Lpc2000
CAN bit timming vs RS232
2006-01-03 by r_goncalves2000
Hello,
This is my first message to this group but I read this group
with atention for some time.
I'm using an Olimex LPC-E2294 board with a cristal of 14.746.000Hz.
This gives perfect baud rate for RS232 but I can find a CAN bit timing
with no error for some usual bit timings like 125K, 250K, etc.
If I go to a 15MHz cristal I have perfect bit timimings in CAN but I
have a RS232 error of about 1.67%.
Is there a way to have no error in both RS232 and CAN baud rates?
If not what's the best choice for the cristal value?
I want to have both RS232 and CAN.
Thank you.
Rui
Re: [lpc2000] CAN bit timming vs RS232
2006-01-03 by dasbento@aeiou.pt
Hello Rui,
the boards TinyArm has a cristal of 12MHz. I think that work fine but
I not still tried the CAN.
Good work
            Domingos
Citando r_goncalves2000 <rpsgoncalves@...>:
> Hello,
> Thank you.
> Rui
_________________________________________________________
CEAC Cursos de forma\ufffd\ufffdo profissional - pe\ufffda informa\ufffd\ufffdes aqui.:
http://ceac.online.pt/
2006-01-03 by Martin Steppuhn
Hello Rui,
I 'am using the LPC2129 an there ist the same "problem".
You can fix it with the CAN setup by chosing a time quanta
with a low error in the CANBTR.
For 14,7456 MHz and 125k CAN Buadrate my settings for CANBTR are:
#define   CALC_BRP_43      0x0000002A
#define   CALC_SJW_1        0x00000000
#define   CALC_TSEG1_8    0x00070000
#define   CALC_TSEG2_2    0x00100000
#define   CANBitrate125k      CALC_BRP_43 | CALC_SJW_1 | CALC_TSEG1_8 |
CALC_TSEG2_2
Error:  -0,24%
You can find additional infos in:
http://www.hitex.co.uk/arm/lpc2000book/index.html
Best regards,
Martin
> Thank you.
> Rui
2006-01-03 by Ake Hedman, eurosource
Martin Steppuhn wrote:
> Hello Rui,
> CALC_TSEG2_2
> Error:  -0,24%
> Best regards,
> Martin
With en error less then 1% there should be no problem for CAN.
Cheers
/Ake
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavagen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 0533 146
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
Re: CAN bit timming vs RS232
Hello guys and thank you very much for your fast answers.
I'm thinking in doing this.
 Use a 15MHz cristal.
 Use PLL to set cclk to 60MHz.
 Set VPDIV to define pclk to 60Mhz.
With this settings I have 0% error in defining the CAN baud rate
and a maximum of 1.72% error in RS-232 baud rate at 115.200.
At 19.200 I get 0.16% error. In this group I found that RS323
error should be less than 3% so I think I'm OK.
I think it's better to have no error in CAN than in RS-232.
In CAN if the cable is to long I get errors due to the baud
rate setting and errors do to the size of the cable.
Am I right? Any comments?
Martin:
Did you test your CAN settings over a large cable (500m)?
Did you test the CAN comunication between your ARM and another
equipment or with 2 ARM with the same settings?
Regards.
Rui
--- In lpc2000@yahoogroups.com, "Ake Hedman, eurosource" <akhe@b...>
> > Hello Rui,
CALC_TSEG1_8 |
> > CALC_TSEG2_2
> > Error:  -0,24%
> > Best regards,
> > Martin
> Cheers
> /Ake
Re: [lpc2000] Re: CAN bit timming vs RS232
If you are withing 1% for the CAN bit speed you will be alright. For
cable length adjust the sample point instead. Use 87.5% for instance to
be able to use the length specified for CANOpen
Cheers
/Ake
2006-01-04 by Martin Steppuhn
Hello Rui,
Ake write
I think so too.
Not yet, only a few meters.
At the moment I communicate with a CAN to USB Dongle and it worked perfect.
http://www.peak-system.com/db/gb/pcanusb_gb.html
Best regards,
Martin
> Martin:
> Regards.
> Rui
>> > Hello Rui,
> CALC_TSEG1_8 |
>> > CALC_TSEG2_2
>> > Error:  -0,24%
>> > Best regards,
>> > Martin
>> Cheers
>> /Ake
