Lpc2000
.ld for 2148
.ld for 2148
2005-12-29 by paloalgodon
I admit I'm a little disappointed about getting no replies on this
one.  Looking over the exisiting .ld files I have, it would appear to
be less than an hour's work (?).  I just figure, why re-invent the
wheel, when there's probably a bunch of *tested* copies running around
(especially when I'm a newbie).  I was actually suprized that there
wasn't already a complete set of .ld files for all the lpc parts in the
files section of our group.  I understand that .ld files are typically
customized a bit, just like makefiles, but a straightforward one that
runs from rom and calls global ctors would be fine for most beginners,
I would think.  I will certainly post if/when I get one
working...course that could be counterproductive if we're trying to
keep all the folks used to having the hard stuff done for them (WinAVR)
off of our list <wink><wink>
Steve
Re: .ld for 2148
2005-12-29 by rtstofer
to
around
there
in the
typically
that
beginners,
to
(WinAVR)
> Steve
I don't think anyone is hiding the file, it's just that other tools
than GNU use a different approach.  Perhaps the .ld just isn't
around right now.
So, grab James Lynch's tutorial from
http://www.olimex.com/dev/pdf/ARM%20Cross%20Development%20with%
20Eclipse%20version%203.pdf and note that there is a process for
converting LPC2106 linker script (name *.cmd in the tutorial) to the
LPC2148.
Basically, you are just defining the size of flash and ram,
specifying an address for each and then assigning .text, .data
and .bss to the appropriate memory type.  There are a couple of
other symbols like _end, _bss_end and end (not defined in the
tutorial but required for sbrk and malloc).
The end of my 2106 file looks like
/* RTS - changed alignment for malloc() - was ALIGN(4) */
	. = ALIGN(8);						/*
advance location counter to the next 32-bit boundary */
	_bss_end = . ;						/*
define a global symbol marking the end of the .bss section */
	_end = .;
	/* define a global symbol marking the end of application RAM
PROVIDE (end = .);						/*
for sbrk	*/
That's about it.
Richard
Re: [lpc2000] .ld for 2148
2005-12-29 by Marko Panger
Hi !
I am attaching two .ld files I am using. I don't remember where do I
grab them (it was on www.gnuarm or somewhere else on this forum)
exactly. I adopted them to suit my needs on the LPC2138. Modifying them
for 2148 should be straight forward.
The ROM_fiq.ld file has a special ".fiqisr" section which is placed
directly on the exception vector (no extra jump needed) for optimum
performance when executing an FIQ from flash. If you define your
"fiqisr" section it will be placed right there.
Hope it helps !
marko,
uSmartX RTOS - mixing preemptive and non-preemptive worlds !
http://usmartx.sourceforge.net/
>Steve
>Yahoo! Groups Links
/*  RAM.ld:  Linker Script File                                        */
ENTRY(_start)
STACK_SIZE = 0x400;
RAM_LIMIT = 0x40008000;
/* Memory Definitions */
MEMORY
	FLASH (rx) : ORIGIN = 0x0, LENGTH = 0x80000			/* 512Kb of internal FLASH */
	SRAM (rwx) : ORIGIN = 0x40000000, LENGTH = 0x8000	/* 32Kb of internal SRAM */
/* Section Definitions */
SECTIONS
  	/* first section is .text which is used for code */
  	.text :
		*crt0.o (.text)
    	*(EXCLUDE_FILE(*crt0.o).text)         /* remaining code */
    	*(.rodata)               			  /* read-only data (constants) */
    	*(.rodata*)
    	*(.glue_7)
    	*(.glue_7t)
  	} > FLASH
	. = ALIGN(4);
	_etext = . ;
  /* .data section which is used for initialized data */
  .data  : AT (_etext)
    _data = .;
    *(.data)
    . = ALIGN(4);
    _edata = .;
  } > SRAM
  /* .bss section which is used for uninitialized data */
  .bss (NOLOAD) :
    _bss = . ;
    *(.bss)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;
  } > SRAM
/*  .heap ALIGN(4) :*/
/*  	_heap_begin = .;*/
/*  	*(.data_heap)*/
/*  } > SRAM**/
  /*. += 0x4000;*/
/*  _heap_end = .;*/
  . = RAM_LIMIT - 8 - 4 - 4 - 4 - 1024 - 1024;
  .stack ALIGN(4) :
  	_stack = .;
  	. += 4;
  	_undefined_stack = .;
  	. += 4;
  	_abort_stack = .;
  	. += 4;
	_fiq_stack = .;
	. += 4;
	_svc_stack = .;
	. += 1024;
	_usr_stack = .;
	. += 1024;
	_irq_stack = .;
	_estack = .;
  } > SRAM
  _end = . ;
  PROVIDE (end = .);
  /* Stabs debugging sections.  */
  .stab          0 : { *(.stab) }
  .stabstr       0 : { *(.stabstr) }
  .stab.excl     0 : { *(.stab.excl) }
  .stab.exclstr  0 : { *(.stab.exclstr) }
  .stab.index    0 : { *(.stab.index) }
  .stab.indexstr 0 : { *(.stab.indexstr) }
  .comment       0 : { *(.comment) }
  /* DWARF debug sections.
