Lpc2000
TD1(pin 22) on LPC2292/LPC2294 as GPIO
2006-01-24 by Boris Kralik
Hi.
I want to use TD1 pin on LPC2292/LPC2294 as output, but in manual is
not ports to GPIO. Is possible to use TD1 as GPIO ? If yes, how it
make it ?
Thx.
Re: TD1(pin 22) on LPC2292/LPC2294 as GPIO
2006-01-24 by unity0724
I was suspecting that pin to be port bit P0.26 previously.
But dare not use it.   May be you can try with setting PINSEL0
and try toggle it.   Let me know the result, thanks.... :)
--- In lpc2000@yahoogroups.com, "Boris Kralik" <kralikbo@y...> wrote:
> Hi.
> make it ?
> Thx.
Re: [lpc2000] Re: TD1(pin 22) on LPC2292/LPC2294 as GPIO
2006-01-27 by Boris Králik
I try TD1 pin set as GPIO (P0.26) and toogle it
(SET/CLR), but without effect.
Any sugestion ?
--- unity0724 <unity0724@...> wrote:
> Hi,
> previously.
> setting PINSEL0
> thanks.... :)
> Regards
> > Hi.
> ? If yes, how it
> > make it ?
> > Thx.
Regards / S pozdravom Boris Kralik
http://www.geocities.com/kralikbo/
___________________________________________________________
Yahoo! Photos \ufffd NEW, now offering a quality print service from just 8p a photo http://uk.photos.yahoo.com
RE: [lpc2000] Re: TD1(pin 22) on LPC2292/LPC2294 as GPIO
Yes,direction (GPIO0_IODIR) was OK.
PCB_PINSEL1 &= 0x0FFFFF; //bit 23:20 as 0, ?P0.26? and
P0.27 as GPIO
GPIO0_DIR |= (1 << 26);  //Set as output
GPIO0_IOSET/GPIO0_IOCLR | =(1 << 26);
Any sugestion ?
> > Any sugestion ?
> Direction registers reset as inputs, be sure to set
> direction register
> correctly.
> Joel
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre. http://uk.security.yahoo.com
2006-01-27 by Joel Winarske
> P0.27 as GPIO
What's the LPC21xx part you're working with?
Joel
LPC2294
> and
> > P0.27 as GPIO
> Joel
Win a BlackBerry device from O2 with Yahoo!. Enter now. http://www.yahoo.co.uk/blackberry
> > and
> > > P0.27 as GPIO
P0.26 is reserved per user manual page 128:
http://www.semiconductors.philips.com/acrobat_download/usermanuals/UM_LPC21X
X_LPC22XX_2.pdf
You should be able to toggle P0.27.
Joel
2006-02-02 by unity0724
Hi, Sorry for some delays... Did not have a chance to get near an
LPC21xx chip for a week...
Pls test out/verify following code.   It seems toggling Pin 10 which
is an NC Pin on the LPC2124. Can you verify at your side??
PINSEL1 |= 0x00300000;
IODIR0  |= 0x04000000;
while (1) {
	for (i=0;i<10000;i++);
	IOSET0=0x04000000;	// Set P0.26
	IOCLR0=0x04000000;	// Clr P0.26
- Somehow waveform is not 50%, I did not try to figure out why.
  That port bit might have some weird delays/bugs.
- I do not have a LPC2292/4, only LPC2124 here.   Pin 10 is NC pin
  for LPC2124.
- I think Philips errata sheet did say this pin must NOT be pulled
  low during reset
- I will NOT want to use the pin in this way, unless real
  "emergency"...    :)
- Hope philips will put P0.26 back...  It is difficult to find
  contiguous/consecutive 8-bit data bus bits for external peripheral
  interface.   I guess some VHDL guys must have screw up something
  on P0.26...   :)
- Good luck and have fun, pls tell me of more discoveries...
> Any sugestion ?
> > Hi,
> > previously.
> > setting PINSEL0
> > thanks.... :)
> > Regards
> > > Hi.
> > ? If yes, how it
> > > make it ?
> > > Thx.
> Yahoo! Photos – NEW, now offering a quality print service from
2006-02-02 by Boris Kralik
When I tried set/clr pin P0.26, no changes on TD1.
I works only with LPC2294/2292.
In the manual this pin is not available (page 5 in Preliminary data
Rev01-05 2004).
Regards.
> while (1) {
>   for LPC2124.
>   low during reset
>   "emergency"...    :)
>   on P0.26...   :)
> Regards
> > Any sugestion ?
> > --- unity0724 <unity0724@> wrote:
> > > Hi,
> > > previously.
> > > setting PINSEL0
> > > thanks.... :)
> > > Regards
> > > > Hi.
> > > ? If yes, how it
> > > > make it ?
> > > > Thx.
