These are the defines for the FastIO registers on LPC2101,2102,2103
2006-01-29 by apex_olsene
#define FIODIR (*((volatile unsigned long *) 0x3FFFC000)) #define FIO0DIR0 (*((volatile unsigned char *) 0x3FFFC000)) #define FIO0DIR1 (*((volatile unsigned char *) 0x3FFFC001)) #define FIO0DIR2 (*((volatile unsigned char *) 0x3FFFC002)) #define FIO0DIR3 (*((volatile unsigned char *) 0x3FFFC003)) #define FIO0DIRL (*((volatile unsigned short *) 0x3FFFC000)) #define FIO0DIRU (*((volatile unsigned short *) 0x3FFFC002)) #define FIOMASK (*((volatile unsigned long *) 0x3FFFC010)) #define FIO0MASK0 (*((volatile unsigned char *) 0x3FFFC010)) #define FIO0MASK1 (*((volatile unsigned char *) 0x3FFFC011)) #define FIO0MASK2 (*((volatile unsigned char *) 0x3FFFC012)) #define FIO0MASK3 (*((volatile unsigned char *) 0x3FFFC013)) #define FIO0MASKL (*((volatile unsigned short *) 0x3FFFC001)) #define FIO0MASKU (*((volatile unsigned short *) 0x3FFFC012)) #define FIOPIN (*((volatile unsigned long *) 0x3FFFC014)) #define FIO0PIN0 (*((volatile unsigned char *) 0x3FFFC014)) #define FIO0PIN1 (*((volatile unsigned char *) 0x3FFFC015)) #define FIO0PIN2 (*((volatile unsigned char *) 0x3FFFC015)) #define FIO0PIN3 (*((volatile unsigned char *) 0x3FFFC017)) #define FIO0PINL (*((volatile unsigned short *) 0x3FFFC014)) #define FIO0PINU (*((volatile unsigned short *) 0x3FFFC016)) #define FIOSET (*((volatile unsigned long *) 0x3FFFC018)) #define FIO0SET0 (*((volatile unsigned char *) 0x3FFFC018)) #define FIO0SET1 (*((volatile unsigned char *) 0x3FFFC019)) #define FIO0SET2 (*((volatile unsigned char *) 0x3FFFC01A)) #define FIO0SET3 (*((volatile unsigned char *) 0x3FFFC01B)) #define FIO0SETL (*((volatile unsigned short *) 0x3FFFC018)) #define FIO0SETU (*((volatile unsigned short *) 0x3FFFC01A)) #define FIOCLR (*((volatile unsigned long *) 0x3FFF C01C)) #define FIO0CLR0 (*((volatile unsigned char *) 0x3FFF C01C)) #define FIO0CLR1 (*((volatile unsigned char *) 0x3FFF C01D)) #define FIO0CLR2 (*((volatile unsigned char *) 0x3FFF C01E)) #define FIO0CLR3 (*((volatile unsigned char *) 0x3FFF C01F)) #define FIO0CLRL (*((volatile unsigned short *) 0x3FFF C01C)) #define FIO0CLRU (*((volatile unsigned short *) 0x3FFF C01E))
