Lpc2000
clock freq. for new LPC2103
2005-12-08 by Gus
Anyone can help me in figuring out the best oscillator frequency to
run LPC2103 at the high speed (near 70Mhz) but keeping UART standard
baud rates? 9600 and 115200 for example
Gus
RE: [lpc2000] clock freq. for new LPC2103
2005-12-08 by Joel Winarske
The LPC2101/2/3 implement a fractional divider on the UARTs, just as in the
LPC214x series.
Enter in your peripheral clock and desired baud rate into my utility and it
will return a list sorted by margin of error:
http://groups.yahoo.com/group/lpc2000/files/Tools/lpc2fdcalc.exe
You should be able to run right at 70MHz and get nearly any baud rate you
like, at least on the UARTs...
Joel
Re: clock freq. for new LPC2103
2005-12-08 by lpc2100_fan
Gus,
I agree with Joel about the UART frequencies. To answer your question,
use a 10 MHz crystal, the only one that is within the PLL range 10-25
and that can generate the 70 MHz dead on.
Bob
in the
> LPC214x series.
and it
rate you
> Joel
