Lpc2000
ISP Problem
ISP Problem
2005-12-20 by Rodrigo Cesar da Silva Martins
I can't make this thing work at all!!! Serial interface works fine,
because I tested it using Hiperterminal (I'm using a MAX202, 5V, but
I'm sure LPC is 5v tolerant). P0.14 and RESET pins go low, after a
while reset goes high and after that P0.14, the way it should be, I
think. I receive a data through the serial but the board doesn't
respond. I'm using the Philips Flash Utility V2.2.1 and it works fine
in my MCB2100 board. There is something I am doing wrong? I'm using a
MOSFET transistor instead of BC850 used in MCB2100, but I don't think
it's a problem because the high e low levels are just fine.
Re: [lpc2000] ISP Problem
2005-12-20 by Richard Duits
The LP2xxx are 5 volt tolerant, but this does not mean that the MAX202
will work with the 3.3 volt signals from the LPC. Did you check the
datasheet of the MAX202 if it will accept 3.3 volt input signals?
Richard.
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
2005-12-20 by Michael Rubitschka
Hi
I dont think this will work out and why take the risk?
I allways use the max3232 or some derivates for my designs.
f.e. the ST3232 wounderfull chip and cheap.
Cheers
Michael OE1MIS
>From: Richard Duits <yahoo@...>
>Reply-To: lpc2000@yahoogroups.com
>Subject: Re: [lpc2000] ISP Problem
>Date: Tue, 20 Dec 2005 13:48:00 +0100
>Richard.
> > YAHOO! GROUPS LINKS
Re: ISP Problem
2005-12-20 by Mark Butcher
Hi
From the information you have given I can not say why the ISP is not
working on your board but I can clear up the MAX202 issue. I have
several thousand devices in the field using the MAX202 driven from 5V
(to be precise MAX202ECUE) so there is no problem with this part (if
used correcty).
I can however confirm from experience that the serial port of the
LPC2106 (the one I use, but probably generally the case) is very
sensitive to glitches on its input. In my case I had no problems
communicating using the FLASH utility but downloads would almost
always fail until I removed a gate with overshoot in the receive path.
The only thing that I would suggest is to verify the quality of the
signals and use a low speed to establish communication until you know
that all is well. Check also that the quarz that you are using doesn't
have a frequency which makes async communication difficult - don't
forget that the ISP program has to automatically set its serial baud
rate when establishing a connection.
Mark Butcher
www.mjbc.ch
--- In lpc2000@yahoogroups.com, "Rodrigo Cesar da Silva Martins"
fine
a
think