     Symbols in the DWARF debugging sections are relative to the beginning
     of the section so we begin them at 0.  */
  /* DWARF 1 */
  .debug          0 : { *(.debug) }
  .line           0 : { *(.line) }
  /* GNU DWARF 1 extensions */
  .debug_srcinfo  0 : { *(.debug_srcinfo) }
  .debug_sfnames  0 : { *(.debug_sfnames) }
  /* DWARF 1.1 and DWARF 2 */
  .debug_aranges  0 : { *(.debug_aranges) }
  .debug_pubnames 0 : { *(.debug_pubnames) }
  /* DWARF 2 */
  .debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
  .debug_abbrev   0 : { *(.debug_abbrev) }
  .debug_line     0 : { *(.debug_line) }
  .debug_frame    0 : { *(.debug_frame) }
  .debug_str      0 : { *(.debug_str) }
  .debug_loc      0 : { *(.debug_loc) }
  .debug_macinfo  0 : { *(.debug_macinfo) }
  /* SGI/MIPS DWARF 2 extensions */
  .debug_weaknames 0 : { *(.debug_weaknames) }
  .debug_funcnames 0 : { *(.debug_funcnames) }
  .debug_typenames 0 : { *(.debug_typenames) }
  .debug_varnames  0 : { *(.debug_varnames) }
ENTRY(_start)
STACK_SIZE = 0x400;
RAM_LIMIT = 0x40004000;
MEMORY
	FLASH (rx) : ORIGIN = 0x0, LENGTH = 0x20000			/* 512Kb of internal FLASH */
	SRAM (rwx) : ORIGIN = 0x40000000, LENGTH = 0x4000	/* 32Kb of internal SRAM */
SECTIONS
  	.text :
		crt0.o (.vectors)
		*(.fiqisr)
		crt0.o (.text)
    	*(EXCLUDE_FILE(crt0.o).text)         /* remaining code */
    	*(.rodata*)
    	*(.glue_7)
    	*(.glue_7t)
  	} > FLASH
	. = ALIGN(4);
	_etext = . ;
  .data  : AT (_etext)
    _data = .;
    *(.data)
    . = ALIGN(4);
    _edata = .;
  } > SRAM
  .bss (NOLOAD) :
    _bss = . ;
    *(.bss)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;
  } > SRAM
/*  	*(.data_heap)*/
/*  } > SRAM**/
  /*. += 0x4000;*/
/*  _heap_end = .;*/
  .stack ALIGN(4) :
  	_stack = .;
  	. += 4;
  	. += 4;
  	_abort_stack = .;
  	. += 4;
	_fiq_stack = .;
	. += 4;
	_svc_stack = .;
	. += 1024;
	_usr_stack = .;
	. += 1024;
	_irq_stack = .;
	_estack = .;
  } > SRAM
  _end = . ;
  PROVIDE (end = .);
  /* DWARF 1 */
  /* DWARF 2 */
Re: .ld for 2148
The tutorial I linked to earlier has a complete 2148 linker script
including extensive documentation.
Richard
2005-12-30 by Rob Jansen
Work ?
What is an lpc2148 .ld file different from a 2106 or other version?
