Lpc2000
RE: [lpc2000] JTAG - RTCK ? / Building DIY wiggler w/74VHC14
2006-01-20 by Soentgerath, Guido
Thank you all for your answers !
By the way, do you know which pin of the jtag connector is used for RTCK
Tom, is there something in the BDI2000 manual ?
Ed, I think it would be good to add RTCK even it is  not in the original
wiggler design.
Have a nice day,
Guido
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of Dan Beadle
Sent: Mittwoch, 18. Januar 2006 17:29
To: lpc2000@yahoogroups.com
Subject: RE: [lpc2000] JTAG - RTCK ?
It is the Return Clock.  It is used for deglitching the return signal.
Ideally, the chip under test would have zero delay getting the clock on
board.  But it does have some delay. The RTCK is the image to of the
JTAG clock being used by the chip. For very fast clocking, this allows
the debugger to sync up with the chip under test.
  _____
Of Leon Heller
Sent: Wednesday, January 18, 2006 3:03 AM
Subject: Re: [lpc2000] JTAG - RTCK ?
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, January 18, 2006 9:05 AM
Subject: [lpc2000] JTAG - RTCK ?
> Hello all,
> can someone give me an explanation for RTCK  or  a hint where I can
find
> some more infos about this signal ?
> Thanks in advance!
I found a document on the ARM web site a long time ago which describes
JTAG interface in detail. Can't remember where, though.
Leon
  _____
YAHOO! GROUPS LINKS
*      Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
*      To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*      Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
  _____
YAHOO! GROUPS LINKS
Re: JTAG - RTCK ? / Building DIY wiggler w/74VHC14
2006-01-20 by derbaier
--- In lpc2000@yahoogroups.com, "Soentgerath, Guido"
The Lauterbach Trace32 uses Pin-11 of the 20 pin JTAG connector for
RTCK.  They have usually been quite good at sticking with ARM's
specifications, so that is *probably* the pin specified by ARM.
Unfortunately, AN31 predates ARM's use of RTCK, so it does not mention
it at all.
-- Dave
Re: [lpc2000] JTAG - RTCK ? / Building DIY wiggler w/74VHC14
2006-01-20 by Tom Walsh
I don't use the RTCK signal.  The manual says something about a "special
cable",  they probably added one more wire to the present cable that I
have...  The wire they use is some 11 or 15 strand (maybe even 19
strand) super flexible stuff.
TomW
It is Pin 11 on the 20 pin connector, 14 pin connector doesn't show any.
Myself, I put a 10 pin header on my board and just moved the wires
around on the 14pin cable...
TomW
Thanks Tom, Dave,
it seems that pin 11 is the RTCK pin.
Guido
Of Tom Walsh
Sent: Freitag, 20. Januar 2006 14:13
Subject: Re: [lpc2000] JTAG - RTCK ? / Building DIY wiggler w/74VHC14
RTCK
TomW
SPONSORED LINKS
Microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontroller
s&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4
&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>  	Microprocessor
<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&
w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s
=95&.sig=9jjd2D3GOLIESVQssLmLsA>  	Intel microprocessors
<http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontr
ollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontroller
s&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>
Pic microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontro
llers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers
&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
YAHOO! GROUPS LINKS
