LPC3180 data sheet available
2006-02-07 by elektrknight
Hi, A bit more LPC3180 details in the data sheet at Philips website: http://www.standardics.philips.com/products/lpc3000/pdf/lpc3180.pdf thanks, elektrknight http://groups.yahoo.com/group/lpc3000
2006-02-08 by Peter Jakacki
Arrhhh, if only it had a bootloader that could load from SD memory cards into internal RAM and then a secondary bootloader could then perform the high-level boot into external RAM. Having to implement parallel Flash means more chips/cost/space etc when the code would be quite happy to run out of RAM. Do you think that Philips will do this or does anyone know of an ARM that does? Maybe I'm jumping the gun because looking at the block diagram I see that the SD and SPI are running off the same slave bus as the NAND Flash controller. Could it be that the bootloader allows a variety of devices to be used??? Plus, the BGA is always a pain for protos but it is the way many chips are going if you want the features. On the upside the power consumption looks modest for a 208MHz optioned-up ARM9. Thoughts? *Peter* elektrknight wrote:
> > A bit more LPC3180 details in the data sheet at Philips website: > http://www.standardics.philips.com/products/lpc3000/pdf/lpc3180.pdf
2006-02-08 by unity0724
Umm... - LPC3180 loads nand flash to internal SRAM - May be they will load from USB/SPI,I2C in future. 16KBROM inside. Have not seen a chip that boot from SD. but the AT91sam9261 does boot from serial eeprom and run on 160KB internal SRAM. Here's a copy of what the datasheet says: <<< Bootloader supporting a wide range of non-volatile memories Downloads and runs an application from external storage medias into internal SRAM: - SPI DataFlash connected on NPCS0 - Two-wire EEPROM - 8-bit parallel memories on NCS0 >>> There is development kit from atmel but do not know if chip is available. Old data sheet in QFP208 but chip now ended up as BGA317. The LPC3180 spec is weird...Hee... I think may be marketing guys forgot to look at what the other competitors' (Intel, Samsung, Cirrus Logic, Atmel) chips features before coming out one.. :) Sorry... ARM9 is some "rotten" market. I'm curious and can someone tell me what type of market this LPC3180 is targeting at?? (What?? No LCD, No ethernet?? no...) Anyway, most of my application requires flash memory read protection, and so I will be sticking to LPC21xx. Regards --- In lpc2000@yahoogroups.com, Peter Jakacki <peterjak@...> wrote: > > Arrhhh, if only it had a bootloader that could load from SD memory cards > into internal RAM and then a secondary bootloader could then perform the > high-level boot into external RAM. Having to implement parallel Flash > means more chips/cost/space etc when the code would be quite happy to > run out of RAM. Do you think that Philips will do this or does anyone > know of an ARM that does? > > Maybe I'm jumping the gun because looking at the block diagram I see > that the SD and SPI are running off the same slave bus as the NAND Flash > controller. Could it be that the bootloader allows a variety of devices > to be used??? > > Plus, the BGA is always a pain for protos but it is the way many chips > are going if you want the features. On the upside the power consumption > looks modest for a 208MHz optioned-up ARM9. > > Thoughts? > *Peter* > > > > elektrknight wrote: > > > > A bit more LPC3180 details in the data sheet at Philips website: > > http://www.standardics.philips.com/products/lpc3000/pdf/lpc3180.pdf >
2006-02-08 by Tom Walsh
Peter Jakacki wrote: >Arrhhh, if only it had a bootloader that could load from SD memory cards >into internal RAM and then a secondary bootloader could then perform the >high-level boot into external RAM. Having to implement parallel Flash >means more chips/cost/space etc when the code would be quite happy to >run out of RAM. Do you think that Philips will do this or does anyone >know of an ARM that does? > > > Yes, look at the Cirrus EP930x (EP9301, EP9302, ...). That family boots from an SD Flash memory, it pulls in a small amount of code from the SD memory (if it exists), from that little code, you can init SDRAM and pull in larger code from the SD Flash, eventually you will have your bootloader (with file system support) loaded. This is one downside of the LPC2000 series, it relies very heavily on BIG Flash and small SRAM, I'd like to see an LPC2000 chip with 512K of SRAM and 32K of Flash! Couple that processor with an SD Memory Card and you've got one heck of an ARM system in a tiny footprint! TomW >Maybe I'm jumping the gun because looking at the block diagram I see >that the SD and SPI are running off the same slave bus as the NAND Flash >controller. Could it be that the bootloader allows a variety of devices >to be used??? > >Plus, the BGA is always a pain for protos but it is the way many chips >are going if you want the features. On the upside the power consumption >looks modest for a 208MHz optioned-up ARM9. > >Thoughts? >*Peter* > > > >elektrknight wrote: > > >> A bit more LPC3180 details in the data sheet at Philips website: >>http://www.standardics.philips.com/products/lpc3000/pdf/lpc3180.pdf >> >> > > > >Yahoo! Groups Links > > > > > > > > -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
> Yes, look at the Cirrus EP930x (EP9301, EP9302, ...). That family > boots from an SD Flash memory, it pulls in a small amount of code > from the SD memory (if it exists), from that little code, you can > init SDRAM and pull in larger code from the SD Flash, eventually > you will have your bootloader (with file system support) loaded. > > This is one downside of the LPC2000 series, it relies very heavily > on BIG Flash and small SRAM, I'd like to see an LPC2000 chip with > 512K of SRAM and 32K of Flash! Couple that processor with an SD > Memory Card and you've got one heck of an ARM system in a tiny > footprint! > > TomW > Hi, Thanks to the Cirrus logic Chip info. Do they have a version with large internal SRAM (Like Sharp/Philips/Atmel) which make it even better? For your 512KB SRAM requirement... May be attach a 512KB SRAM to LPC2292 might be cheaper than chip comes with it... :) Regards
