Lpc2000
Problem with VCOM PC PLPU-S2K driver
2006-01-12 by arrek_x
Hi everybody,
I'm trying to run VCOM USB driver on LPC2148. Device is being detected
by PC but an error occurs and it's not possible to install PC driver.
After the first detection device is not detected again (after
unplugging and plugging USB cable).
But it's not main problem. After installing driver PLPU-S2K manually
on my PC (Windows 2000) it is simply reseted and is not able to run
again. I get  error "STOP: 0x0000001E ...
KMODE_EXCEPTION_NOT_HANDLED". To run my PC again I have to remove
PLPU-S2K driver.
What could be the reason?
Arek
Re: [lpc2000] Problem with VCOM PC PLPU-S2K driver
2006-01-13 by Tom Walsh
arrek_x wrote:
>Hi everybody,
>PLPU-S2K driver.
MicroSoft Windows?
Re: Problem with VCOM PC PLPU-S2K driver
2006-01-13 by arrek_x
--- In lpc2000@yahoogroups.com, Tom Walsh <tom@o...> wrote:
> MicroSoft Windows?
Yes, I did not see driver for any other system prepared by Philips ;).
Well, I see you dont'l like M$ Windows (I'm not suprised :) ) but my
question was serious. I know that one man has run it under Win98 but,
as he says, it works generally not well. People wrote here that they
have problems with compilation firmware under ARM-GCC byt didn't tell
anything about problems with PC drivers.
So if anyone run this under Windows2000 (successfully or not) please
share your experirnce.
I solved the problem and driver started working - it was an electrical
problem (Windows was not a reason ;) ). Sorry for taking your time.
greetings
2006-03-08 by MAIA
I´m using LPC2148 to convert USB-RS232.
My hardware is ok. But, I don´t know how to install PLPU-S2K driver.
Could You give to me the steps to install this driver on Windows XP ?
Like a tutorial ?
Maia.
electrical
> greetings
2006-03-08 by MAIA
Like a tutorial ?
Maia.
electrical
> greetings
2006-03-08 by philips_apps
Program the flash,
unplug and replug the USB cable,
Window Plug-and-play device manager
will pop out and ask for installation info.,
choose "install from a specific location",
goto "VCOMHostDrv/PLPU-S2K",
click OK,
once it look for a PLP2US.sys file,
it's under "objchk_w2k_x86/i386" directory,
click OK again to install the sys file.
There are two COM ports in the host driver,
so you will be asked twice to install both
COM ports on.
Philips App.
driver.
XP ?
> Like a tutorial ?
> Thanks,
> Maia.
> electrical
time.
> > greetings
2006-03-08 by MAIA
I did that !!
But after that, it shows a message that unrecognize my Hardware.
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@...>
wrote:
> Program the flash,
> click OK,
> COM ports on.
> Philips App.
> driver.
> XP ?
> > Like a tutorial ?
> > Thanks,
> > Maia.
> > electrical
> time.
> > > greetings
2006-03-08 by MAIA
I did that !!
wrote:
> Program the flash,
> click OK,
> COM ports on.
> Philips App.
> driver.
> XP ?
> > Like a tutorial ?
> > Thanks,
> > Maia.
> > electrical
> time.
> > > greetings
Without enough description of your problem, here are a few things
you can try:
(1) Try something you know is working first, e.g. USB HID examples
from Keil.
(2) After programming the flash, unplug the JTAG connector,
then reboot the board again.
(3) Maybe, the host driver is in a unknown state, uninstalled
the host driver, reboot the board, it'll ask for the driver
again. You use the steps I described in the previous msg.
to reinstall.
(4) Reboot the PC.
(5) Check the board jumper setting.
Philips Apps
> I did that !!
> --- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@>
> wrote:
> > Program the flash,
> > click OK,
> > COM ports on.
> > Philips App.
> > driver.
Windows
> > XP ?
> > > Like a tutorial ?
> > > Thanks,
> > > Maia.
> > > electrical
your
> > time.
> > > > greetings
2006-03-09 by MAIA
in PLP2KUS.INF is writen as described below
[Manufacturer]
%Philips%=MRI
[MRI]
%PhilipsUSBSerial%=Philips.Install,USB\VID_C251&PID_1305&MI_00
%PhilipsUSBSerial%=Philips.Install,USB\VID_C251&PID_1305&MI_01
in my firmware(LPC2148) is writen
0xc251 for ID (vendor), and
0x1305 for ID (Product).
Windows shows "unknow device"
I try to reinstall drive PLP2KUS.INF but the message saying no
information about my hardware appears.
I don´t know what to do.
Maia.
> you can try:
> from Keil.
> to reinstall.
> (4) Reboot the PC.
> Philips Apps
> > I did that !!
> > wrote:
> > > Program the flash,
> > > click OK,
> > > COM ports on.
> > > Philips App.
> > > driver.
> Windows
> > > XP ?
> > > > Like a tutorial ?
> > > > Thanks,
> > > > Maia.
> > > > electrical
> your
> > > time.
> > > > > greetings
2006-03-09 by philips_apps
Maia,
    I suspect that your firmware is not running. Can you
reprogram the flash and use a known, good HID example to
test first?
