Lpc2000
Flash write errors
Flash write errors
2006-01-25 by Guillermo Prandi
Hi. Are Flash write errors normal, i.e. a known issue? When
programming my LPC2138 using the isp21lpc utility, every now and then
I get a write error; a second attempt always succeed. This happens
roughly once every 100 programming attempts. I thought it could have
been a problem with my serial cable or some other hardware problem,
but now I added an IAP function to my test program and I am getting
errors too (i.e., saved data differs from the source data, although
the IAP copy ram to flash command returns CMD_SUCCESS). I checked
everything and I think I covered the normal requisites:
* Prepare the Flash sector for writing (for erase).
* Erase the intended block.
* Prepare the Flash sector for writing.
* Write a 256 bytes block.
At each IAP call I:
* Disable all interrupts.
* Provide the right clock in KHz to the IAP (10 MHz-->10000).
I am using an external 10 MHz crystal, and no PLL.
Even the power supply seems solid; for what I've seen with my
osciloscope, VDD never gets below 3.3V (it is normally at 3.334V).
Oddly enough, I am NOT getting any dabt exceptions; I would have
expected that reading from a corrupted sector of the flash memory
would have raised a dabt exception, which doesn't seem to be the
case. Also, reads from the flash are consistent; i.e., even when I
get the wrong data in the flash sector, the 'wrong' data is stable
until erased. Also, the 'wrong' data is *similar* to the 'right'
data; i.e., if I want to save "HELLO", I might get "HELLO" (correct)
or perhaps "H??L?" (incorrect).
Any ideas?
Guille
Re: [lpc2000] Flash write errors
2006-01-26 by Tom Walsh
There seems to be something goofy going on with those utils.  I tried
using the lpc21isp (version 1.24) package on Linux, but it would
sometimes error out at random locations.  Not sure why.
I finally had to write an ISP loader for an LPC2138 to program an
LPC2106.  This loader source I then took an hung some RS232 routines
onto it so I could also up load into the LPC2138 from Linux.  So far, my
loader works flawlessly.
Go figure.
TomW
Re: Flash write errors
2006-01-26 by Guillermo Prandi
That's interesting, Tom. That would explain the programming errors
from my PC, but the IAP errors are still puzzling. I can live with
lpc21isp errors (provided I can retry a couple of times until it
works). The problem is IAP. My device is supposed to keep track of
things in its Flash memory, and my file system code is to be much
more complex if it has to take IAP false writes like these into
account.
Guille
then
have
problem,
getting
although
tried
routines
far, my
> Go figure.
> TomW
Re: [lpc2000] Re: Flash write errors
>account.
My apologies, for some reason I get IAP & ISP mixed up and equate one
with the other.  No, I haven't encountered problems with the IAP.  The
one processor erases all but 80K of the flash and self programs 112K
from the SD card.  This doesn't give any problems or errors, it just works.
TomW
2006-01-26 by Robert Adsett
I had some similar occurrences with the Philips utility as well.  They seem
to have disappeared about the time I started using the automatic
downloading and a good cabling setup on the last few centimeters.  I've not
had a similar problem with the lpc21isp program and I've not tried
IAP.  Mind you the write errors I was seeing were not verify errors but the
protocol appearing to simply stop and it was rare enough that I couldn't be
certain as to its source.
A quick question to verify my understanding of what you are seeing
Guillermo, is your verification source the same buffer you just used to
program via IAP or do you refresh it from elsewhere before you do the compare?
Just a little more grist for the mill.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
My apologies if this shows up twice.  Every once in a while Yahoo decides
it couldn't send a piece of mail my way several days in the past and shuts
down delivery despite having sent mail successfully to the same address
since many times.
Robert
2006-01-26 by Richard Duits
Because of the build-in ECC, the flash cannot update a block smaller
than 16 bytes (aligned on a 16 byte boundary). This is not documented in
the user manual. You can search this list for previous threads about this.
Richard.
> shuts
> since many times.
> seem
> I've not
> but the
> couldn't be
> compare?
