Lpc2000
J-Link errors on initial installation
2005-12-13 by Steve Franks
Hi All,
Just plugged in a jlink for the first time.  Usb drivers look good in
devman, and green light on unit is on, but I can't talk to it; I thought
someone on the list might have seen the following errors before.
Steve
J-Link>usb 0
Connecting to J-Link via USB (Port: 0)
JTAG_GetFirmwareString: J-Link reports unsupported firmware string size of
26956
 (expected 112)
Could not identify firmware (Read failure)
J-Link>usb 1
Connecting to J-Link via USB (Port: 1)
Can not connect to J-Link via USB.
J-Link>usb 2
Connecting to J-Link via USB (Port: 2)
J-Link>usb 3
Connecting to J-Link via USB (Port: 3)
J-Link>usb 0
27502
 (expected 112)
J-Link>usb 0
25376
 (expected 112)
J-Link>
RE: [lpc2000] J-Link errors on initial installation
2005-12-13 by Joel Winarske
Is green light solid or blinking?  If driver is not loaded it will just
blink.  The driver updates the J-Link firmware on the fly.  So you want to
be working with the latest J-Link driver from Segger's website.
Are you restarting jlink.exe each time you reinsert your J-link, or leaving
it open?
The other thing you might want to do is power cycle your machine with J-Link
plugged in.  Then see if devmgmt.msc (shortcut from start/run) is still
happy.
Joel
> Hi All,
> Thanks,
> Steve
> J-Link>usb 0
> 26956
>  (expected 112)
> J-Link>usb 1
> J-Link>usb 2
> J-Link>usb 3
> J-Link>usb 0
> 27502
>  (expected 112)
> J-Link>usb 0
> 25376
>  (expected 112)
> J-Link>
RE: RE: J-Link errors on initial installation
2005-12-14 by Steve Franks
Joel,
Did all that. Light is solid, rebooted machine, deleted & re-installed
latest driver from segger site, etc.  Figure the box is just fried?  It's
been in the dev-kit box unused for a year...but it was in a cool, dark,
ESD-controlled place.
From the error messages, it looks like jlink.exe is about to load the
firmware, but keeps getting bogus string sizes for the fw update.  Tried
several usb cables.  I just thought someone might of seen this, but if not,
I think I'll assume it's DOA.
Steve
> Message: 2
>    Date: Tue, 13 Dec 2005 12:54:33 -0800
>    From: "Joel Winarske" <joelw@...>
> Subject: RE: J-Link errors on initial installation
> will just
> So you want to
> J-link, or leaving
> it open?
> machine with J-Link
> start/run) is still
> happy.
> Joel
> > Hi All,
> look good in
> it; I thought
> > Thanks,
> > Steve
> > J-Link>usb 0
> string size of
> > 26956
> >  (expected 112)
> > J-Link>usb 1
> > J-Link>usb 2
> > J-Link>usb 3
> > J-Link>usb 0
> string size of
> > 27502
> >  (expected 112)
> > J-Link>usb 0
> string size of
> > 25376
> >  (expected 112)
> > J-Link>
RE: [lpc2000] RE: RE: J-Link errors on initial installation
2005-12-14 by Joel Winarske
not,
You might try an incremental update from approximate version of original
manufacture.  Perhaps once you update to a certain version it will take the
most recent.  You might contact Segger directly to get driver archives.
Joel
