Lpc2000
wiggler problem
wiggler problem
2006-01-29 by G B
Hello,
I switched from the laptop to a desktop and got Eclipse and OCD to
recognize the port.
It is wierd bc I have to install the BSL jumper for that to happen, just
the opposite of what the tutorial says.
When I switch to the Debug Perspective, all happens as in the tutorial
except that the code line above Initialize is not highlighted, and when
I right click, there is no option for Run to Line.
I am assuming that The debugger is not really enabled.  Of course, after
getting OCD to run, I removed the BSL jumper.
It does take my command in the Console (gdb)reset, and responds with
(gdb)
Anyone else seen similar things?  Most things look correct, but the
debugger is not really running?
Glen
