Lpc2000
PWM width detection
PWM width detection
2006-02-18 by hdxlh74
Does anyone have any code examples of how I can use a LPC2138 to detect
the width of the positive pulse in a PWM signal. I know I can use the
timer circuit and detect the rising and falling edges do some math and
determine the width. I am very new to micro controllers and some code
examples or guidance would be greatly appreciated.
Thanks
J Parham
RE: [lpc2000] PWM width detection
2006-02-18 by Joel Winarske
Hi J,
For some theory take a look at this Atmel application note:
AVR135: Using Timer Capture to Measure PWM Duty Cycle   (12 pages, revision
A, updated 10/05)
Found here: http://www.atmel.com/dyn/products/app_notes.asp?family_id=607
As for the LPC2100 you would use the Capture feature of the Timer
peripheral.  Setup timer to generate an interrupt on capture pin leading or
trailing edge.  In the interrupt routine read the capture register value and
pass it on to your algorithm.
Be sure to read the correct section of the errata sheet related to TIMER.
Joel
Re: [lpc2000] Re: PWM width detection
2006-02-18 by Onestone
The 'standard' way to do this is to use 1 pin. ISR latency on slow small
micros is usually more than fast enough. On an LPC it should be a shoe
in. 1 instruction cycle to flip the bit sense. How hard can it be. A
typical ISR to measure pulse width on most micros requires fewer than 10
instructions. Your final sentence may be true, but this is the case in
99% of applications, and is certainly true in your case, even with the
comparatively poor interrupt latency of the LPC2xxx. On the odd
occasions where the pulses are too fast I would suggest that using two
pins is a poor solution anyway, since the resolution of meaurement will
only be typically 2-4 bits at most, and other solutions would offer a
better result.
Cheers
Al
Ryan Niemi wrote:
>I recently implemented pulse width measurement on an LPC2124 to detect
>the width of pulses from an R/C radio receiver (varies between 1ms and
>2ms positive-going pulse width) for a theatrical motion control and
>lighting control project.  There's an interesting shortcoming that I
>encountered, each capture pin can only capture a rising or falling
>edge, but not both.  So to measure pulse width, I found it necessary
>to use *two* capture pins tied together, one to capture the rising
>edge and another to capture the falling edge.  The main loop of the
>program compares the two, and if the count on the falling edge capture
>is larger than the count on the rising edge capture, then pulse_width
>= falling_edge_capture - rising_edge_capture.
>The Hitex book includes an example whose description says it measures
>a pulse width, but the example shown (using one capture pin) very
>clearly does not measure pulse width and is incomplete, and merely
>measures the time between pulses (but not the pulse width).  Now my
>curiosity is had, has anyone succeeded in measuring pulse widths
>without using multiple capture pins?  From the way the LPC capture
>units are set up, I doubt it's possible, short of flipping the capture
>edge polarity in an ISR.  ISR-based solutions are only really useful
>if the pulse width is larger than the execution time of the ISR + any
>interrupt latency due to other ISR's executing at the time.
>-Ryan
>--- In lpc2000@yahoogroups.com, "Joel Winarske" <joelw@...> wrote:
>>Hi J,
>detect
>revision
>>A, updated 10/05)
>>Found here:
>leading or
>value and
>TIMER.
>>Joel
>Yahoo! Groups Links
RE: [lpc2000] Re: PWM width detection
Yes.  I have a design using six capture inputs doing bit banged CAN bus on
the LPC214x.  Polarity is being conditionally flipped in ISR.  It's been
rock solid.
If IRQ latency is a problem, and timing permits you can always implement as
FIQ.
Joel
2006-02-19 by Joel Winarske
> rock solid.
I should mention it uses one capture pin per bus.
Joel
2006-02-20 by brendanmurphy37
Al,
You're right in most circumstances. However, anyone reading this
needs to be aware that the LPC2xxx parts, like many other 32-bit
micros with pipelined architectures and multiple (internal) buses,
are not quite as straightforward as previous generation micros. For
example, the "1 instruction cycle to flip the bit sense" you refer to
will actually take multiple clocks, due to the latency of the
peripheral bus.
Interrupt latency is also not straightforward to work out, as it will
include some or all of:
- delay to due to background software disabling interrupts
- variable instruction execution delay (ARM is not very "RISC" like
in this respect, due to extended instructions such as load multiple)
- variable hardware interrupt acknowledgement delay
- software delay in saving additional context and calling correct ISR
If your interrupt software isn't set up to handle nested interrupts,
there can be even longer delays.