> Robert
> restrictions,   be
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Hi, Richard. This is an excertp of my test code:
#define IAP_LOCATION 0x7ffffff1
typedef void (*IAP)(unsigned int [],unsigned int[]);
static    unsigned    int    iapcmd[5];
static    unsigned    int    iapres[3];
#define    IAP_CMD_PREPARE_FOR_WRITE   50
#define    IAP_CMD_COPY_RAM_TO_FLASH   51
#define    IAP_CMD_ERASE_SECTORS       52
#define    IAP_CMD_CHECK_BLANK         53
#define    IAP_CMD_READ_PART_ID        54
#define    IAP_COMMAND                 0
#define    IAP_RESULT                  0
#define    IAP_PFW_START_SECTOR        1
#define    IAP_PFW_END_SECTOR          2
#define    IAP_CRTF_DST_ADDR           1
#define    IAP_CRTF_SRC_ADDR           2
#define    IAP_CRTF_BYTES              3
#define    IAP_CRTF_CCLK_KHZ           4
#define    IAP_ES_START_SECTOR         1
#define    IAP_ES_END_SECTOR           2
#define    IAP_ES_CCLK_KHZ             3
#define    IAP_CB_START_SECTOR         1
#define    IAP_CB_END_SECTOR           2
#define    IAP_CB_NON_BLANK_FIRST      1
#define    IAP_CB_NON_BLANK_WORD       2
} else if( !strnicmp( command, "iapw ", 5 ) )
    static    char   buf[256];
              char*  txt = &command[5];
              int    res;
    memset( buf, 0, sizeof(buf) );
    strcpy( buf, txt );
    do {    // Not a loop
    res = IAP_CheckBlank( 22, 22 );
    if( res != IAP_CMD_SUCCESS )
        printf( "Sector is not blank. Blanking sector...\r\n" );
        res = IAP_PrepareForWrite( 22, 22 );
            printf( "IAP_PrepareForWrite() returns error %
d\r\n", res );
            break;
        res = IAP_EraseSectors( 22, 22 );
            printf( "IAP_EraseSectors() returns error %d\r\n", res );
            break;
        printf( "Sector blanked.\r\n" );
    printf( "Writing onto flash...\r\n" );
        printf( "IAP_PrepareForWrite() returns error %d\r\n", res );
        break;
    res = IAP_CopyRAMToFlash( buf, (void*) 0x00078000, sizeof(buf) );
    if( res == IAP_CMD_SUCCESS )
        printf( "Flash memory written successfully.\r\n", res );
        if( memcmp( buf, (void*) 0x00078000, sizeof(buf) ) )
            printf
( "Flash and RAM buffer contents do NOT match.\r\n" );
        } else {
            printf( "Flash and RAM buffer are now identical.\r\n" );
    } else {
        printf( "IAP_CopyRAMToFlash() returns error %d\r\n", res );
        break;
    } while(0);
int IAP_PrepareForWrite( int start_sector, int end_sector )
    taskENTER_CRITICAL();
    iapcmd[IAP_COMMAND] = IAP_CMD_PREPARE_FOR_WRITE;
    iapcmd[IAP_PFW_START_SECTOR] = start_sector;
    iapcmd[IAP_PFW_END_SECTOR] = end_sector;
    IAP    iap_entry = (IAP) IAP_LOCATION;
    iap_entry( iapcmd, iapres );
    int    res = (int) iapres[IAP_RESULT];
    taskEXIT_CRITICAL();
    return res;
int IAP_CopyRAMToFlash( void* src_addr, void* dst_addr, int bytes )
    iapcmd[IAP_COMMAND] = IAP_CMD_COPY_RAM_TO_FLASH;
    iapcmd[IAP_CRTF_SRC_ADDR] = (unsigned long) src_addr;
    iapcmd[IAP_CRTF_DST_ADDR] = (unsigned long) dst_addr;
    iapcmd[IAP_CRTF_BYTES] = bytes;
    iapcmd[IAP_CRTF_CCLK_KHZ] = GetCCLKKHz();
    return res;
int IAP_EraseSectors( int start_sector, int end_sector )
    iapcmd[IAP_COMMAND] = IAP_CMD_ERASE_SECTORS;
    iapcmd[IAP_ES_START_SECTOR] = start_sector;
    iapcmd[IAP_ES_END_SECTOR] = end_sector;
    return res;
int IAP_CheckBlank( int start_sector, int end_sector )
    iapcmd[IAP_COMMAND] = IAP_CMD_CHECK_BLANK;
    iapcmd[IAP_CB_START_SECTOR] = start_sector;
    iapcmd[IAP_CB_END_SECTOR] = end_sector;
    return res;
Guille
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
decides
and shuts
address
> since many times.
then
happens
have
problem,
getting
although
tried
routines
far, my
They seem
I've not
but the
couldn't be
used to
the compare?
> Robert
restrictions,   be
chew a
2006-01-26 by Mauricio Scaff
I cannot talk about the IAP errors, but the ISP errors sometimes are
related to unsupported baud rates for your selected crystal.
Here I use 12.000Mhz and it works fine @ 38400. but if I raise to 57600
I get frequent errors in the middle of the process.
By the way. Is it possible with the lpc2isp (maybe with a simple
modification in the source code) to use non standard baud rates ?
The ISP works fine @14.7456Mhz with 115200 or even 230400 (datasheet
information)
So if my crystal is 12.000 would be possible to talk with the ISP @
93750bps or 187500bps.
Mauricio
Sorry, guys, my mistake.
I was not checking the sector for being blank after my
IAP_EraseSectors() function, and there was a typo in that function
that prevented the correct CPU clock from getting through the IAP
command.
It was a weird thing to watch the erase sectors command take almost
no time, when it was supposed to take 400 mS!
Thanks everybody.
Guille
--- In lpc2000@yahoogroups.com, "Guillermo Prandi"
>               int    res;
>     strcpy( buf, txt );
>     do {    // Not a loop
> d\r\n", res );
>             break;
d\r\n", res );
>             break;
>         break;
(buf) );
>             printf
>         } else {
>     } else {
>         break;
>     } while(0);
>     return res;
>     return res;
>     return res;
>     return res;
> Guille
> decides
> and shuts
> address
> > since many times.
and
> then
> happens
could
> have
> problem,
> getting
> although
checked
> tried
> routines
> far, my
> They seem
centimeters.
> I've not
tried
errors
> but the
> couldn't be
seeing
> used to
> the compare?
> > Robert
> restrictions,   be
to
> chew a
