lowest output that the LPC puts out for a standard load high.
> > (Usually it will be closer to 3.3V)
> > I am using a Lumex display with a Samsung controller. It has a VIH min
> > of 2.2. Any input above 2.2 is guaranteed to be an input. Therefore,
> > there is 2.9 - 2.2, or .7V of margin on the high side input to the LCD.
> > On LOW, there is usually less of an issue. The LPC will guarantee that
> > a zero is below VOL max 0.4V while the Samsung LCD controller requires
> > input to be less than 0.6V, leaving a .2V margin.
> > As for LCD to LPC...
> > Here the Samsung can output .9 x Vcc or 4.5V max, but guarantees to put
> > out at least 2.4V. The 2.4 is plenty to swing the LPC to high - it
> > requires 2.0V or more. But if the input goes above 3.3V, the "5V
> > Tolerant" feature of the LPC kicks in. I don't know the details, but
> > generally, you can think of this as a resistor in series with the input,
> > limiting current, and a protection diode that dumps the excessive
> > voltage to the 3.3 rail.
> > So.. Bottom line, with this LCD controller, you just wire it up (making
> > sure to power the LCD from 5V)
> > Hope this helps.
> > Dan
> > _____
> > From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
> > Of bhimanipankaj
> > Sent: Tuesday, November 15, 2005 8:49 PM
> > To: lpc2000@yahoogroups.com
> > Subject: [lpc2000] LCD interface problem
> > Dear ARMieessss..
> > thanks for your replies , but my problem is I want to connect a 5V
> > interface in traditional way that is 8 data lines and 3 control lines
> > with LPC2214, now LPC2214 datasheet is saying that all GPIOs are 5V
> > tolerant so I think I can connect the LCD with Pull Ups on GPIO pins
> > or can I directly connect the 5V LCD with the port pins.
> > Thanks
> > Pankaj
> > SPONSORED LINKS
> > Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2>
> > =Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=9
> > 3&.sig=tsVC-J9hJ5qyXg0WPR0l6g> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&>
> > w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s
> > =93&.sig=DvJVNqC_pqRTm8Xq01nxwg> Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microproces
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microproces>
> > sor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c
> > =4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> > 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocess
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocess>
> > or&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=
> > 4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> > _____
> > YAHOO! GROUPS LINKS
> > * Visit your group "lpc2000
> > <http://groups.yahoo.com/group/lpc2000> " on the web.
> > * To unsubscribe from this group, send an email to:
> > lpc2000-unsubscribe@yahoogroups.com
> > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> > Service <http://docs.yahoo.com/info/terms/> .
> > _____
> > [Non-text portions of this message have been removed]
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
> <http://groups.yahoo.com/group/lpc2000>" on the web.
> Service <http://docs.yahoo.com/info/terms/>.
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavägen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 84 84 102
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