I'm not suggesting you're incorrect or wrong in anything you say, but
it's important for anyone new to the parts to keep in mind all of the
above before implementing a particular solution. If you're happy that
after doing the analysis that the timing is OK, then fine. However,
don't skip the analysis, particularly if you're planning to respond
to "fast" events.
One thing you find is that it is very hard to guarantee to respond at
a very precise time after any interrupt: there is usually quite a bit
of jitter involved. In most cases, such as flipping the direction of
a capture i/p "somewhere" in an ISR this won't matter, but in others
it will.
Brendan
P.S. there's been plenty of posts to the forum on exact timings of
peripheral bus access and interrupt latencies: this is just a
reminder that they exist, rather than a repeat of the actual data
involved.
small
shoe
A
than 10
in
two
will
a
> better result.
> Cheers
> Al
2006-02-20 by Onestone
Hi brendan,  I am aware of the latencies with the LPC, especially the
over discussed slow I/O issues. I am also aware of the odd interrupt
latency issues (for a supposed RISC machine), but promoting them touse
the FIQ ISR helps resolve some of these issues. Knowing the exact isr
latency isn't really an issue in timer capture for pulse timing, as long
as the ISR is taken and completed before the next edge to be detected,
since the time of the event is stored, like time travel backwards, and,
since the post I responded to discussed 1ms/20ms remote control signals
ISR latency and single pin handling certainly wasn't going to be an
issue. I do appreciate that the LPC is not really a conventional
microcontroller, more like a microprocessor with the extra hardware
kludged into the same silicon.
Thansk for the reminders though
Al
brendanmurphy37 wrote:
>Al,
>peripheral bus.
>to "fast" events.
>it will.
>Brendan
>involved.
>small
>shoe
>A
>than 10
>in
>the
>two
>will
>a
>>better result.
>>Cheers
>>Al
>Yahoo! Groups Links
If the signal is too fast to be captured by a single capture pin, using
the edge flipping method, then it is occuring faster than the capture
ISR can execute, and reservice itself.  Assuming that the ISR is well
written, executes in the absolute minimum possible time, ie no calls ,
no massive processing in the ISR, then the pulse  is obviously very
short. having one edge captured by pinA and the other by pin B won't
change this, in fact the nett time to execute and service the two
routines will be shorter, typically, than the nett  time to service a
single bit flipping routine, and the pulse, depending upon the processor
of course, will typically be only a few counts long,  thus a few bits of
resolution, and a limited dynamic range. In this case other methods
would perform the task better.
With respect to noise in the system, this is where I believe system
design enters the picture. In this case if the time is taken to learn
the system before ever laying down hardware or software, and the
vagaries of the signals are studied and understood first, not discovered
to be a problem later, as seems to be the more common event, then they
can be first of all minimised during the hardware design, then perhaps
compensated for during the software design with signal or logical
filters, or a combination.
Cheers
Al
Ryan Niemi wrote:
>Hi Al,
>Why would the capture resolution using two capture pins only be 2-4
>bits at most?
>One note on using an ISR for flipping the capture edge, this works
>fine if the signal you're capturing is not noisy..  Determinism in
>hard-realtime systems goes away anytime interrupts can be triggered by
>external noise.
>-Ryan
>small
>than 10
>>better result.
>>Cheers
>>Al
>>>-Ryan
>Yahoo! Groups Links
A little confuse about CRP
2006-03-10 by Xtian Xultz
I am a little confused about CRP.
I am working with LPC2106. That chip have or havent CRP? I read somewhere that
CRP is on LPC2106 after some version, thats true or LPC2106 do not have CRP
at all?
Is there a way to protect my firmware agains piracy or my firmware will
allways be open to anyone read it?
Thanx a lot for any reply!
Use of external reset supervisor chips
2006-03-10 by Andrew Berney
Hi all,
We're currently in the process of putting together a device that will be
powered via an induction ring and as such there is the potential for the
device to lose sufficient power intermittantly.
I was wondering on peoples' general opinion of using an external supervisor
chip to ensure a clean startup by keeping reset pulled to ground for a
period of around 150 milliseconds.
Re: Use of external reset supervisor chips
2006-03-10 by unity0724
Wow, very tough working condition for that Arm Chip...
and interesting...  :)
May be you should use both power supervisor/monitor chip + external
Hardware WDT. => WDT "kicks" the CPU again if it does not power up
properly.
I've seen some AVR chips flash program-able for WDT always on after
reset.  (WDT default as on after reset)
Could you help eMail me your experience after the project??
Thanks in advance!
