Lpc2000
user data storage
user data storage
2005-11-22 by gen_4p
how effective is it to store user data (which can be updated
relatively frequently) on lpc2138/48?
User data size is about 2K.
Data should be stored/updated within max 2ms.
Data is going to be loaded to RAM on power-up and operated from RAM.
As far as I understand, I have the following options:
1. Use external nonvolatile data memory (like spi flash, preferably
with byte write capability) and update data in RAM and external flash
on a fly.
2. Update data only in RAM. On power-down create sufficient VDD delay
and store the whole RAM user data array to the on-chip flash. Not
sure how long storing of 2K of data will take. And I believe that
according to one of the previous discussions I can write data to the
on-chip flash providing interrupts are disabled (?)
3. Update data in RAM and in on-chip flash on a fly. As far as I
understand, there is no byte-write provision for flash in lpc, so I
will need to save a page - 256 bytes. The question here is, of
coarse, time to store a page, and, second - flash endurance. How many
times can I write to the flash (I couldn't find information on that)?
Will appreciate advice and considerations.
Gennady
RE: [lpc2000] user data storage
2005-11-22 by Joel Winarske
Hi Gennady,
There are some notes when using IAP on page 294 of the LPC214x user manual.
Page 6 of the LPC214x user manual:
" The LPC2141/2/4/6/8 Flash memory provides minimum of 100,000 erase/write
cycles and 20 years of data-retention."
This is a demo posted by Phillips apps that you might be interested in:
http://groups.yahoo.com/group/lpc2000/files/EE_demo.zip
Joel
Re: user data storage
Thanks a lot Joel,
well, I missed those 400ms for sector erase - bad news for me.
Then, may be I can use another way:
- on power-up load user data to RAM (also duplicating in external
  serial flash ?)
- erase user data sectors in on-chip flash. At this point time to
  erase is not that critical
- during operation update user data in RAM only
- on power-down use VDD delay to store RAM user data array in on-chip
  flash
Gennady
delay
manual.
I
many
that)?
erase/write
in:
> Joel
Re: [lpc2000] Re: user data storage
2005-11-22 by 42Bastian Schick
gen_4p <gennadyp@...> schrieb am Tue, 22 Nov 2005 14:29:55 -0000:
> Thanks a lot Joel,
>   serial flash ?)
I'd use two sectors to have in case of valid copy in case of a power-down
during erase.
I'd store the RAM copy from time to time in the back-ground
42Bastian Schick
RE: [lpc2000] Re: user data storage
>   serial flash ?)
This would just require a modification to your CRT init code.
>   flash
This should be fine as long as your VDD delay is long enough.  One thing
that is not well documented by Phillips -yet- is the current consumption on
the LPC214x series running at different clock and peripheral speeds.
Joel
2005-11-22 by Bruce Paterson
> interested in:
Demo is basically sound but has a few glaring bugs that mean the code in
the zip won't actually work properly !
I'll send an update to phillips_apps today (a working version), but
unfortunately it has also been modified to suit my application, so a bit
of a merge will be necessary rather than a replacement.
Bruce
2005-11-24 by 42Bastian Schick
gen_4p
> Unfortunately this is not going to work for me (so i'd love to...).
> The system in design is a sound development system with 10 ms cycle,
> and max I can miss is one cycle once in a while. So there is no way I
> can spend 400ms for sector erasing and backing data up.
Isn't sector erasing self-timed ? Maybe you need to do it manualy, not via
IAP ?
>> >   chip flash
> Also I would like to make sure again. According to the ee_demo,
> though code is executed from the main flash, all operations on a
> flash writing are done through the bootloader/IAP. Is it right?
> And I do have my doubts on implementing data storage in on-chip flash
> (from development efforts point of view). SPI external flash for $1
> will do the same and, probably, with a lot less efforts.
External flash or EEPROM has IMHO a lot of advantages though the
disadvantage
of having one chip more.
Pros:
- up to 1 million times erasable (FRAM even more, but more expensive)
- erasing will not disturb the LPCs program flow. IAP means IIRC the
interrupts are locked because you can not run from flash while erasing.
- there are EEPROM with a large buffer, so writing is only the SPI speed.
42Bastian Schick