It's just the amount of RAM/Flash that is different.
Adapting your lpc2106 (or other) .ld file is maybe the easiest thing to do.
I do have .ld files for all lpc21xx types delivered on CD with my Embedded
Artists boards and the only differences are in RAM/Flash settings.
I am starting to like these quickstart boards more and more.
With the boards all kinds of programming examples and a complete
development system are delivered on CD - no need to go searching for all
these examples on how to use watchdog, uart, i2c or other peripherals ...
Rob
Re: .ld for 2148
2005-12-30 by paloalgodon
Thanks all!  I feel alot more comfortable jumping in with all the
help.  ~Steve
2005-12-30 by Marko Panger
I'm just re-sending this as it seems that it didn't arrived the first
time. See below.
marko
Hi !
Hope it helps !
marko,
>Steve
>Yahoo! Groups Links
ENTRY(_start)
STACK_SIZE = 0x400;
MEMORY
SECTIONS
  	.text :
		*crt0.o (.text)
    	*(.rodata*)
    	*(.glue_7)
    	*(.glue_7t)
  	} > FLASH
	. = ALIGN(4);
	_etext = . ;
  .data  : AT (_etext)
    _data = .;
    *(.data)
    . = ALIGN(4);
    _edata = .;
  } > SRAM
  .bss (NOLOAD) :
    _bss = . ;
    *(.bss)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;
  } > SRAM
/*  	*(.data_heap)*/
/*  } > SRAM**/
  /*. += 0x4000;*/
/*  _heap_end = .;*/
  .stack ALIGN(4) :
  	_stack = .;
  	. += 4;
  	. += 4;
  	_abort_stack = .;
  	. += 4;
	_fiq_stack = .;
	. += 4;
	_svc_stack = .;
	. += 1024;
	_usr_stack = .;
	. += 1024;
	_irq_stack = .;
	_estack = .;
  } > SRAM
  _end = . ;
  PROVIDE (end = .);
  /* DWARF 1 */
  /* DWARF 2 */
ENTRY(_start)
STACK_SIZE = 0x400;
MEMORY
SECTIONS
  	.text :
		crt0.o (.vectors)
		*(.fiqisr)
		crt0.o (.text)
    	*(.rodata*)
    	*(.glue_7)
    	*(.glue_7t)
  	} > FLASH
	. = ALIGN(4);
	_etext = . ;
  .data  : AT (_etext)
    _data = .;
    *(.data)
    . = ALIGN(4);
    _edata = .;
  } > SRAM
  .bss (NOLOAD) :
    _bss = . ;
    *(.bss)
    *(COMMON)
    . = ALIGN(4);
    _ebss = .;
  } > SRAM
/*  	*(.data_heap)*/
/*  } > SRAM**/
  /*. += 0x4000;*/
/*  _heap_end = .;*/
  .stack ALIGN(4) :
  	_stack = .;
  	. += 4;
  	. += 4;
  	_abort_stack = .;
  	. += 4;
	_fiq_stack = .;
	. += 4;
	_svc_stack = .;
	. += 1024;
	_usr_stack = .;
	. += 1024;
	_irq_stack = .;
	_estack = .;
  } > SRAM
  _end = . ;
  PROVIDE (end = .);
  /* DWARF 1 */
  /* DWARF 2 */
2005-12-30 by Tom Walsh
Linker script files (.ld) are unique to the development environment:
compiler, libraries, etc.  They are not peculiar to the processor
flavor, therefore you can take a LPC21xx, LPC22xx, LPC23xx, or whatever,
make a few changes to the top of the file where the MEMORY SIZEs are,
and use them.
The scripts essentially describe where to put what.  And before I get
flamed, yes, there are slightly different arrangements of memory between
the LPC products where an external memory bus is available..
The files are not hard to read, if you are on Linux: 'info ld' and look
at the "scripts" menu entry.  If you are Cygwin, well..., YMMV.
Embedded programming is an acquired skill / art-form, not a turnkey
operation.
Reminds me of "... teach a man how to fish ...".
TomW
Re: .ld for 2148
2005-12-30 by derbaier
> Regards,
> TomW
Well, you just made my day!!!    <G>    :-)
-- Dave
