Lpc2000
re: LPC FLASH security (CRP) broken?
2005-12-22 by jayasooriah
Was Philips misleading us about Code Read Protection?
The preliminary user manual for LPC2119/2129/2194/2292/2294 dated 2004
May 03 in the section on CRP states:
> When the code read protection is enabled the JTAG debug
> port, external memory boot and the following ISP commands
> are disabled:
> • Read Memory
> • Write to RAM
> • Go
> • Copy RAM to Flash
> The ISP commands mentioned above terminate with return
> code CODE_READ_PROTECTION_ENABLED.
> The ISP erase command only allows erasure of all user
> sectors when the code read protection is enabled.
Philips stated (by way of poster dated Sat Dec 17, 2005  11:52 AM)
that the purpose of CRP as:
> Code Read Protection (CRP) was implemented with intention
> to protect on-chip Flash content from preying eyes.
It appears that Philips made these claims while it knew that CRP can
be defeated by other methods, including parallel programming or
booting from external memory.
1/  LPC parts without external memory interface support parallel
programming.  This method can be used to read and write on-chip flash.
2/  On LPC parts with external memory, it is possible to force the
part to boot on external memory.  Code in external memory can read and
If the above claims are not true, it would be a simple matter for
Philips to say so.  The fact that Philips has chosen to go quiet on
this issue seems to suggest the claims are indeed true.
If this is the case, then clearly Philips has intentionally misled us.
Comments anyone?
Jaya
Re: [lpc2000] re: LPC FLASH security (CRP) broken?
2005-12-22 by Robert Adsett
> > are disabled:
> > • Read Memory
> > • Write to RAM
> > • Go
> > • Copy RAM to Flash
I've seen the hints you provided on this but no real evidence yet.  Since
this appears to directly contradict what is on Philips Website I remain to
be convinced.  You need to be able to show that the parts can be parallel
programmed and that method of programming bypasses the CRP
features.  Certainly if parallel programming is possible it raises that as
a possibility since presumably the boot loader would not be involved.
There is another possibility though and that is that you have been the
victim of marketing manipulation of terms.  It is quite possible that the
references you have seen to parallel programming are just indicators that
the devices can be programmed off board with an appropriate programmer and
that programmer uses either the serial or JTAG ports to do the programming.
Well they do claim that turning on CRP disables the ability to boot from
external memory.  Do you have any evidence to the contrary?  This does have
the advantage of being easily tested.  Have you tested it and if so what
did you use for a test case?  If not, why not?  With a test case this would
be easy to duplicate and verify.
Hey give them a bit of a chance.  They do, I think, need to respond.  If
this is coming out of the blue they may need some time to figure out
exactly what it is they are responding to.  Also at this season the people
most able to respond may well be on vacation.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
Re: LPC FLASH security (CRP) broken?
2005-12-22 by philips_apps
Jaya,
I am truely sorry but I do not understand your point. A parallel
programmer will not be able to read or program a secured device. A
microcontroller that executes an external program can not be secured
because the external code can always be compromised. Booting from
external is not possible once the device is secured and programmed
to boot internally.
Did I miss something?  Oh yes, you, the user is always able
to "undo" your security while running IAP but how would a "spy" be
ever able to run IAP (In application programming). The devices you
mentioned also leave the option to reenable JTAG in your program,
again, chicken and egg, as the spy will not be able to alter your
program how can he enable JTAG.
Philips Apps
--- In lpc2000@yahoogroups.com, "jayasooriah" <jayasooriah@y...>
2004
> > are disabled:
> > • Read Memory
> > • Write to RAM
> > • Go
> > • Copy RAM to Flash
can
flash.
and
us.
> Comments anyone?
> Jaya
Robert,
fyi, parallel programming is possible but the only thing parallel is
the databus, in the end the parallel programmer again uses the
bootloader for programming.
The other Robert
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
2004
> > > are disabled:
> > > • Read Memory
> > > • Write to RAM
> > > • Go
> > > • Copy RAM to Flash
can
flash.
yet.  Since
remain to
parallel
that as
involved.
that the
indicators that
programmer and
programming.
read and
boot from
does have
so what
this would
on
respond.  If
out
the people
> Robert
restrictions,   be
chew a
Pleae let me clarify.  I am seeking affirmative answers to the two
questions below so as to assure client that code in the LPC parts
(with CRP enabled) is secure.
According to the Product Overview Edition 08 2005 provide by Philips,
all of the LPC2100 series parts less 2194 is marked "Y" for Parallel
Programming (PP) feature column.
