Lpc2000
MMC/SD support on LPC2000
2006-01-17 by Carsten Grøn
Hello,
I have some code running now on a Embedded Artists 2148 board that
accesses a SD card (based on the philips code). So I can read/write
individual sectors....
My plan is to use a SD card as a "circular" buffer for data, so I
won't be using a real "file system" like FAT16 etc.
What I need now is a simple program (or some ideas for it) that can
access a SD card when connected to a PC using "raw" sector access....
That way I will be able to read the data from the card when it is
inserted in a card reader in a PC.
Any ideas/pointers ?
Carsten
Re: [lpc2000] MMC/SD support on LPC2000
2006-01-17 by David Hawkins
Carsten Gr\ufffdn wrote:
> Hello,
If you are running Linux, you can always get direct access to
the device via eg. /dev/sda1 nodes (assuming here you stuck
the card in say a USB multi-card reader and it showed up as
/dev/sda, with /dev/sda1 being the first partition on that
device).
If you're on Windows, take a look at filedisk by Bo Brant\ufffdn, its
a utility for mounting devices much like the loopback device under
Linux. I've used it with Cygwin for dd'ing floppy images into fake
drives for booting vmware, and mounting iso's.
It should be low-level enough for you.
Here's a site with filedisk
http://www.insidewindows.info/
I'm not sure what Windows will do if you plug a device in that
has no file system, it'll probably offer to format it for you.
Helpful soul that it is ...
Dave
2006-01-17 by Tom Walsh
>Hello,
Linux (maybe Cygwin as well?): use dd command to suck in the drive
contents: dd if=/dev/sda of=mySDcard.img
If you don't want the whole drive image, limit dd: dd if=/dev/sda
of=mySDcard.img bs=512 count=100
That will read the first 100 sectors off the SD card.
Assuming, of course, you used an media reader of some kind and inserting
the card mounted it as /dev/sda
TomW
>Regards,
>Carsten
>Yahoo! Groups Links
Re: MMC/SD support on LPC2000
Thanks Dave,
I have looked at the filedisk program your mentioned, but I don't
see (or more correctly, understand :-) how I can use that for
accessing the individual sectors on the SD card ?
I'm also more after some "code snippets" that will allow me access
to the SD cards sectors from within a C++ or C# application,
basically what I would need, is just the "PC equivivalent" of the
mmc_read_block() and mmc_write_block() in the Philips apps example
code, that way my "PC log file displayer" application can just look
at the SD card, and show the circular data (a large logfile) from
the card...
Carsten
> device).
> If you're on Windows, take a look at filedisk by Bo Brantén, its
> Dave
2006-01-17 by Bertrik Sikken
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> Hello,
'/dev/sdx' filenames also work with cygwin, so you can do something
like this under cygwin:
dd if=/dev/sdg of=image.bin
There is not a simple relation between the /dev/sdx name and
the windows name as far as I can tell.
Bertrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFDzVa6ETD6mlrWxPURAvW+AJ0XJpnI82q2qrZZ4GL9AGYpKYFjBwCdHZUU
yxeg4pxgFFLOjCeO1YaWghI=
=6qZp
-----END PGP SIGNATURE-----
Re: [lpc2000] Re: MMC/SD support on LPC2000
> the card...
I would just try it and see. Install Cygwin, and then install your
USB card reader with SD card installed. Try and figure out if
the /dev/sdX nodes are created. Sorry, I'm not sure what the
Cygwin command might be ...
To read binary data:
   int fd, len;
   char buf[10];
   fd = open("/dev/sda1", O_RDONLY);
   if (fd < 0) {
     printf("open failed\n");
     return -1;
   len = read(fd, buf, 10);
   if (len < 0) {
     printf("read failed\n");
     close(fd);
     return -1;
   ... mess with your data ...
Cheers
Dave
Sometimes I wish I was working under Linux :-)
Unfortunately, the people that is going to read the SD cards are not
running Linux/Cygwin etc on their PC's, so my only option is to have
something working under Windoze !
I will see if I can come up woth something for this, although (as
usual) deadline is coming fast......
Carsten
> Hash: SHA1
> Carsten Grøn wrote:
> > Hello,
that
read/write
can
access....
> Bertrik
> =6qZp
2006-01-17 by donhamilton2002
--- In lpc2000@yahoogroups.com, Carsten Grøn <cgroen@m...> wrote:
> Thanks Dave,
> the card...
> Regards,
> Carsten
"code snippets" assume that Windows knows how to use the media.
No program will be able to access that media until windows is happy.
Fooling Windows is what your looking for.
"filedisk" may be able to do that.
hamilton
2006-01-17 by Jaromir Subcik
Hi Carsten,
one possibility is to write one long defragmented file with a 512 (one
sector) unique bytes as starting symbol to SD card using standard card
reader on PC. This is easy task - erase (better quick format) entire SD card
and write prepared file.
