Lpc2000
Maximum periodic D/A speed
2006-01-16 by drareve
Does anyone know what is the maximum speed that I could send
data to the D/A at fixed frequency?
I am using a LPC2148 with a 10MHz crystal and a PLL M value of 6, and
P value of 2.  My PCLK should be 60Mhz (VPBDIV=0x1)
I have tried setting up a timer to send a sample every 1uS, but the
output appears to be quite unstable.
  Thank you
Re: [lpc2000] Maximum periodic D/A speed
2006-01-16 by Karl Olsen
---- Original Message ----
To: <lpc2000@yahoogroups.com>
Sent: Monday, January 16, 2006 9:40 PM
Subject: [lpc2000] Maximum periodic D/A speed
As far as I know, the D/A converter itself doesn't limit the update rate,
other than its fast/slow settling time.  But having a timer interrupt that
is called every 60 clocks that updates the DAC, requires some very careful
programming, and in the best case, you'll get very few spare clocks left for
the foreground program.  Just the stores that write to DACR and T0IR take 7
clocks each since they are behind the slow APB bridge.
Something like this (gcc):
unsigned short buf[1024];
int index;
void timer0_handler (void) __attribute__ ((interrupt("IRQ")));
  int next_index;
  DACR = buf[index] << 6;
  if ((next_index = index+1) == 1024)
    next_index = 0;
  index = next_index;
  T0IR = 0x01;
  VICVectAddr = 0x00;
with the usual  LDR  PC, [PC, #-0x0FF0]  at 0x0018 and MAM enabled and
MAMTIM=3, will take around 83 clocks.  Check the compiler output and see
http://groups.yahoo.com/group/lpc2000/message/7808 .  If you use FIQ instead
of IRQ, and carefully write it in assembler, you may be able to get below 60
clocks.
The DAC updating will have a jitter of a few clocks, because at each timer
interrupt, the current instruction of the foreground program must complete,
and that can take a variable number of clocks.
Karl Olsen
2006-01-16 by David Hawkins
You can eliminate the software jitter by introducing a set of
latches.
Use the hardware timer or PWM hardware to generate a fixed
frequency square-wave (or edge at least) on an output pin.
Use this to latch the input to the DAC.
In your software, triggered from the same timer, write the
next valid sample to the input of the latch, eg. on the
output pins of the micro, or to another latch that
preceeds the DAC latch.
The software jitter then only affects the data written
to the first latch, data written to the second latch
(or DAC internal latch) is done by the timer I/O pin,
so is unaffected by the software jitter.
If you use software to fill a FIFO, then the DAC can be
driven by the FIFO draining, and software can fill it
up on an 'almost empty' interrupt. You'll get higher
performance from the DAC with this scheme.
Cheers
Dave
Re: Maximum periodic D/A speed
2006-01-17 by brendanmurphy37
I presume you're talking about using some form of external DAC as
part of your suggestion? If not, can you explain the statement "Use
this to latch the input to the DAC".
A significant problem with the on-board DAC is that there is no latch
signal that can be applied, making some degree of jitter inevitable
on any software-driven setup.
We had to abandon the idea of using the on-board DAC for our software
modem for this very reason: even a few clocks of jitter at 60 Mhz is
enough to generate significant noise on the output.
I suspect anyone else (the original questioner on this topic?) trying
to drive the DAC at high speeds will hit this problem before they hit
the maximum o/p speed problem (unless having a noisy o/p isn't a
concern). This is unfortunate, as it means that the DAC can't really
be used for even relatively simple signal generation without a noisy
o/p.
A very simple addition to the DAC, namely a latch signal, would be a
great help here.
Of course, a DMA-fed FIFO arrangement would be even better.....
Brendan
P.S. as an aside, we did come up with a jitter-free software-fed DAC,
but it consumed significant MIPS, and just wasn't worth the effort.
> latches.
> Cheers
> Dave
Karl,
As a further suggestion to anyone taking this approach, I'd suggest
the following optimisations (which can be applied in other scenarios
as well that require speedy o/p).
1. Prepare the samples in buffers that are "ready to go", rather than
doing any processing in the o/p interrupt. I know that on ARM shifts
can sometimes be "free", but in some cases they're not.
2. Use power-of two sized buffers, and load using something like:
#define BUFF_SIZE 256
#define BUFF_SIZE_MASK (BUFF_SIZE - 1)
REG = buffer[index++];
index &= (BUFF_SIZE_MASK);
3. If you're really pushed for cycles for one particular interrupt,
you can use an FIQ interrupt and "pre-load" certain registers.
For example, in this case, in your start-up code:
load r8 with the DAC o/p register address
load r9 with the buffer address
load r10 with the current index
In the FIQ interrupt:
- just fall through from the bottom of the vector table (i.e. don't
branch or jump)
- use the pre-loaded r8, r9 and r10 (and others): no need to save
these as they're unique to FIQ interrupts
- update the pre-loaded registers of required for next time: they are
preserved across interrupts
We use these (and other) techniques in a system that both generates
and samples at high speed (200 Khz and above), and it works very well
Hope this of help to someone.
Brendan
> From: "drareve" <everard.kamphorst@g...>
and
rate,
interrupt that
careful
left for
T0IR take 7
> int index;
>   int next_index;
>     next_index = 0;
>   index = next_index;
>   T0IR = 0x01;
>   VICVectAddr = 0x00;
and
and see
FIQ instead
below 60
> clocks.
each timer
complete,
> Karl Olsen
Just to clarify the example below:
In your startup code, you can pre-load FIQ registers, but obviously
you have to be in FIQ mode to do this! We do this as part of the
initial startup that switches between modes to initialise the stack
pointers for each mode.
Brendan
--- In lpc2000@yahoogroups.com, "brendanmurphy37"
<brendan.murphy@i...> wrote:
> Karl,
scenarios
than
shifts
> branch or jump)
are
well
> Regards
> Brendan
6,
> and
> the
update
> rate,
> interrupt that
very
> careful
clocks
> left for
> T0IR take 7
> > int index;
> >   int next_index;
> >     next_index = 0;
> >   index = next_index;
> >   T0IR = 0x01;
> >   VICVectAddr = 0x00;
enabled
> and
> and see
> FIQ instead
get
> below 60
> > clocks.
> each timer
> complete,
> > Karl Olsen
2006-01-17 by Karl Olsen
> latch  signal that can be applied, making some degree of jitter
> inevitable on any software-driven setup.
> software modem for this very reason: even a few clocks of jitter at
> 60 Mhz is enough to generate significant noise on the output.
> trying to drive the DAC at high speeds will hit this problem before
> they hit the maximum o/p speed problem (unless having a noisy o/p
> isn't a concern). This is unfortunate, as it means that the DAC
> can't really be used for even relatively simple signal generation
> without a noisy o/p.
> a great help here.
Yep.  You can add an external "analog latch", i.e. a sample-hold
circuit with an analog switch and a capacitor, where the analog
switch is controlled by a PWM output.  The software then updates the
DAC output (at an imprecise time) while the analog switch is off and
the capacitor holds the voltage, and the PWM output later, at a
precise time, turns the analog switch on and lets the new voltage get
to the capacitor.
Karl Olsen
