Programming LPC2292 with Crossworks
2005-11-29 by thomas_ploeger
Hi, I'm new in this stuff and I try to figure out wich connection I should use to program my LPC 2292. I using CrossWorks and I want to connect my board via serial port. Is it possible or should I use the JTAG interface? Cheers Thomas
2005-11-29 by Michael Johnson
Hi Thomas, CrossWorks supports the JTAG port only. Regards Michael
>Hi, > >I'm new in this stuff and I try to figure out wich connection I should >use to program my LPC 2292. >I using CrossWorks and I want to connect my board via serial port. > >Is it possible or should I use the JTAG interface? > >Cheers > >Thomas > > > > > > > >Yahoo! Groups Links > > > > > > > >
2005-11-29 by Thomas Ploeger
Hi, :-( So just with JTAG. Does I need expensive stuff or can I build my own one based on the sourceforge schematics? Cheers Thomas
To: lpc2000@yahoogroups.com
Sent: Tuesday, November 29, 2005 5:07 PM
Subject: Re: [lpc2000] Programming LPC2292 with Crossworks
Hi Thomas,
Michael
>Hi,
>Cheers
>Thomas
>Yahoo! Groups Links
SPONSORED LINKS Microprocessor Microcontrollers Pic microcontrollers
8051 microprocessor
YAHOO! GROUPS LINKS
a.. Visit your group "lpc2000" on the web.
[Non-text portions of this message have been removed]2005-11-29 by Karim Virani
Crossworks works well with the $20USD wiggler-compatible from olimex: http://www.olimex.com/dev/arm-jtag.html purchase at sparkfun.com if you're in the US. Karim
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of Thomas Ploeger
Sent: Tuesday, November 29, 2005 11:08 AM
Cheers
Thomas
Hi Thomas,
Michael
>Hi,
should
>Cheers
>Thomas
>Yahoo! Groups Links
8051 microprocessor
YAHOO! GROUPS LINKS
Service.
Yahoo! Groups Links2005-11-30 by Robert Adsett
At 04:07 PM 11/29/05 +0000, Michael Johnson wrote: > >I'm new in this stuff and I try to figure out wich connection I should > >use to program my LPC 2292. > >I using CrossWorks and I want to connect my board via serial port. > > >CrossWorks supports the JTAG port only. Oh, come now, surely they haven't found a way of preventing you from using the serial port to download a program? ;) Robert " 'Freedom' has no meaning of itself. There are always restrictions, be they legal, genetic, or physical. If you don't believe me, try to chew a radio signal. " -- Kelvin Throop, III http://www.aeolusdevelopment.com/
2005-11-30 by Michael Johnson
CrossWorks can generate hex,bin,srec etc files which can be downloaded using the Philips tool. We don't support downloading from CrossStudio via the serial port using the standard Philips booloader. We have our own serial/USB/whatever bootloader that works with both CrossStudio and CrossLoad. It doesn't fit into the LPC2xxx world - we couldn't bring ourselves to do uuencoding :-> Regards Michael
>At 04:07 PM 11/29/05 +0000, Michael Johnson wrote: > > >>>I'm new in this stuff and I try to figure out wich connection I should >>>use to program my LPC 2292. >>>I using CrossWorks and I want to connect my board via serial port. >>> >>> >>> >>CrossWorks supports the JTAG port only. >> >> > >Oh, come now, surely they haven't found a way of preventing you from using >the serial port to download a program? ;) > >Robert > >" 'Freedom' has no meaning of itself. There are always restrictions, be >they legal, genetic, or physical. If you don't believe me, try to chew a >radio signal. " -- Kelvin Throop, III >http://www.aeolusdevelopment.com/ > > > > > >Yahoo! Groups Links > > > > > > > >
