Lpc2000
Soldering LPC2148
Soldering LPC2148
2005-12-30 by bigakisgr
I have a couple of LPC2148, thanks to EXCELLENT Phillips sample program.
I don't want to build a specific project right now, so i prefer to
solder them to a generic proto-board, and use this board to experiment.
Searching on the net, i found SchmartBoards (http://www.schmartboard.com/)
They say that even a 10-year old can solder a .5mm QFP.
Have anyone of you tried SchmartBoards, or have a better advice?
Thank you and happy new year.
Akis
Re: [lpc2000] Soldering LPC2148
2005-12-30 by Sean
Those look pretty neat and easy, but really it's not a tough task soldering
.5mm QFP on your own.  For any surface mount components it's extremely
useful to have a nice binocular microscope, around the 7x magnification
range.  One on a boom is much better.  Once you have that, it's pretty easy
to do all SM work, check for shorts, etc.  Even without it's not terribly
difficult, but you'll need some sort of magnifying glass to at least check
the work.  Placement isn't difficult either, especially once you've done a
few and know the tricks.  I'd probably say that 99% of all experienced
electrical engineers CAN solder 0.5mm QFP on their own, not the other way
around.
Considering how you can get a prototype double sided board made for like
$30 USD (roughly 4"x6" in size), you may be better off designing a module
yourself with all required supporting circuitry (osc, regulators, caps,
rs232, usb, etc) that can be reused for multiple projects, you can likely
get 4 modules out of a single 4"x6" sheet.  Just a thought.
-- Sean
>(<http://www.schmartboard.com/)>http://www.schmartboard.com/)
2005-12-30 by Tom Walsh
>around.
I agree, you can hand solder 0.5mm but it is tough to keep from getting
solder bridges between pins, or the absolute worst is when you get a
bridge "behind" a pair of pins!
I'd done handsolder down to 0.8mm, then hot-air pencil + syringe paste
applicator at 0.5mm.  This is with a commerially made board with a
solder mask.  What I use now is a toaster oven and mylar stencil (thanks
to SparkFun!).  It is the absolute easiest way I've found to build SMD
boards!
My current board has 140+ SMD components on it, ranging from 0805, to
SSOP, to 0.5mm TSSOP / QFP.  It only took 2hours to setup, paste, apply
parts and reflow using the stencil + oven.  I would not think to attempt
a board as complex as this (and as small) by hand, you always get too
much paste or it won't flow right and it bridges...
I use Advanced Circuits (http://4pcb.com), check out their $33 special:
full silkscreen, paste / solder mask, and resolution down to 7mil.
After many years of etching my own boards, I let someone else do the
dirty work.  :P
Myself, I'd be very leary of the claims that the Schmart Board people
make.  Soldering SMD _is_ a PITA.  BTW, I do have a 10X / 20X binocular
microscope, 20X makes it possible to solder jumper wires to the 0.5mm
pins (now, if my hands would only stop shaking).
TomW
2005-12-30 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Friday, December 30, 2005 10:07 PM
Subject: [lpc2000] Soldering LPC2148
Drag soldering works very well for fine-pitch devices. I use a Metcal system
with a special mini-hoof tip, it just takes a few seconds.
Leon
RE: [lpc2000] Soldering LPC2148
2005-12-30 by Joel Winarske
Use a de-soldering braid to remove any excess solder, and depending on the
type of solder you use don't be shy with the liquid flux.
Joel
2005-12-30 by Don Ingram
If you run with Leon's suggestion this is not an issue.  Most of the
manufacturers have drag tips & with a bit of practice these make .5mm QFP's a
doddle.  There is a video on the net somewhere, google should find it.  The
other good suggestion was the bino microscope.  With these two smd is a non-issue.
Don
> Joel
Cheers
Don Ingram
Leading Edge Design
Mob:   +61 4 1877 5670
Ph :   +61 7 4942 5670
SIP: 899 060 4942 5670
Fax:   +61 7 4942 5680
23 Daniel St
North Mackay
QLD 4740
Australia
P.O. Box 10326
Mt Pleasant
QLD 4740
Australia
2005-12-31 by Joel Winarske
> QFP's a
> The
> non-issue.
