Lpc2000
uC hangs when initialising external interrupt
2005-11-23 by laurensswaans
Hello,
I'm using the LPC2129 (on the MCB2100 board by Keil) to communicate
with an ADC via SPI. The ADC sends a pulse when new data is valid on
its output and I use this pin to trigger an external interrupt.
I've used interrupts in my designs before so I have a
routine that works. But as soon as I add the functions (init and
ISR) the
microcontroller won't work anymore.
Anyone any idea how come? Has anyone experienced this before?
Besides that, The SPI interface isn't quite working as supposed.
I've written a program that sends several bytes to the ADC (setting
some registers). When I'm debugging the microcontroller with the
ULINK JTAG interface it all works as supposed, but when I stop
debugging and let the controller run on its own, the bytes that I
sent did not reach the ADC??????
Any kind of help will be rewarded,
Thanks in advance, Laurens
Re: [lpc2000] uC hangs when initialising external interrupt
2005-11-23 by Richard Duits
Hello Laurens,
Please take a look a the errata for the part you are using.
Hint: EXTMODE and EXTPOLAR and also the SPI have some bugs in the first
LPCs.
Richard.
laurensswaans wrote:
> Hello,
> ISR) the
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-11-28 by Laurens Swaans
Ik doe het maar in het nederlands he?
  Ik gebruik een evaluation board van Keil, kortom ik kan zo 123 geen errata vinden. Bij de leverbon staat niks vermeld van wat voor controller er op zit...
  Heb jij enig idee hoe ik daarachter kom (via uitlezen ID of zo??)
  Alvast bedankt,
  Laurens
Richard Duits <yahoo@...> wrote:
  Hello Laurens,
LPCs.
Richard.
> Hello,
> ISR) the
> YAHOO! GROUPS LINKS
  YAHOO! GROUPS LINKS
Yahoo! Messenger  NEW - crystal clear PC to PC calling worldwide with voicemail
2005-11-28 by Rob Jansen
Laurens,
with a good light source (e.g. Halogen lamp) you can just read the small
print on the device.
If you look on the product information page at the Philips website
(http://www.semiconductors.philips.com/pip/LPC2119.html for the lpc2129)
you will find an errata sheet almost at the bottom of the page under
"Support & tools". That document also describes what to look for.
Good luck,
Rob
2005-11-28 by Richard Duits
Hoi Laurens,
In je eerste mail heb je het over LPC2129 dus dat is de chip waar de je
errata voor moet opvragen. Het typenummer staat ook op het IC
(waarschijnlijk de grootste op het bord). De errata, user manuals, etc.
zijn te vinden op de Product Information Page (PIP) van de LPC2129:
http://www.semiconductors.philips.com/pip/LPC2119FBD64.html
Groeten,
Richard.
>   Alvast bedankt,
>   Laurens
>   Hello Laurens,
> LPCs.
> Richard.
> > Hello,
> > ISR) the
> > YAHOO! GROUPS LINKS
>   YAHOO! GROUPS LINKS
> voicemail
> YAHOO! GROUPS LINKS
