Lpc2000
Rise and fall time of capture inputs
2006-02-03 by widescreen03608
Hi all,
On the CAP0.3 input I have pulses from an encoder and I want detect
both edges and generate interrupts. The signal is filtered so the rise
and fall time are slow (don't know exactly how long, but surely within
1ms). Is it possible that no interrupt is generated on CAP0.3, because
the signal is to slow?
I didn't found any datasheets from Philips which this is described.
Thanks for help
Re: [lpc2000] Rise and fall time of capture inputs
2006-02-03 by Tom Walsh
widescreen03608 wrote:
>Hi all,
Aside from the datasheet thing, wouldn't it be possible to use a schmidt
gate to drive the capture intput?  Or some op-amp crossing-detector with
hysteresis?
TomW
>Thanks for help
>Yahoo! Groups Links
Re: Rise and fall time of capture inputs
2006-02-03 by charlesgrenz
The real question is why the rise time is so long. A typical HEDS
encoder sensor is in the 50 to 100ns rise and fall times.
regards,
Charles
> >Hi all,
schmidt
with
> hysteresis?
> Regards,
> TomW
> >Thanks for help
> >Yahoo! Groups Links
2006-02-03 by G B
I would think a high speed comparator, where you could set
the precise rise and fall voltage values would be best.
Glen
> Hi all,
> Thanks for help
2006-02-03 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Friday, February 03, 2006 3:19 PM
Subject: Re: [lpc2000] Rise and fall time of capture inputs
>>Hi all,
> hysteresis?
I've done that in the past with that sort of input. I then had a problem
with multiple signals (like contact bounce) which I eliminated with
software.
Leon
Leon Heller, G1HSM
leon.heller@...
http://www.geocities.com/leon_heller
Leon Heller wrote:
>----- Original Message -----
>From: "Tom Walsh" <tom@...>
>>>Hi all,
>>hysteresis?
>software.
Yes, that is a given when dealing with mechanical contacts.  They do
bounce.  As far as that goes, analog lines can "bounce", inductance.
TomW
Sent: Friday, February 03, 2006 6:25 PM
>>>hysteresis?
>>software.
It was an LED/transistor unit, not mechanical.
Leon