My paste solder experience is somewhat limited, though I have 20 years
experience with the core solder.  I'll look into the drag technique.
Joel
I just watched a "drag soldering" instructional video.  It involved applying
liquid flux to the unsoldered joints, then taking a smaller chisel style
tip, applying some core solder and dragging the iron across the pins.
Nothing I haven't done before, now it just has a name.
> QFP's a
> The
> non-issue.
Re: Soldering LPC2148
2005-12-31 by deliconn
I always wanted to try SMD for the longest time but was always afraid
to even attempt it.  I knew there was no way I would be able to hand
solder them, and the whole solder paste and toaster oven thing just
seemed like such a hassle.  Then I took a contract job with a small
robotics company and my preconceptions were smashed.
They had a technician there that could solder fine pitch packages in a
few seconds.  Half of that time was lining the package up, the second
half was soldering.  I couldnt believe it, he was so fast, and he was
using tools that I already had.  He was like a machine.
I spent about 30 minutes with him and he showed me the tricks.  Its
simple. I will try and talk you through the steps I use.
Before you even start, you have to have a couple tools.  Most people
need some sort of magnification.  I cant afford a nice binocular
setup, so I just use one of those lenses that is on an arm and you
swing it down in front of you. Something like this,
http://www.hmcelectronics.com/cgi-bin/scripts/product/9360-0008/.
This one is expensive, but if you go to a sewing shop or a hobby shop
you should be able to find one much cheaper.  The next thing you need
is a fine soldering tip, hoof tips are not necessary.  I use a bent
.016" tip from Weller.  You will also need solder, not the kind you
get at Radio Shack.  Radio Shack's solder is way to thick and you
always end up using much more than you need.  I use
http://www.hmcelectronics.com/cgi-bin/scripts/product/4800-0061/.  Its
.025" diameter with a water soluble flux core.  Next is flux.  You
will DEFINITELY need flux.  Flux is the only reason you will be able
to solder these packages.  I use a flux that matches the properties of
my solder,
http://www.hmcelectronics.com/cgi-bin/scripts/product/4800-0032/.  You
dont have to buy it by the gallon, so its not as expensive as it
seems.  The solder and flux are organic water soluble substances, so
after you do all your work, you have to wash the board off.  I just
run it under warm water and use a mild dish soap.
Now you are ready to start.  First step is clean your board to get rid
of any oils.  I just wipe it down with alcohol.  Then place your part,
just work each side a little at a time and before you know it, it will
be lined up on the pads.  I found that using some fine tipped curved
tweezers really makes it easier.  I just push the pins ever so gently.
 Now hose the part down with flux, dont be afraid, you cant use too
much (please use proper ventilation, solders and fluxes contain
poisons).  With a clean soldering iron tip gently press the solder to
the tip and transfer as little as you possibly can.  If you do too
much, just clean your iron and do it again.  Now just place the iron
tip on some pins, careful not to move the package and do not worry
about bridging the pins.  You are only trying to anchor the part, dont
try to spread the solder.  Repeat the process for some pins on the
other side of the package.  Now your part is firmly planted to the
board in the correct location.
Its easy now, just put a tiny bit of solder on your iron and run it
along the a row of pins.  Dont worry about bridging.  You will see the
the solder will follow your iron up and down the pins, gently coating
the pins with solder, its like magic.  If the solder is not following
your iron, you need more flux; throw some on.  Until you learn how
much solder to put on your iron, you are going to have too much and
you are going to have pins bridged.  Relax, its no big deal.  Just
clean your iron, add more flux if you need it and run the tip up and
down the row again.  Repeat this, clean and run step, a couple times
and you will have picked up the excess solder.  Now, to fix the
bridges, just gently swipe the pins quickly with the iron in an
outward motion, away from the package.  Start at the package and move
to the tips of the pins.  Dont run the iron up and down the pins like
before, the motion you want is perpendicular to that.  Now, it should
only take a couple times to remove the bridges.  If its not working,
you still have too much solder.  Clean your iron, add flux and get rid
of some solder like described earlier.