--- In lpc2000@yahoogroups.com, "Andrew Berney" <amb@...> wrote:
> Hi all,
will be
for the
supervisor
for a
Re: A little confuse about CRP
Sorry, All LPC2xxx chips have flash memory locking except
 LPC2104/LPC2105/LPC2106...  :)
So far, I think there is only one silicon ver for LPC2104/5/6.
Have not heard of any new silicon yet!
somewhere that
have CRP
> at all?
will
Re: [lpc2000] A little confuse about CRP
2006-03-10 by Robert Adsett
Quoting Xtian Xultz <xultz@...>:
> somewhere that
> at all?
LPC 2104/5/6 do not have CRP
Presumably they also would have to copy your hardware.
Robert
2006-03-10 by philips_apps
Xtian,
unfortunately the LPC2104/5/6 do not have a protection against reading
your code through a debug channel.
We are however working on such a version that will include CRP and it
is scheduled to be available to the market in Q3 of this year.
Robert
somewhere that
have CRP
> at all?
will
2006-03-10 by lpcarmed
I had startup issues when the power supply did not ramp up the voltage
fast enough. The reset supervisor will make sure you reached the
operating voltage and then apply the delay. If your CPU is locked up
in a slow startup of the core voltage when peripheral supply already
applied the watchdog might not work. Is there a specification for
these conditions?
> properly.
> Thanks in advance!
> Regards
> --- In lpc2000@yahoogroups.com, "Andrew Berney" <amb@> wrote:
> > Hi all,
> will be
> for the
> supervisor
> for a
2006-03-11 by unity0724
Sorry, could not fully understand your question.
I was suggesting extra external hardware WDT to Mr Andrew Berney as
there might be cases of CPU not starting up, even with H/W
reset/power supervisor.  His type of working condition is just too
tough for the CPU.
If external hardware WDT is installed, this type of hardware WDT are
normally cleared by reset (Power supply below threshold level) and
will start to "WDT ticking" only after the reset (Power is above
threshold level + some reset delay).   It will always ensure some
fixed WDT timeout after reset before that WDT "bites" (typically 1-2
seconds).
For the core voltage delay, it is the duty of the reset/power
supervisor chip to have enough extra reset delay, typical 50-200mS
(extra reset delay after 3.3V power good to be longer than your 1.8V
LDO ramp delay)
voltage
up
already
> these conditions?
external
up
> > properly.
after
> > Thanks in advance!
> > Regards
> > --- In lpc2000@...m, "Andrew Berney" <amb@> wrote:
> > > Hi all,
that
> > will be
potential
> > for the
external
> > supervisor
ground
> > for a
RE: [lpc2000] Re: Use of external reset supervisor chips
2006-03-13 by Andrew Berney
Cheers for the input guys.
The actual environment this board will live in is on a steel propeller shaft
rotating at up to 1000Rpm (not an ideal environment but given its job is to
measure physical parameters of the shaft somewhat unavoidable). Due to the
nature of the rotation and required freedom, power is provided by induction
from a power head mounted close to the shaft, however this can lead to
intermittent problems with power loss/surge. Surge and spikes we can deal
with electronically however power drop/loss can lead to the ramp condition
you both describe. Hence I'm looking at the potential use of an external
supervisor / WDT and wondered if anyone had had any prior experience using
them with the Philips Micros.
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of unity0724
Sent: 11 March 2006 01:53
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Re: Use of external reset supervisor chips
tough for the CPU.
seconds).
LDO ramp delay)
voltage
up
already
> these conditions?
external
up
> > properly.
after
> > Thanks in advance!
> > Regards
> > > Hi all,
that
> > will be
potential
> > for the
external
> > supervisor
ground
> > for a
Yahoo! Groups Links
2006-03-13 by johnsonnenberg99
I've got experience with the LPC2132 not handling a brown-out
condtion.  In my case, when the Vcc dropped to around 1V, and then
back up to 3.3V, the CPU locked up, and would not recover.  External
reset will not clear this condition.  The only way I found to do it
was remove Vcc, then let it come back on.  If you have a system
where DC power will routinely ramp down and up, and may not go all
the way to 0V when it goes off, I highly suggest using something to
monitor the INPUT to the voltage regulator, and turn the regulator
off when its input is low.  The external WDT is probably a good idea
also.
John
propeller shaft
job is to
Due to the
induction
lead to
can deal
condition
external
experience using
Behalf
> Of unity0724
> tough for the CPU.
are
2
> seconds).
1.8V
> LDO ramp delay)
> Regards
> voltage
> up
> already
> > these conditions?
> external
> up
> > > properly.
> after
> > > Thanks in advance!
> > > Regards
> > > > Hi all,
> that
> > > will be
> potential
> > > for the
> external
> > > supervisor
> ground
> > > for a