Client was told PP can read and program on-chip flash.  Philips (Jim
E) by email has advised me that I could use PP to re-load the on-chip
flash for LPC2105 parts that my students manage to kill just by bad
coding.
Client wants Philips to confirm that if the device is secured using
CRP, then PP cannot be used to access the on-chip flash.
Your say:
> A parallel programmer will not be able to read
Q1: Can I tell client Philips has confirmed CRP is not voided by PP?
I am curious, what happens to a part when is CRP enabled, and if there
is no way to recover the part at all.
In the same Product Overview document referred to above, all of the
LPC2200 series parts that have external memory interface have a "-"
against the PP feature column.  If it was a "N", I would tell client
this means these devices do not support parallel programming.  I am
not sure what the "-" means.
If these devices cannot be parallel programming, how does the on-chip
flash gets loaded the first time, or after it has been corrupted?
Client was told that these parts are loaded (first time) by forcing
them to boot from external memory by pull downs on specific pins
during reset.
Q2: Would Philips confirm such methods cannot be used to defeat CRP?
I am curious how Philips loads the flash first time for these parts.
You make the statement:
> Oh yes, you, the user is always able to "undo" your
If the user can "undo" CRP, you must assume the "spy" can.
Security by obscurity (which attempts to use secrecy of design,
implementation, etc) to ensure security is not acceptable to the client.
As an example, Philips "secured" boot loader sector by keeping the
programing algorithms a secret.  My students killed two of my 2105
boards by accident.  I could not tell them what they should not do
because I did not know the programming algorithm.
I am sure there are many who have worked out the algorithm as I now
have.  How long do you think it takes for one of these persons to
publish the algorithm on the net, assuming this has yet to happen?
Jaya
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...> wrote:
> Jaya,
> to boot internally.
> Philips Apps
Robert,
Now I am confused even more ... :(
According to your Jim E, I am able to reload the on-chip boot sector
using PP even when the boot loader has been corrupted or erased.
This must mean PP does not require or depend on the boot sector being
intact for programming purposes.  You are saying it does?
Jaya
> Robert,
> The other Robert
Re: [lpc2000] Re: LPC FLASH security (CRP) broken?
2005-12-22 by Tom Walsh
>coding.
Good grief!  The last time I had a "secure" part with an external bus, I
proved that I could defeat the "security" by enabling the external ROM
and then reading the internal ROM.  There was a problem with that part.
Have you done nothing but 'read'?  Come on now, try it out, see if you
can break it.  Spend some money, get a parallel programming setup, can
you break it??
Sheesh
TomW
>Your say:
>during reset.
>Jaya
>>Jaya,
>>to boot internally.
>>Philips Apps
>Yahoo! Groups Links
2005-12-22 by Mauricio Scaff
If the parallell programming is done by the bootloader, and the serial
programming is done by the bootloader, and the JTAG is controlled by the
bootloader, How the bootloader is programmed for the first time (in
factory ) ????
Another question:
Is it possible to erase the bootloader using the provided IAP calls ? If
so, is there anyway to recover it ?
Mauricio
> Robert,
> The other Robert
> 2004
> > > > are disabled:
> > > > . Read Memory
> > > > . Write to RAM
> > > > . Go
> > > > . Copy RAM to Flash
> can
> flash.
> yet.  Since
> remain to
> parallel
> that as
> involved.
> the
> that the
> indicators that
> programmer and
> programming.
> read and
> boot from
> does have
> so what
> this would
> on
> respond.  If
> out
> the people
> > Robert
> restrictions,   be
> chew a
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Mauricio,
with IAP calls you can not erase the bootloader, it protects itself
as it knows where it is located.
I can assure you we have an options to program the virgin device on
a tester.
Regards, Robert
serial
by the
(in
> factory ) ????
> Another question:
calls ? If
> Mauricio
> > Robert,
parallel is
> > The other Robert
dated
> > 2004
> > > > > are disabled:
> > > > > . Read Memory
> > > > > . Write to RAM
> > > > > . Go
> > > > > . Copy RAM to Flash
11:52 AM)
CRP
> > can
or
parallel
chip
> > flash.
> > yet.  Since
I
> > remain to
be
> > parallel
raises
> > that as
> > involved.
been
> > the
possible
> > that the
> > indicators that
> > programmer and
> > programming.
force the
> > read and
> > boot from
This
> > does have
if
> > so what
case
> > this would
for
quiet
> > on
> > respond.  If
figure
> > out
> > the people
> > > Robert
> > restrictions,   be
try to
> > chew a
> > SPONSORED LINKS
> > Microprocessor
J9hJ5qyXg0WPR0l6g>
> > 	Microcontrollers
q01nxwg>
7c6LyBvUqVQ>
> > 8051 microprocessor
VIlekkDP-A>
> > YAHOO! GROUPS LINKS
of
[lpc2000] I Gotta Know
2005-12-22 by Marko Pavlin (home)
I am not Elvis, but "I Gotta Know".
