Lpc2000
T and G commands
T and G commands
2006-01-11 by philips_apps
Hello all LPC2000 participants,
Here are some answers to the T and G command related questions that
have been asked on this forum recently.
T command
The T command was designed with the intention of expediting the
loading of data into the on-chip RAM during Philips in-house
testing. In essence, what the "W" command does in a serial fashion,
using UART0, the "T" command was supposed to do using a selected
group of GPIO pins.
The T command had to provide a one-way data transfer only (from the
testing environment into the LPC2000). Furthermore, the data width
was supposed to be either 8 or 16 bits and there was an option to
select handshaking or not.
When an LPC2000 device is put into a tester, we are capable of
controlling every single signal that stimulates the microcontroller,
and therefore a non-handshake based upload could be possible.
Knowing how many cycles it takes a portion of code to be executed,
we could provide the right data at the right time at the right pins
so that the "T" command would fetch them and store them into the RAM.
Since there are not to many environments as controllable as the one
described above outside of a semiconductor company manufacturing
and/or testing facilities, a simple handshake was designed: An
LPC2000 would wait for a high-to-low transition on a dedicated pin,
and when such event would be detected, it would fetch data from a
parallel port.
Issuing a "T" command means that in addition to 3 pins taken by the
ISP, additional 8/16 (byte/half-word transfer) or 9/17 (byte/half-
word transfer + handshake) would have to be used. It was our belief
that there would not be too many real-life applications that would
be willing to trade 8 to 17 pins for a GPIO functionality,
especially on smaller parts (48 and 64 pin packages).
It is clear that most of those customers that would decide to use
a "T" command could not live without a handshake. Unfortunately,
this feature was not working in some of the early releases of the
bootloader, and this was an additional reason why it was decided not
to promote this feature.
Bottom line: The "T" command was supposed to fetch data from
a "parallel" port and store it into on-chip RAM. It does not execute
a single piece of code on its own. Even if a code is successfully
loaded into the on-chip RAM using this command, a "G" command has to
be issued.
G command with "tEsT" argument
The "tEsT" argument was meant to be used by Philips testing
facilities so that a special test/piece of code residing in the
bootloader can be called/executed. In reality it turned out that
almost 100 tests (small applications) have to be loaded into every
single device when testing it, in order to verify its functionality
and say it is "OK". These tests are not carved in stone because we
keep updating and refining them. Therefore, although it was intended
at one point in time, we could not store all these patterns into the
bootloader. This is why no meaningful code can be accessed using
the "tEsT" argument in the current version of the bootloader.
Philips Apps Team
Re: T and G commands
2006-01-11 by jayasooriah
Dear philips_apps,
I am very pleased that you have finally chosen to repsond to two of
the three core issues I raised in this forum.
I am anxiously awaiting confirmation of third issue relating to CSI
vulnerability.
Arising from explanation of T and 'tEsT' arguments, please clarify:
1/  if the T command disabled when CEP is enabled;
2/  if it is corect to say that what happpens to the boot sector code
is indetermine should any user enter "G tEsT A" or "G tEsT T"; and
3/  if you knew about these when you posted the "CRP Update" message.
Thank you.
Jaya
> T command
> group of GPIO pins.
> parallel port.
> be issued.
> Regards,
> Philips Apps Team
2006-01-12 by philips_apps
Dear Jayasooriah,
The "T" command is disabled when CRP is enabled.
Though the "G tEsT A" or "G tEsT T" commands were mentioned in the
earlier revisions of the User Manual's we realized that they do not
help the application in any way. Hence we skipped their descriptions
in the later revisions. These commands were solely meant for Philips
testing facilities.
The way the bootloader has been implemented so far will lead a
customer using either "T" or "G tEsT" command to a dead-end. Having
commands designed for in-house use only, together with reasons
ranging from a command not being fully functional (T command lacking
synchronization capabilities in different versions of the
bootloader) all the way to not having a useful code at all ("G
tEsT"), it becomes obvious why the "T" and "G tEsT" commands are not
part of the latest releases of the LPC2000 documentation.
We hope these details will help you and all other LPC2000 users in
their current work and future designs with these microcontrollers.
Philips Apps Team
--- In lpc2000@yahoogroups.com, "jayasooriah" <jayasooriah@y...>
wrote:
> Dear philips_apps,
> vulnerability.
code
message.
> Thank you.
> Jaya
that
> > T command
2006-01-14 by jayasooriah
Dear philips_apps,
While I very appreciative that you have responded, I note you have
chosen to do this selectively.
You have not to address CSI vulnerability when "U 0 0 0 0 0" yet
again.  The inference is that it exists.  Also, the T command does
work on 1.52 version of the loader and I am not sure why you say it
does not.
Nontheless, as the T command and the 'tEsT' argument serve no useful
purpose, a very positive outcome of the discussion so far would be the
removal of these two features from the boot loader itself, not just
its documentation.
When I get back from my holidays (in about three weeks), I will
explain the why I am making this request, in the context of CRP security.
Thanks again for responding.
Kind regards,
Jaya
> Dear Jayasooriah,
> testing facilities.
> Regards,
> Philips Apps Team