    Yes, it's important that, your PID and VID should match
between these in the descriptor table of the firmware and
host driver INF file. The mismatch in the PID and VID area was
the only installtion issue people complained about long time
ago. Since then, I've not heard of any installation issues.
    Uninstall the VCOM drivers, have a clean start, once you
plug in the USB cable, the window device manager should pop out
automatically and ask for host driver info. If not, something
is wrong in the firmware already.
    A very effective way to debug the firmware is, add external
power +5V on VIN of the Keil MCB2140 board, program the flash,
start the debugger, set to run, unplug and replug the USB cable,
then you can single step to debug.
    Check the device manager, if there are some drivers installed
under "Others" area, check what they are, uninstall them,
minimize the number of USB connections first, just for testing
purposes.
    The two OS platforms we tested are W2K and XP. What's yours?
Tom
> [Manufacturer]
> %Philips%=MRI
> [MRI]
> Maia.
things
> > you can try:
examples
> > from Keil.
> > to reinstall.
> > (4) Reboot the PC.
> > Philips Apps
> > > I did that !!
Hardware.
> > > wrote:
> > > > Program the flash,
> > > > click OK,
> > > > COM ports on.
> > > > Philips App.
S2K
> > > > driver.
> > Windows
> > > > XP ?
> > > > > Like a tutorial ?
> > > > > Thanks,
> > > > > Maia.
an
> > > > > electrical
> > your
> > > > time.
> > > > > > greetings
Re: [lpc2000] Re: Problem with VCOM PC PLPU-S2K driver
2006-03-12 by Herivaldo Maia
Hi Tom,
  My hardware is so strange !
  In anex the schematic in pdf.
  Five times in hundred of tries, it works.
  I could install the driver and using Hyperterminal I could transmit/receive by virtual com serial (COM3 was used).
  At most time the hardware is not recognize. And sometimes it works !.
  What is happening ?
  When the hardware is working if it´s not unplugged, it´s work indefinitely. But, after unplugged, it doesn´t work after re-plugged.
  thanks,
  Maia.
philips_apps <philips_apps@...> escreveu:
  Maia,
test first?
purposes.
Tom
> [Manufacturer]
> %Philips%=MRI
> [MRI]
> Maia.
things
> > you can try:
examples
> > from Keil.
> > to reinstall.
> > (4) Reboot the PC.
> > Philips Apps
> > > I did that !!
Hardware.
> > > wrote:
> > > > Program the flash,
> > > > click OK,
> > > > COM ports on.
> > > > Philips App.
S2K
> > > > driver.
> > Windows
> > > > XP ?
> > > > > Like a tutorial ?
> > > > > Thanks,
> > > > > Maia.
an
> > > > > electrical
> > your
> > > > time.
> > > > > > greetings
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors     Pic microcontrollers
  YAHOO! GROUPS LINKS
 Yahoo! Acesso Grátis
Internet rápida e grátis. Instale o discador agora!
2006-03-13 by Herivaldo Maia
Sorry Tom,
  The right schematic is in JPEG anex.
  Hi Tom,
  What is happening ?
  thanks,
  Maia.
  Maia,
test first?
purposes.
Tom
> [Manufacturer]
> %Philips%=MRI
> [MRI]
> Maia.
things
> > you can try:
examples
> > from Keil.
> > to reinstall.
> > (4) Reboot the PC.
> > Philips Apps
> > > I did that !!
Hardware.
> > > wrote:
> > > > Program the flash,
> > > > click OK,
> > > > COM ports on.
> > > > Philips App.
S2K
> > > > driver.
> > Windows
> > > > XP ?
> > > > > Like a tutorial ?
> > > > > Thanks,
> > > > > Maia.
an
> > > > > electrical
> > your
> > > > time.
> > > > > > greetings
  SPONSORED LINKS
  YAHOO! GROUPS LINKS
2006-03-13 by Dezheng Tang
The Keil's board doesn't support soft connect,
you need to add extra H/W logic to make it work.
Go to Keil's website, these is an app-note about that.
I also suggest that you fix the VBUS issue mentioned
on Keil's website.
After adding soft connect logic, to test unplug and
unplug, I also suggest that you use external power
on the board.
regards,
Philips app.
--- In lpc2000@yahoogroups.com, Herivaldo Maia <maiatec2005@...>
wrote:
> Hi Tom,
works !.
>   What is happening ?
>   thanks,
>   Maia.
>   Maia,
> test first?
> purposes.
> Regards,
> Tom
> > [Manufacturer]
> > %Philips%=MRI
> > [MRI]
> > Maia.
> things
> > > you can try:
> examples
> > > from Keil.
> > > to reinstall.
> > > (4) Reboot the PC.
> > > Philips Apps
> > > > I did that !!
> Hardware.
<philips_apps@>
> > > > wrote:
> > > > > Program the flash,
> > > > > click OK,
> > > > > COM ports on.
> > > > > Philips App.
> S2K
> > > > > driver.
> > > Windows
> > > > > XP ?
> > > > > > Like a tutorial ?
> > > > > > Thanks,
> > > > > > Maia.
was
> an
> > > > > > electrical
taking
> > > your
> > > > > time.
> > > > > > > greetings
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