Do that for each row of pins on your package and your done.  Wash the
board and Bobs your uncle.  You are now an expert and you can take
your hobbying to a whole new level.  Bonus, you can charge your
friends a couple bucks to assemble for them.
It sounds much worse than it is.  You only need to see it once to
realize how easy it truly is.  If you are going to do this kind of
work I would recommend a hot air station.  Its technically not
necessary, but it will save you a bunch of headaches and time when you
solder the part on backwards or whatever other boneheaded mistake you
make.  They really arent that expensive anymore, you can pick up some
pretty cheap knock offs.  Heres on for $130, its Hakko knock off,
http://www.madelltech.com/M3-4.html.  There are cheaper ones out there.
As far as buying carriers boards to mount chips, I would recommend
making your own.  Use www.BatchPCB.com to order your very low run PCBs
(read: 1 or 2 boards), its run by the guys from sparkfun.com.  They
charge $2.50 sq/in with a $10 setup fee.  So you could make your
LPC2148 carrier board for half the price and you could even add room
for supporting components.
If none of this makes sense let me know I will try to do a better job.
 Hope it helps someone.
Vern
Re: [lpc2000] Re: Soldering LPC2148
2005-12-31 by Don Ingram
No offence intended but the reason why we use concave tips is precisely to avoid
the following...
Repeatedly re-heating the joint to do clean up tasks alters the alloy mix and
creates embrittlement in the joint which later may lead to joint failure.  The
concave tip is a single pass process, no solder clean-up, no reheating. General
rule is to hit it once & that's it, don't be tempted to go back over it again
The joints may look prettier but will in all likelihood be far weaker.
Generally any tip which has thermal mass greater than the joint will attract
solder away from the joint leaving an optimal fillet, some people prefer flat
blades which cover a few pins at a time e.g. is heating a new pin while drawing
across middle pins and snapping the fillet away from the trailing pin.
Cheers
Don
2005-12-31 by mahbub1833
I am using schmartboard for last 2 months and its technology is a bit
interesting. You can make a full prototype board joining their 2"x2"
boards all together. Although it is easy and smooth technology; but it
would be a bit expensive from the soldering view.
I am a student and don't wish to let the $s go away for prototyping.
So, I use adhesive method (no soldering) to join my chips on
schmartboard. In this case I don't have to worry about short circuit,
painful soldering process (at least to me), chip wastage etc.
And it works great.
So, from adhesive view schmartboard is cheaper than other proto
systems.
Thanks.
program.
experiment.
schmartboard.com/)
> Akis
precisely to avoid
None taken, I didnt mention it to directly counter the hoof tip
statement in that way.  I meant it in that, to do the job, you dont
need to spend a lot of money on new equipment.  Many soldering
irons/stations dont offer hoof tips, mine included.
Your point is well taken about heating joints multiple times.  I will
have to try a blade tip and see how well it works.  Although I have
gotten very good with my round bent tip, which may work in a very
similar manor to the blade.  Once you do a couple and learn your
tools, it becomes less and less necessary to reheat joints.
I made a comment at the end of my post about hobbying.  I should have
been more clear.  I would never and have never assembled production
units in this manor, and would recommend the same to anyone.  That
said, it works great for prototypes and proof of concept work, or just
hobbying around.
Thanks for setting me straight Don,
Vern
2006-01-02 by Ake Hedman, eurosource
What oven do you have?
/Ake
I have been looking for a source for syringes for solder paste. Where do
people buy theese?
/Ake
2006-01-02 by Leon Heller
Sent: Monday, January 02, 2006 9:16 AM
Subject: Re: [lpc2000] Soldering LPC2148
> people buy theese?
You can buy solder paste in syringes, complete with needle. I recently got
some from Warton Metals:
http://www.warton-metals.co.uk/
Leon
Leon Heller wrote:
> From: "Ake Hedman, eurosource" <akhe@...>
> > people buy theese?
