GNU ARM Frontend (IDE)
2006-01-25 by Felipe Fontoura
Hi, would like to know if exists some IDE of development for GNU ARM (WinARM or GNU Toolchain)? Grateful to all -- Felipe Fontoura - Brazil Linux user: #281076
2006-01-25 by rtstofer
Sure, just follow the tutorial here: http://tinyurl.com/camje Richard --- In lpc2000@yahoogroups.com, Felipe Fontoura <ffontouras@g...> wrote:
> > Hi, > > would like to know if exists some IDE of development for GNU ARM > (WinARM or GNU Toolchain)? > > Grateful to all > > -- > Felipe Fontoura - Brazil > Linux user: #281076 >
2006-01-25 by ntfreak2000
The only ones i know of are RIDE www.raisonnace.com which uses GNUARM and Anglia www.anglia.com/columbus One slight problem is they both only target the ST STR7x devices. Regards sjo --- In lpc2000@yahoogroups.com, Felipe Fontoura <ffontouras@g...> wrote:
2006-01-25 by EmbeddedHub
Hi, you may try CrossWorks for ARM (http://www.rowley.co.uk/arm/index.htm) also. It targets for ARM core micrcontrollers from LPC, ST, TI, etc. There are sample programs for the target boards: http://www.rowley.co.uk/arm/boards.htm Have fun :) Regards, Tim http://www.embeddedhub.com --- In lpc2000@yahoogroups.com, "ntfreak2000" <ntfreak2@h...> wrote:
> > The only ones i know of are RIDE www.raisonnace.com which uses > GNUARM and Anglia www.anglia.com/columbus > > One slight problem is they both only target the ST STR7x devices. > > Regards > sjo > > --- In lpc2000@yahoogroups.com, Felipe Fontoura <ffontouras@g...> > wrote: > > > > Hi, > > > > would like to know if exists some IDE of development for GNU ARM > > (WinARM or GNU Toolchain)? > > > > Grateful to all > > > > -- > > Felipe Fontoura - Brazil > > Linux user: #281076 > > >
2006-01-25 by Tom Walsh
Felipe Fontoura wrote: >Hi, > >would like to know if exists some IDE of development for GNU ARM >(WinARM or GNU Toolchain)? > > > Mice are nice but I find them getting in the way of software developement (sorry Eclipse ;). I use a more traditional command line oriented approach as I am constantly roaming the command line doing things that most encapsulated development IDEs just don't provide me with. My development solution (both cost-wise and functionally) was to go with a Linux host, binutils, gcc ARM cross compiler (Thumb flavor), Insight as a frontend to gdb (source level debug), and an ethernet based JTAG (Abatron BDI2000). Having a somewhat limited budget to start this project, I decided to sink the bulk of the software tokens into a good JTAG unit. From recommendations from many sources, I finally purchased an Abatron BDI2000. This is an excellent unit, has proved to be highly reliable and flexible! A real asset and time saver when building code. The devtools I built from source. A webpage detailing how to replicate my environment is at: http://www.openhardware.net/?title=ARM%20Thumb%20tools%20for%20LPC2000&dir=ArmTools&file=ThumbToolchain.html Enjoy! TomW >Grateful to all > >-- >Felipe Fontoura - Brazil >Linux user: #281076 > > > >Yahoo! Groups Links > > > > > > > > -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
2006-01-25 by Jan Szymanski
Tom, As you love you Linux do you know of any software CAD tools for schematic and pcb development. Luck of such tools of a quality comparable to medium level tools like Protel is keeping me away from Linux Happy typing Jan --- In lpc2000@yahoogroups.com, Tom Walsh <tom@o...> wrote: > > Felipe Fontoura wrote: > > >Hi, > > > >would like to know if exists some IDE of development for GNU ARM > >(WinARM or GNU Toolchain)? > > > > > > > Mice are nice but I find them getting in the way of software > developement (sorry Eclipse ;). I use a more traditional command line > oriented approach as I am constantly roaming the command line doing > things that most encapsulated development IDEs just don't provide me with. > > My development solution (both cost-wise and functionally) was to go with > a Linux host, binutils, gcc ARM cross compiler (Thumb flavor), Insight > as a frontend to gdb (source level debug), and an ethernet based JTAG > (Abatron BDI2000). > > Having a somewhat limited budget to start this project, I decided to > sink the bulk of the software tokens into a good JTAG unit. From > recommendations from many sources, I finally purchased an Abatron > BDI2000. This is an excellent unit, has proved to be highly reliable > and flexible! A real asset and time saver when building code. > > The devtools I built from source. A webpage detailing how to replicate > my environment is at: > http://www.openhardware.net/?title=ARM%20Thumb%20tools%20for% 20LPC2000&dir=ArmTools&file=ThumbToolchain.html
> > Enjoy! > > TomW > > > >Grateful to all > > > >-- > >Felipe Fontoura - Brazil > >Linux user: #281076 > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > -- > Tom Walsh - WN3L - Embedded Systems Consultant > http://openhardware.net, http://cyberiansoftware.com > "Windows? No thanks, I have work to do..." > ---------------------------------------------------- >
2006-01-25 by Marko Pavlin (home)
Jan Szymanski wrote: > Tom, > > As you love you Linux do you know of any software CAD tools for > schematic and pcb development. Cadsoft eagle??? http://www.cadsoft.de/index.htm
2006-01-26 by Tom Walsh
Jan Szymanski wrote: >Tom, > > As you love you Linux do you know of any software CAD tools for >schematic and pcb development. Luck of such tools of a quality >comparable to medium level tools like Protel is keeping me away from >Linux > > > Yes I do, I do my circuit boards using Eagle: http://www.cadsoft.de. It is a commercial package, modules cost around USD$400 each (schematic, layout, autorouter). It does metric and english units. It also runs natively on either Windows or Linux without Wine or other emulators. TomW -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
2006-01-26 by Boris Kralik
http://pcb.sourceforge.net/ --- In lpc2000@yahoogroups.com, "Jan Szymanski" <janek@b...> wrote:
> > Tom, > > As you love you Linux do you know of any software CAD tools for > schematic and pcb development. Luck of such tools of a quality > comparable to medium level tools like Protel is keeping me away from > Linux > > Happy typing > > Jan
Boris Kralik wrote: >http://pcb.sourceforge.net/ >--- In lpc2000@yahoogroups.com, "Jan Szymanski" <janek@b...> wrote: > > Maybe that now works, but when I first encountered the package there were features that were missing that I needed. So, I went with the commercial solution. Price wasn't as much a concern but the feature set was important. This was 5 years ago. Regards, TomW -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
2006-01-26 by xultz
De:lpc2000@yahoogroups.com Para:lpc2000@yahoogroups.com Cópia: Data:Wed, 25 Jan 2006 23:17:13 +0100 Assunto:Re: [lpc2000] Any tools for Linux > Jan Szymanski wrote: > > > Tom, > > > > As you love you Linux do you know of any software CAD tools for > > schematic and pcb development. > > Cadsoft eagle??? > http://www.cadsoft.de/index.htm > Hi there I use since 2001 gEDA to capture schematics and PCB to draw printed circuits. I love that tools, to my work they are great. They dont have the features the more expensive tools have, like a good autorouter and back anotating, but I can do my professional work withou troubles. Take a look at geda.seul.org and at pcb.sf.net Hope I helped Best regards Xtian Xultz Curitiba - Brazil [Non-text portions of this message have been removed]