On your board you can only find start of this file - read sectors from
begining until you find starting sequence and next sector is basic adress
for your buffer.
On PC you can simply read this file.
Sorry, I forgot how this metod calls - it is not sclerosis but my inability
Jarda
To: lpc2000@yahoogroups.com
Sent: Tuesday, January 17, 2006 9:07 PM
Subject: [lpc2000] MMC/SD support on LPC2000
Hello,
Carsten
Hi Jarda,
yes, I also thought about that idea, only problem is that the card
needs to be prepared on a PC, but I might be able to live with
that....Guess it's a kind of "poor mans filesystem" :-)
I have found some information regarding direct disk access, and it
should be perfectly possible from WinXP/2K...but the "one fixed file
method" you describe might turn out to be easier overall....
Carsten
--- In lpc2000@yahoogroups.com, "Jaromir Subcik" <subcik@s...> wrote:
> Hi Carsten,
(one
card
entire SD card
from
adress
> for your buffer.
inability
> Jarda
Yup,
if that works, it is sure simple !
The only problem is that I would really hate (and so would the
people using the PC software) to install lotsa software to use that
feature (cygwin etc)....
Carsten
>    int fd, len;
>    char buf[10];
>    if (fd < 0) {
>      return -1;
>    if (len < 0) {
>      close(fd);
>      return -1;
> Cheers
> Dave
Indeed it works.
I just plugged in a USB camera that appears as a USB mass
storage device
dd bs=512 count=1 if=/dev/sdb of=tmp.img
worked, and if I removed the device, it gave an error.
Seems good to me.
Dave
2006-01-17 by Sean
I get really tired of everyone bashing windows all the time... :)  Isn't it
interesting how 4x the number of bugs are found in linux than windows?  But
I digress...
Check out WinHex, it can directly access any fixed media device at a raw level.
Alternatively, if you aren't afraid of a little programming, you can easily
open any raw device and seek to any sector and read/write to your hearts
content with only a few lines of standard C code.  Windows has just as
robust an addressing system as linux does under the /dev/ filesystem, if
anything windows has even more, do a google search on the \\?\ prefix.  No
fooling of windows is necessary to make this happen.
-- Sean
At 03:07 PM 1/17/2006, you wrote:
>Hello,
>Regards,
>Carsten
>Hi Jarda,
His idea is not too bad.  blank an SD card with quick format,  that will
erase the FAT table.  Then create a file the size of your buffer.  In
your embedded system, read the partition table, MSDOS boot block and
root directory to locate your file start cluster.  Then deblock from
there from cluster to sector.  Be carefull of fragmentation, Microsoft
loves to fragment files!
Of course, then you have the idiot (that's the guy that refuses to
RTFM)  out in the field that wants to add / delete files on the SD card...
TomW
> Yup,
There's nothing special about the Cygwin technique, it
just uses the standard Linux tools. Under the hood its using a
Windows call ...
http://disktype.sourceforge.net/doc/ch01s04.html
Windows name: \\.\PHYSICALDRIVE2
so ...
   HANDLE h = CreateFile("\\\\.\\PHYSICALDRIVE2" ...
or whatever the Windows device names are.
Take a look around Microsoft for 'raw device access' or something
like that.
Dave
Hi Sean,
you're absolutely right !
If I were to suggest the people that is going to read the log data
from this SD card, that they install Linux (or some other
derivative), they would just look at me, and ask, WHAT ?
So, only option is to use Windows (which I absolutely don't mind,
having 7 WinXP PC's in the house here :-)
I just realized that CreateFile can do all the magic, direct disk
access and pretty much anything else !
(http://msdn.microsoft.com/library/default.asp?url=/library/en-
us/fileio/fs/createfile.asp)
So this is the route I will take, definately,
thanks for the heads-up Sean
Carsten
Isn't it
windows?  But
> I digress...
a raw level.
can easily
hearts
just as
filesystem, if
prefix.  No
2006-01-17 by Sean
This may be a stupid question, why not just use a file system?  I believe
that there is some code available for FAT file system access on SD/MMC for
LPC series, wouldn't that make things a lot easier?  This way you can use
any existing application without any special need for programming or
unix-style commands.
-- Sean
>Hello,
>Regards,
>Carsten
>SPONSORED LINKS
><http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>Microprocessor
><http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>Microcontrollers
><http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>Pic
>microcontrollers
><http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>8051
>microprocessor
>YAHOO! GROUPS LINKS
>    *  Visit your group "<http://groups.yahoo.com/group/lpc2000>lpc2000"
> on the web.
>    *  To unsubscribe from this group, send an email to:
> <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>lpc2000-unsubscribe@yahoogroups.com
>    *  Your use of Yahoo! Groups is subject to the
> <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service.
