Lpc2000
Building USB emulator
2005-12-14 by householder_lpc
I'm searching for information on the working of an emulator.
What would it take to make a Wiggler type emulator, but using the USB
port in stead of the parallel port... Which software would I need on
the host side (in addition to a USB driver) to be able to debug from
standard debugging tools? Is RDI interesting for this?
Thank you.
Re: [lpc2000] Building USB emulator
2005-12-14 by haare_in_der_dusche
An interesting approach is done here
http://www-user.tu-chemnitz.de/~heha/bastelecke/Rund%20um%20den%20PC/USB2LPT/index.html.en
This is a USB-parallel adapter which comes with a Windows device driver,
that hooks into direct I/O accesses to the parallel port.
Thus a standard Wiggler ought to work when attached to this device,
albeit a tad slowly when reading data.
I've not yet had time to test this.
When developing a "true" USB solution, the MPSSE embedded in the FTDI
FT2232C should be an interesting starting point, given that there is
software provided for JTAG access:
http://www.ftdichip.com/Projects/MPSSE/FTCJTAG.htm
This I presume to be more interesting and time-worthy than mere bit-banging.
___________________________________________________________
Telefonate ohne weitere Kosten vom PC zum PC: http://messenger.yahoo.de
Re: Building USB emulator
2005-12-14 by khachsat
--- In lpc2000@yahoogroups.com, "householder_lpc" <nieuw_bericht@h...>
> Thank you.
Some russians create USB emulator named MTlink, compatible with Jlink
and used the same DLL and driver for communication (JLinkARM.dll).
This device is based on ARM core, not M16c core like original Jlink.
So, cloning is possible, but I do not clear about legallity of that.
Re: [lpc2000] Re: Building USB emulator
2005-12-14 by George M. Gallant, Jr.
Where are the specs? I could envision using an 8-bit micro with an
embedded usb
port to bit/bang the jtag pins. I have a similar device (serial) that
drives a Motorola
68332 BDM.
George
George
> USB
> > Thank you.
> SPONSORED LINKS
> Microprocessor
> Microcontrollers
> Pic microcontrollers
> 8051 microprocessor
> ______________________________________________________________________
> YAHOO! GROUPS LINKS
>      1.  Visit your group "lpc2000" on the web.
>      2.  To unsubscribe from this group, send an email to:
>          lpc2000-unsubscribe@yahoogroups.com
>      3.  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>         Service.
> > Thank you.
I don't seem to find this MTlink. Is information on it available
anywhere on the web?
Thanks a lot.
The spec is a level of performance that is significantly higher than
Wiggler-based debugging.
It would seem interesting to use an LPC with a USB controller as JTAG
emulator, LPC2142 or so.
The thing I'm not sure about is what the reference points are.
What kind of traffic is there between emulator and target?
What kind of traffic is there between host usb driver and usb-based
emulator?
What kind of software is needed between host usb driver and the debugger?
What kind of traffic is there between the debugger and this program?
With "what kind of traffic", I mean, what protocol is used between
these "application layers"...
--- In lpc2000@yahoogroups.com, "George M. Gallant, Jr."
> embedded usb
> drives a Motorola
> 68332 BDM.
> George
> George
> > USB
> > > Thank you.
> > SPONSORED LINKS
> > Microprocessor
> > Microcontrollers
> > 8051 microprocessor
> > YAHOO! GROUPS LINKS
> >         Service.
2005-12-14 by theothervmax
MT-Link's manufacturer web site:
www.mt-system.ru
It's all in russian though.
MT-Link is a functional analogue of J-Link and costs $70.
  Max Volkov
--- In lpc2000@yahoogroups.com, "householder_lpc" <nieuw_bericht@h...> wrote:
> > > Thank you.
> Thanks a lot.
2005-12-14 by Dominic Rath
When I tested bitbanging on a LPC2294, I were able to toggle bits at around
15mhz - each access to a gpio set/clear register took 2 cycles. That's
without serving usb (no idea how expensive this is on lpc devices), and
without any processing, loop handling, and so on. I wouldn't use bitbanging -
use a small cpld as a serial shift register, that would be way faster.
Emulator -> Target: Totally target dependant, the ARM7 TRM has information on
how to debug these devices.
Usb-driver -> Usb-based-emulator: Totally dependant on the design. You could
bitbang, which would be awfully slow at ms latencies. You could define a
high-level jtag interface, in that case you would transfer your jtag
commands. Or you implement all debugging inside the emulator, then your
traffic is whatever protocol you use, GDB, RDI, Telnet.
Everything else also depends on these choices.
Dominic
> emulator?
