Lpc2000
KICK me a bit to START (LPC22xx)
2005-12-21 by mahbub1833
Very newbie problem. Sorry for that.
IO0SET = 0x00000100; /* Turn LED Off (P0.8 = 1) */
I didn't get the 0x00000100 in datasheet. What does it mean? How would
I understand other pin configerations as well? Please tell this newbie
in details.
Thanks in advance.
Re: KICK me a bit to START (LPC22xx)
2005-12-21 by rtstofer
0x00000100 represents 8 4-bit hex digits, 32 bits in all.  The right
two digits represent the bits 0..7 so the 1 in the next digit is bit
8 of 32 and it would set P0.8 to a 1.
To clear P0.8 do:
IO0CLR = 0x00000100;
--- In lpc2000@yahoogroups.com, "mahbub1833" <fireball003@g...>
wrote:
> Hi,
would
newbie
> in details.
> Thanks in advance.
Thank you very much!
That means if I want to enable p0.9 then i would write 0x00000200
(0x0000 0000 0000 0000 0000 0010 0000 0000)...Am I right??
Then what for p1.25 or p3.4 or other pins? How would I initialize
those pins in this way?
Would you please send me a link where it is already explained?
Thank you.
> To clear P0.8 do:
> wrote:
> > Hi,
> would
> newbie
> > in details.
> > Thanks in advance.
@Embedded Artists - Thank You
2005-12-21 by Michael Rubitschka
Yesterday I got my XMas Tree.
And I must really confess I like it.
Also till now I routed "eval" boards myself.
I am not willing to spend f.e. 1k $ for a LPC 3000 board.
This is simply crazy. I would be really interested what kind
of bells & whistles they added to justify this kind of price.
On the other hand companies like emb. artists let me
reconsider my strategy.
I think I will soon buy a "real" board from them.
The price is really fair and the boards are interesting.
So thanks and Merry Xmas
Michael
Re: [lpc2000] Re: KICK me a bit to START (LPC22xx)
2005-12-21 by Carsten
Hello.
Here are some helping stuff:
/****************** define PortPin-Bits ***********/
#define PINSEL_BITPIN0  0
#define PINSEL_BITPIN1  2
#define PINSEL_BITPIN2  4
#define PINSEL_BITPIN3  6
#define PINSEL_BITPIN4  8
#define PINSEL_BITPIN5  10
#define PINSEL_BITPIN15  30
/************* define Pin-Function-Bits ***********/
#define PINSEL_FIRST_ALT_FUNC  1
#define PINSEL_SECOND_ALT_FUNC 2
#define PINSEL_THIRD_ALT_FUNC  3
#define PINSEL_4TH_ALT_FUNC    4
/******* use for uart0 and uart1 for example ******/
// Values of Bits 0-3 in PINSEL to activate UART0
#define UART0_PINSEL
((PINSEL_FIRST_ALT_FUNC<<PINSEL_BITPIN0)|(PINSEL_FIRST_ALT_FUNC<<PINSEL_BITPIN1))
// Values of Bits 16-19 in PINSEL to activate UART1
#define UART1_PINSEL
((PINSEL_FIRST_ALT_FUNC<<PINSEL_BITPIN8)|(PINSEL_FIRST_ALT_FUNC<<PINSEL_BITPIN9))
// Mask of Bits 0-3
#define UART0_PINMASK      (0x0000000F)    /* PINSEL0 Mask for UART0 */
// Mask of Bits 16-19
#define UART1_PINMASK      (0x00000F00)    /* PINSEL0 Mask for UART0 */
/**************** set PINSEL **********************/
  PCB_PINSEL0 = (PCB_PINSEL0 & ~UART0_PINMASK) | UART0_PINSEL;
  PCB_PINSEL0 = (PCB_PINSEL0 & ~UART1_PINMASK) | UART1_PINSEL;
regards
carsten
> Thank you.
> > To clear P0.8 do:
> > wrote:
> > > Hi,
> > would
> > newbie
> > > in details.
> > > Thanks in advance.
Telefonieren Sie schon oder sparen Sie noch?
NEU: GMX Phone_Flat http://www.gmx.net/de/go/telefonie
Re: [lpc2000] @Embedded Artists - Thank You
2005-12-22 by Rob Jansen
Christmas is now complete; my tree arrived today :-)
I could not find anything special on the board but I understood from a
collegue that these kind of boards are expensive to create.
Remember, the LPC3000 is a BGA device.
You will defenitely love the boards. I've got the 2106, 2138 and 2148
boards, with prototype boards (for these prices I cannot even create a
breadboard solution).
The current prototype board needs extra 'spacers' between board and
module, otherwise the DB9 connector on the lpc21xx module in in the way.
I did not like this way of mounting so I removed the DB9 connector from
the lpc module and placed the second connector on the prototype board.
Two wires route the Rx/Tx signals to the module, the generation of the
Reset and P0.14 signals using RTS/DTR is already on the board.
Look at http://www.myvoice.nl/electronics/ for a small description and
some photo's
I just received their newest design: a prototype of the education board.
This is a nice board for students or as hands on board for a programming
workshop.
Merry XMas,
    Rob
