Tom Walsh wrote:
>I have two LPC2000 series processors on my board interconnected so that
>either processor can force the other into ISP mode. The project calls
>for the current binary image of each processor be stored (SD card)
>before the new image is loaded into Flash. Using the ISP command set, I
>can read all but the first 64 bytes as the MEMMAP (0xE01FC040) register
>is mapping the IVECTs to the bootloader ROM.
>The solution that I see, aside from a generic jump table, is to:
>1. Load a small program into RAM
>2. Have it flip MEMMAP to User Flash
>3. Copy n bytes into RAM
>4. Flip MEMMAP back to Bootloader
>5. Return to ISP.
> From reading the various LPC2000 user manuals, they seem to suggest
>this might be possible via the GO command. The LPC210{4,5,6} reference
>states that the ISP may be resumed with a simple RETurn at the end of
>the user code.
>Has anyone tried this? I am hoping that after the call to my code in
>RAM, and it returns to the bootloader, that the bootloader will still
>be "synchronized" and I may proceed with a READ command to fetch those
>bytes.
For the benefit of people researching this topic in the future, it does
work. Here is the code I uploaded and executed.
============ begin data_code_array ================
static uint copyIt[] = {
0xe10f5000, // mrs r5, cpsr // turn off interrupts.
0xe3e000c0, // mvn r0, #0xc0
0xe0000005, // and r0, r0, r5
0xe129f000, // msr cpsr, r0
0xe3a040e0, // mov r4, #0xe0 // switch MEMMAP to User Flash
0xe1a04404, // mov r4, r4, lsl #8
0xe384401f, // orr r4, r4, #0x1f
0xe38440c0, // orr r4, r4, #0xc0
0xe3844040, // orr r4, r4, #0x40
0xe3a01001, // mov r1, #1
0xe5841000, // str r1, [r4] // now at User Flash
0xe3a00000, // mov r0, #0
0xe3a01004, // mov r1, #0x4
0xe1a01e01, // mov r1, r1, lsl #28
0xe3811a01, // orr r1, r1, #0x1000
0xe3a02c01, // mov r2, #256 // copy 256 bytes from 0x0
to 0x40000800
//copyIt0:
0xe5d03000, // ldrb r3, [r0]
0xe5c13000, // strb r3, [r1]
0xe2800001, // add r0, r0, #1
0xe2811001, // add r1, r1, #1
0xe2522001, // subs r2, r2, #1
0x1afffff9, // bne copyIt0
0xe3a01000, // mov r1, #0
0xe5841000, // str r1, [r4] // now back to Boot Loader
vectors.
0xe129f005, // msr cpsr, r5 // set flags back to state
on entry.
0xe12fff1e // bx lr // return to ISP
bootloader from "go".
============== snip =========================
Dump the contents of that data array into a convenient RAM location of
the target LPC2000 processor, then execute as "GO nnnn A".
