Thank you very much for your suggestions. Those are really worthy
me. Especially your tease helped me to breathe normally and feel
that microcontroller world is not that magical what I thought.
"Feel like Alice in Wonderland???"
==>In fact my position is just opposite; because I got nobody beside
me here. So, mentally I was depressed. Only help I have is the
internet groups and forums. So, I am little bit nervous.
I am trying to understand datasheets and started reading the
helpfiles came with the IAR workbench compiler.
Thank you.
--- In lpc2000@yahoogroups.com, Rob Jansen <rob@m...> wrote:
> Mahbub1833,
> feel like Alice in Wonderland ???
> >I am newbie in microcontroller world as well as in great ARM
world.
> >WORTHLESS TALK:
> >Although I know that ARM microcontrollers are for the
professionals;
> Welcome in the wonderfull world of ARM microcontrollers,
defenitely not
> only for the professionals.
> With different not-too-expensive boards and free Gnu C compiler it
is a
> real nice target for hobbyists also.
> >BLOODY REQUEST:
> >My request goes to all great professionals of this group. Please
> >make a starting point for us (newbie). More examples and projects
> >are needed to learn programming LPC series smoothly. Especially
step
> >by step tutorial with code would be great. (Please give me some
link
> >if there any).
> It should not be that hard if you start from the IAR examples - I
guess
> they have a "Hello World" in the form of a flashing LED or
something
> similar. These are always nice examples to start from.
> There is also a good book from Hitex (called something like "The
> insiders guide to the ARM7") to start with.
> >NEED HELP:
> >I have IAR LPC2148 development kit and J-Link adapter. I tried
> >example codes using IAR workbench and those run fine. But I
couldn't
> >understand the coding with my little PC based programming
knowledge.
> >Now my questions are-
> >1. How would I learn C language specified for this particular
> >microcontroller?
> There is nothing special or magical about C for the lpc21xx
series. It
> is just standard (ANSI compliant) C.
> You just have to remember that you do not have all resources as
you have
> on a PC. For printf() you need a console - most development
environments
> will support this.
> For file I/O you need a storage device - not standard available so
> forget this for the time being.
> Accessing stuff like the LEDs and other I/O on the board need the
> different peripheral blocks in the chip. Check out the Philips
website
> (www.semiconductors.philips.com) and get the datasheet and - more
> important - the user manual for your chip.
> This user manual contains detailed information on the meaning of
all the
> bits in the I/O registers.
> Note: all I/O is memory mapped an can be read and written using a
> standard C pointer, but it has to be declared volatile - otherwise
> compiler may optimize this out ...
> Okay, you got all this ...
> Take your simplest Keil example and try to add code to light an
LED on
> the board.
> Now you need some hardware knowledge of the board:
> When is the LED lit? when the output port is tied to ground or
to 3.3V ?
> What is the output bit ?
> Assume the LED is lit when tied to ground, you need to program a 0
level
> in the output bit.
> Assume the output bit is P0.20.
> Start reading the user manual of the 2148.
> Chapter 8.4.1 shows the meaning and content of the IODIR register,
this
> register determines if a bit is an input or output bit. You have
to set
> bit 20 to make P0.20 an output port:
> IO0DIR |= (1<<20); // Perform a logical OR of IODIR to set
bit 20 to 1
> (note: IO0DIR can also be called IODIR0, it is defined in the
lpc21xx.h
> - or similar - include file)
> Now all you have to do is set the P0.20 bit to 0, there are two
ways to
> do this. See 8.4.3, 8.4.4 and 8.4.5
> You can write all bits using the IO0PIN register (you need to
apply a
> mask to set or reset the bits you want), use IO0SET to set any
bits to 1
> or IO0CLR to clear any bits (set bits to 0).
> Read the manual: "Writing a 1 produces a low level at the
corresponding
> port pins"
> IO0CLR = (1<<20);
> You don't need any mask or whatever, just writing a 1 is enough -
as is
> stated in the manual.
> Now compile the program and download it to your board.
> You may want to check that you compile and download into RAM, not
in Flash.
> Flash has a limited number of write cycles - do not worry too much
about
> this, it's a large number but for these simple tests it is just a
waste
> to program flash.
> Then download and run using the IAR debugger.
> Please check the IAR / J-Link manuals on this.
> >5. Somebody please upload or link few more codes to learn step by
> >step.
> The problem is that we all have our favorite environment.
> I use a board from Embedded Artists and they have their own make
> environment, farily well documented in the manual.
> That manual is available via their web page and an example can be
found
> somewhere on my ARM page (http://www.myvoice.nl/electronics/)
> Check out "Timing your programs" that one contains a simple piece
of
> code to read a timer and print data on the serial port (UART0).
> >6. Suppose I want to interface a LDR to the circuit and want to
show
> >the value in the LCD display. Now which pin (AD) would I use to
> >connect the LDR? And what would be the program?
> Read the manual, as far as I know all AD ports are the same. It
just
> depends on which pin is still available on your board for your own
I/O.
> The program is simple:
> 1) initialize A/D (and UART)
> 2) start A/D conversion
> 3) wait for A/D conversion to be complete
> 4) print out value of the UART
> 5) repeat ...
> Just start reading the user manual carefully. It's all there -
Best is
> to read and then drop your detailed questions in this group again.
> >I apologize for my kiddy questions in the professional group. I
need
> >your help to go ahead in the microcontroller world.
> we all have to start somewhere. I started about 25 years ago with
a home
> built 6502 kit from Elektor, meanwhile I have no problems reading
> datasheets and user manuals for chips like the lpc2148.
> But I do have problems with standard Windows programming and that
kind
> of things. Programming web tablets, telephones and telephone
exchanges
> is what I did, but do not ask me to write a Visual C (or Basic)
version
> of a calculator ...
> Oh, this group is mixed with professionals and hobbyists on all
sorts of
> levels. So all levels of Questions are welcome!
> In time you will be able to tell other how to ...
> Good Luck,
> Rob