> got
> Leon
Thanks Leon,  I should have written with needle. This company seam to
have what I am looking for.
/Ake
2006-01-02 by Marko Pavlin (home)
Check AOYUE\ufffd:
http://shop.wiltec.info/
2006-01-02 by Peter Harrison
How do you create and use the stencils?
Pete Harrison
2006-01-02 by Tom Walsh
Oster model 6293, $69 at Target.  It is a 1500W, four element,
convection oven.  The convection fan appears to gently circulate the air
rather than stir it.  Temperature dial shows Fahrenhiet and Celsius.
When you put the oven on the BAKE position, it energizes all 4 elements.
TomW
Best for you to do is goto the sparkfun article:
http://www.sparkfun.com/tutorial/SMD_Printing/SMD_Printing.htm
The folks at pololu.com do a fine job on the stencils.
TomW
>people buy theese?
I also use these:
http://www.zeph.com/pencil.html
http://www.zeph.com/zephpaste.htm
http://www.zeph.com/zt5_dir.htm
It is nice to use the pnuematic paste applicator, it is great for
rework.  Your hands can get very tired (not fooling you), trying to
force that paste out a tiny needle!
For building the board, a paste stencil + toaster oven is definately the
way to go!
TomW
2006-01-02 by Rock Dubois
you can buy at stores that sells food and other merchandise for larger animals
  like horses and others or veterinary supplies at very low cost.
  Good luck.
  Yvon.
people buy theese?
/Ake
  SPONSORED LINKS
        Microprocessor   Microcontrollers   Pic microcontrollers     8051 microprocessor
  YAHOO! GROUPS LINKS
 Yahoo! DSL Something to write home about. Just $16.99/mo. or less
> >people buy theese?
> I also use these:
> way to go!
> TomW
Tom thanks!
A dispenser would be good to have.
I use a pre-heater today
(http://www.aoyue.de/en/Aoyue_853a_quarz_infrared_preheater_smd_rework_repair_desoldering.htm)
and it works fine for small cards following a temperature profile manually.
An oven would be nice to have though for larger boards and smaller
series. I have tried to find one with a fan in Sweden but not found a
suitable one yet. Instead I am thinking about rebuilding one and putting
in quarts IR elements and control logic to get faster ramp up then it
has standard. As always time is my enemy... ;-)
/Ake
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavagen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 0533 146
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
> animals
>   Good luck.
>   Yvon.
Hi Yvon,
never though about that source. Checked one supplier here in Sweden and
found that I need a paper from a vet. to be allowed to buy them. Have to
check that I guess.
Thanks!
/Ake
Sent: Monday, January 02, 2006 4:48 PM
>> >people buy theese?
>> I also use these:
>> way to go!
>> TomW
> Tom thanks!
> manually.
The Jan 2006 issue of Elektor has a design for temperature controlled
toaster oven. I bought one before Xmas from Argos for just under 20 GBP, it
has two quartz elements on top and two underneath.
Leon
Leon Heller wrote:
>----- Original Message -----
>>>>people buy theese?
>>>I also use these:
>>>way to go!
>>>TomW
>>Tom thanks!
>>manually.
Actually, I don't use any temperature control other than what is in the
Oster oven.  I don't know if the dial is calibrated, but it works.  The
oven does have the quartz elements, major reason that I purchased it,
and I follow a:
1.5 minutes @ 125C (preheat)
1 minute @ 140C (staging)
1 minute @ 180C (reflow)
30 seconds into the 180C, the paste melts on the smaller parts and about
10 seconds the larger parts' paste melts.  I hold the heat for that
additional 10..20 seconds, then shut the oven off and crack open the
door to spill the heat.  Over the next minute, I slowly and gently,
fully open the door, slide the grille out to expose the PCB to ambient air.
After about 30 seconds in ambient, I use needle nose pliers to grasp the
board and remove it.   Meanwhile, I have a "slab" of aluminum waiting,
this is about 3/8" (100mm) thick, by 10" X 10" (25cm X 25cm).  I gently
slide the PCB onto the aluminum plate to suck the heat from the PCB.