Is here anyone dealing with wireless 802.15.4 on LPC21xx  or even using
Chipcon CC2420 with LPC21xx, or "I'll be one and only till the end of time"?
Thank you!
Marko
philips_apps wrote:
> Mauricio,
Ok. It sounds good.
> a tester.
Let's say that your answer is a little bit obscure. So my code is
protected as far as no one knows what happens in that "tester" ? It
doesn't look like something very safe.
Client : - Is my code secure in this device ?
Me  : - Yes, of course. Noboby can read your code. Well, Philips can,
but they told me that they will never tell how to do that.... By the
way, may you give me your bank account and password please ?
> Regards, Robert
Mauricio
RE: [lpc2000] Re: LPC FLASH security (CRP) broken?
2005-12-22 by Joel Winarske
How is a bootloader 'update' handled if IAP calls cannot erase the
bootloader?
> a tester.
Can any of these 'options' read a device?
Is CRP solely implemented in the software based bootloader?
Joel
RE: I Gotta Know
2005-12-22 by Steve Franks
> Message: 10
>    Date: Thu, 22 Dec 2005 20:58:17 +0100
>    From: "Marko Pavlin (home)" <mp@...>
> Subject: I Gotta Know
> even using
> the end of time"?
> Thank you!
> Marko
Marko,
I've been using the CC2420 for quite awhile on the AVR's, actually, the
availability of GCC on the LPC and the existence of some template libs for
the CC2420 was the primary reason I started investigating the LPC's.
Steve
2005-12-22 by derbaier
> > a tester.
How can you catagorize it as not "very safe" without even knowing what
a "tester" is??  A tester, like the HP3000, is often used to test
devices while they are still on the wafer prior to packaging.  Devices
at that stage are far more accesible than they are after they are
packaged, and all you can get at are the pins or balls. It could also
program the device via access methods that become completely
unavailable after packaging. For instance, if the device is a "stacked
die" part, then it could be programed before the dice are even bonded
out. This is not to say that is what is actually happening, but just
to point out that making a judgement from a position of no knowledge
is not likely to be very profitable to anyone.
BTW, if you are assuming that what is happening is just hidden access
mechanisms on completed parts, then I would agree that you are
justified in worrying about security. "Security by obscurity" always
fails eventually.
-- Dave
2005-12-22 by Richard Duits
The bootloader is updated by a program that is uploaded to the internal
ram. I guess this program contains the flash programming code itself and
it does not use the iap calls at any time.
Richard.
> bootloader?
> > a tester.
> Joel
> SPONSORED LINKS
> Microprocessor
> 	Microcontrollers
> 8051 microprocessor
> YAHOO! GROUPS LINKS
At 05:05 AM 12/22/05 +0000, philips_apps wrote:
>Robert,
Thanks Robert, Any chance of this being documented for us mere mortals
:)  or is it reserved for device programmer manufacturers.
Dear Robert,
Could you also confirm you have no options to read a CRP enabled
device on your tester?
The gripe here is that client requirements are quite clear.  The
client will not use a part unless the manufactur guarantees there are
no (known) hidden or undisclosed methods tha the manufacture has
chosen not to disclose that the "enemy" can use to read locked down code.
The client did not say this explicitly, but it my guess that this
client thinks that if Philips chose not to disclose LPC flash
programming algorithm, it may well likewise chose not to disclose
methods or open holes in in the implementation that defeat CRP.
I know the client is happy with protection oferred in AVR device, and
is looking to LPC for other requirements, but the trust component is
not there yet in relation to Philips.
For this reason, I would suggest Philips put effort on this front in
relation to CRP feature if it wants LPC parts to be used in the same
league as AVR parts.
Jaya
> Mauricio,
> a tester.
> Regards, Robert
2005-12-23 by jayasooriah
Robert,
The other Robert (from Philips) appears to be talking about something
else.
The PP method I was referring is quite well documented for 87C576
(which is also ticked as "Y" for PP field in the Product Selection
Guide that started this thread) in Application Note 455.
http://www.semiconductors.philips.com/acrobat_download/applicationnotes/AN455.pdf
Jaya
> >Robert,
restrictions,   be
chew a
