Lpc2000
External Interrrupts, Rowley Crossworks
2005-12-30 by lpc2131makingcl
I'm running sample code from Rowley, using their "Crossworks for ARM"
development suite. I'm working with IAR's demo board for the LPC2148
and I'm having trouble with external interrupts. I have been able to
run Rowley's timer_interrupt example, and have been able to stop at a
set breakpoint in the startup.s file "irq_handler" section. But, I
have not seen the external interrupt get that far. That being said, I
have verified that the EXTINT flag is being set as it should be, when
the external interrupt is asserted. Even though the flag is being set,
it does not kickoff the irq_handler.
Any ideas what the problem could be?
P.S. I have used Rowley's timer_interrupt code as an example for my
external interrupt code - they should act the same way, correct?...
Thanks!
Matt
Re: External Interrrupts, Rowley Crossworks
2005-12-30 by bigakisgr
Maybe you must define VECTORED_IRQ_INTERRUPTS in the preprocessor
defininition screen.
Then in your code, after initialization, (before the endless for loop
on the main program), call __ARMLIB_enableIRQ();
This works for me.
> Thanks!
> Matt
