Lpc2000
No result for ADC in burst mode
2006-02-01 by scrappystuff64
I have this code for the ADC in burst mode. The ISR is called
continually, but I don't see a value for the result. Gurus enlighten
me, what am I doing wrong?
#include <lpc21xx.h>
void AD_ISR (void) __irq
  unsigned val,chan;
  static unsigned result[8];
  val = ADDR;
  chan = ((val >>0x18) & 0x07);
  val =  (val >> 6) & 0x03FF; //Extract the A/D result
  result[chan] = val;
  VICVectAddr = 0; //clear the IRQ function address
int main(void)
  PINSEL1 = 0x003FF000;
  PINSEL0 = 0x03F00000;
  ADCR = 0x00270204; // Setup A/D: 10-bit AIN0 @ 4.2MHz
  VICVectCntl0 = 0x00000032; //connect A/D to slot 0
  VICVectAddr0 = (unsigned)AD_ISR; //pass the address of the IRQ
into the VIC slot
  VICIntEnable = 0x00040000; //enable interrupt
while(1)
Re: [lpc2000] No result for ADC in burst mode
2006-02-01 by Tom Walsh
>  unsigned val,chan;
>  val = ADDR;
>  result[chan] = val;
Try dumping your code (arm-elf-objdump) or look at the listings file
(.lst). I think that you will find that the compiler has decided that
since result[] only has a value put into it and it is otherwise unused,
it was optimized out (dead code).
TomW
Re: No result for ADC in burst mode
2006-02-02 by Guillermo Prandi
> otherwise unused, it was optimized out (dead code).
You can try using the "volatile" modifier to the variable. That
forces the compiler to modify it even when it doesn't see the
point. :)
Guille
enlighten
> >  unsigned val,chan;
> >  val = ADDR;
> >  result[chan] = val;
file
that
unused,
> TomW