Sean,
the reason (for me) would be that it would be simpler on the LPC
board, no need for FAT etc (I'm actually also looking into prllc's FAT
implementation with SD support at $139,- which I think is very
reasonable). Also I'm a little worried that the card will be "killed"
by problems with write-endurance (if using FAT, the FAT tables are
written very often), and if used as a circular buffer, each sector
will be written (relatively) seldom.
Carsten
believe
SD/MMC for
can use
> -- Sean
> Sean,
> Regards,
> Carsten
Perhaps you could get the best of both worlds. Format the card with
a FAT file system containing one large file. If the micro only writes
bytes within that file, and the format is understood within that
file by both the micro, and the Windows app. the OS need only
know that there is a file there, not how to interpret it.
The circular buffering will just occur within the large binary
area that is 'the file'.
Dave
Dave,
yes, that would possibly "fix" both problems, the "FAT data" is just
a "tool" for the PC afterwards to get to the data (as a file), and
the processor would still be able to access the card as a "circular
type" of memory. And as the file is fixed in size, there is no need
to write to the "FAT table" on the card. Might do the trick !
Carsten
> Carsten Grøn wrote:
> > Sean,
prllc's FAT
be "killed"
are
sector
> > Regards,
> > Carsten
writes
> Dave
2006-01-17 by Sean
IIRC Tom Walsh has a FAT implementation working with source code for free
on the LPC series.  You could pretty easily modify it to NOT update the
date/time in the fat table whenever you write to the file, meaning that you
won't kill the area where teh FAT table is if you update it
frequently.  Then you can easily setup a ring buffer in a file on the
device, and it should be pretty easy to access and still give you the
flexibility of having a recognized filesystem on a PC.  If not Tom, then
there are a few other implementations available that will work fine for
your simple application.
-- Sean
At 04:27 PM 1/17/2006, you wrote:
>Sean,
>Regards,
>Carsten
>believe
>SD/MMC for
>can use
> > -- Sean
>YAHOO! GROUPS LINKS
> on the web.
2006-01-17 by Sean
Except that the FAT table is usually updated on every write for the
last-accessed and/or last-written fields.  But if you can get source code
for a filesystem layer then you should be able to modify it to remove that
update.
-- Sean
At 04:36 PM 1/17/2006, you wrote:
>Carsten Grøn wrote:
> > Sean,
> > Regards,
> > Carsten
>Dave
2006-01-19 by Hans Van Ingelgom
> I digress...
Weren't there some issues with patents on the FAT file
system recently? Here's a link:
http://www.eweek.com/article2/0,1895,1909857,00.asp
So I can really understand why people are looking at
alternatives to FAT at the moment.
PS: a quick rebuttal of your digression (sorry, but if
I don't respond people might get FUD'ed): Linux is a
complete system, e.g. Debian has over 9000 packages.
The base system hardly has any bugs. I'm using Debian
exclusively for more than 3 years, and I can't say I
have had many security issues since. 95% of the
security reports I receive involve packages I haven't
got installed. I never got a virus, never found a
root-kit (I check for that regulary), and I have a 3
year old system that I never had to re-install
(upgrades just work(tm)). There were about 2-3
packages I had to upgrade specifically because of
security fixes, and it was a breeze (i.e. it works
just like a regular upgrade). End of rebuttal of
digression. Please don't reply any further (IMO, you
already went too far/OT with your first comment).
Do You Yahoo!?
http://mail.yahoo.com
2006-01-19 by clemens fischer
> Carsten Gr\ufffdn:
> from this SD card, that they install Linux (or some other derivative),
"cygwin" isn't a complete operating system, it's a window$ native
implementation of most POSIX calls running off a DLL. this is to be able
to use "unix"-like tools and make programs the "unix" way, isolated from
the abyss of window$-APIs.
your customer would see a native window$ program.
  clemens
2006-01-19 by Carsten Grøn
Hi Clemens,
yes I know, you're right.
Generally I simply just hate to install (or demand from
users) "extra" stuff in order to use some command tool, I need to
make a "simple application", that is self-contained (I know, it uses
a zillion DLL's from the operating system....) instead of installing
all kinds of software.
Now for something completely OT for this forum :-)
I have been making PC programs since the good old CPM days (for 22
years now), been thru OS/2 and all the windows versions, and I have
to say, I don't miss the old days ! It's never been more stable and
easy to make software than it is today. I know, its also never been
more complicated than it is today, but you have to pay a price for
all the features you get. Part of that is due to Mr. Gates and
Microsoft.
I take my hat of to those how uses Linux and experiments with it,
however, I could not see myself use Linux as a developer, at least
not with the things I do for a living, it would simply be a problem
with tools (FPGA designs etc etc) and my productivity would suffer.
Now I might be completely ignorant and wrong about this, but this is
how I see it :-)
Don't flame me........
Carsten
--- In lpc2000@yahoogroups.com, clemens fischer <ino-qc@s...> wrote:
> > Carsten Grøn:
data
derivative),
be able
isolated from
>   clemens