What I have found is that you can leave the board in the heat for too
long.  I tried a preheat of 3.5 minutes and the resulting solder looked
like there may have been some embrittlement (under microscope), the
shorting the preheat time (to boil out water) results in shiny joints.
If you reference the article on Sparkfun, you'll note that they are
using SOP devices, fairly large.  They are manually holding the stencil
in place.  With a significantly sized TSSOP board, it is impossible to
maintain alignment! What I do is to "pin" the board in place by
surrounding it with like thickness PCB material.  Then carefully
position the stencil and tape it down.
I've found that the stencil will shift when you attempt to remove your
fingers from contact with it.  This problem is taken care of by some
small codiment dishes (about 2" dia - 50mm).
I do use a Madel stainless steel squeegee:
http://www.ntscope.com/Merchant2/merchant.mvc?Screen=PROD&Return_Screen=CTGY&Store_Code=MTC&Category_Code=TAM&Product_Code=SQG-15
That sqeegee is the only "high-tech" equipment used in the entire
process.  :-)
TomW
2006-01-02 by Don Ingram
The other thing to look at is the heat distribution in the oven, it might give
you a surprise...
Place a sheet of printer paper in the oven similar to your larger PCB panels and
do a bake run.  The pattern on the paper will give an indication of the effect
of the elements.
Generally the area around the edges will be pretty cold and the middle a bit
uneven due to the lag in heating the sidewalls & generally losses to ambient.
Attach some alfoil ( shiny side inwards ) to the edges of the oven rack so that
there is a bit of a gap ( 5mm or so ) between the alfoil & the side walls. Do
this at the front as well leaving a portion as a window.
  Cook another sheet of paper & you will be surprised at the much more even
heating pattern due to the decreased losses & the additional reflection from the
sidewalls.
Sunbeam have a AUD$150 oven with convection which gives reasonable results,
alternatively their AUD$60 fanless unit doesn't do too bad either. We used to
use an ABB multi-step PID controller that had ramp/soak time cycles attached to
a thermocouple fitted to a strip of PCB left permanently in the oven however
since then we have moved to a commercial SMD oven.
Cheers
Don
2006-01-03 by Ake Hedman, eurosource
> putting
> might give
> you a surprise...
> panels and
> the effect
> of the elements.
> a bit
> ambient.
> rack so that
> walls. Do
> even
> reflection from the
> sidewalls.
> results,
> used to
> attached to
> however
> Cheers
> Don
Thanks Don,
what do commercial ovens use? IR Quartz elements?
My though was to remove the standard hearing elements in a standard oven
and replace it with my own IR Quarts elements evenly space at the top to
get a more even heat distribution and a faster ramp up. Not certain if a
fan would be needed in a setup like this.
/Ake
> Where do
> >> >people buy theese?
> >> I also use these:
> definately the
> >> way to go!
> >> TomW
> > Tom thanks!
> <http://www.aoyue.de/en/Aoyue_853a_quarz_infrared_preheater_smd_rework_repair_desoldering.htm%29>
> > manually.
> GBP, it
> Leon
Its almost impossible to get small ovens here in Sweden. Can't
understand why!? And certainly not for 20 GBP....
/Ake
2006-01-03 by Leon Heller
Sent: Tuesday, January 03, 2006 9:36 AM
>> Where do
>> >> >people buy theese?
>> >> I also use these:
>> definately the
>> >> way to go!
>> >> TomW
>> > Tom thanks!
>> > manually.
>> > putting
>> GBP, it
>> Leon
Amazon sells them for about the same price:
http://www.amazon.co.uk/exec/obidos/ASIN/B0002HDMPG/qid=1136283104/sr=1-1/ref=sr_1_10_1/202-3374447-4278210
You might be able to get one from them.
The Elektor article recommends a much more exensive higher power oven, as it
will heat up much quicker (important for the required temperature profile)
but I'll see how I get on with the cheap one.
Leon
> as it
> profile)
> Leon
My usual luck. They don't ship to Sweden. Thanks anyway. Let us know
what you find out when you get around to test your oven..
/Ake
