Lpc2000
LPC2138 SPI Problem
LPC2138 SPI Problem
2006-02-09 by johnleerberg
Hi All
      I have been working with the LPC2138 for about 12 months on and
off and have had NO problems with getting any of the peripherals
working until now.
I have two LPC2138's connected via SPI0 and am intending to setup one
as a master and the other a slave that adds two serial ports to my
master.
There are two issues:
1) With MOSI to MOSI, P1.24 (master) to SSEL0 (slave), SCLK0 to SCLK0
and MISO floating i am seeing a mirror of what is being transmitted
by the master on the MISO pin of the slave????? And i mean a perfect
mirror with no time shift, with the 4 channel CRO i am using i can
overlay one waveform ontop of the other and they match perfectly. Yes
i have put a multimeter across the pins to check for conductivity and
no there is no solder across the MOSI and MISO.
2) I can get the SPI interrupt the fire on both the master and the
slave but randomly the master will just lock up (something i have
never had happen before). Also the upon power reset the SPI wont
start but the serial port start perfectly everytime.
My program has three basic sections
a) In main i call an init interrupt routine which initialises the SPI
port on the master.
b) In my ISR i read the S0SPSR (clear it), write 0xA0 to S0SPCR,
clear the interrupt by writing 0x01 to S0SPINT, clear the VicVectAddr.
c) In main i write 0x5A to S0SPDR then wait 4ms and repeat (while(1)
loop)
If anyone can help me it would be greatly appreciated.
Emacs ASM mode
2006-02-09 by George M. Gallant, Jr.
I am looking for an emacs mode script that understands gnu arm
assembler.
The default asm-mode.elc does not highlight the comment "@" or process
lines that start with a label that does not start with an letter.
George
Re: [lpc2000] LPC2138 SPI Problem
2006-02-10 by Bill Knight
Make sure the SSEL0 pin on the MASTER is configured for SPI usage and
is pulled-up.
-Bill Knight
R O SOftWare &
http://www.theARMPatch.com
On Thu, 09 Feb 2006 23:22:36 +0000, johnleerberg wrote:
>Hi All
>working until now.
>master.
>port on the master.
>loop)
>Yahoo! Groups Links
RTC Losing ~5 seconds per day
2006-02-10 by Sean
Hi All,
I've got an LPC2148 set up and the RTC is losing about 5 seconds per day, I
am assuming that my 32.768kHz crystal isn't exact.
Are there any good ways to correct this?  I know this isn't major, but
that's 2 minutes a month, a little outside of what I'd like to see.
-- Sean
Re: RTC Losing ~5 seconds per day
2006-02-10 by Guillermo Prandi
That's about 60 ppm (or worse). Have you checked your crystal's specs?
You might want to try another crystal. Citizen's CM200S32.768KDZFT
($.88 at Digikey) is 20 ppm.
Guille
--- In lpc2000@yahoogroups.com, Sean <embeddedrelated@...> wrote:
> Hi All,
per day, I
but
> Thanks,
> -- Sean
RE: [lpc2000] RTC Losing ~5 seconds per day
2006-02-10 by Dan Beadle
Usually, this is because the tank capacitors are too big.  Look at the spec
sheet for the crystal and see what they recommend.  Or try a different spec
crystal.
The average should be close to dead on once you get the loading right.  But,
you will see some variation from unit to unit, depending upon the accuracy
of components.
  _____
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf Of
Sean
Sent: Thursday, February 09, 2006 4:28 PM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] RTC Losing ~5 seconds per day
Hi All,
-- Sean
SPONSORED LINKS
Microcontrollers
<http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2
=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.s
ig=mfaAujKZXA2Z_vxre9sGnQ>
Microprocessor
<http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=M
icroprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig
=9jjd2D3GOLIESVQssLmLsA>
Intel
<http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrolle
rs&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=
95&.sig=OMnZuqMZX95mgutt4B-tDw>  microprocessors
Pic
<http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontroller
s&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=9
5&.sig=Malspbd0T4Rq3M4Q0nHrfw>  microcontrollers
  _____
YAHOO! GROUPS LINKS
*	 Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> "
on the web.
*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	 Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/>  Terms of Service.
  _____
Re: [lpc2000] RTC Losing ~5 seconds per day
2006-02-10 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Friday, February 10, 2006 12:28 AM
> Hi All,
> I
I've just bought some 32 kHz xtals. They seem to come in two types, 6 pF and
12 pF load capacitance, that could be the cause of your problem. Also, when
used in watches they have a trimmer to set the frequency exactly.
Leon
2006-02-13 by jk jlkj
Hi John,
  Your mail has releived me. I thought i was the only one to face problems with the SPI of phillips. I was facing a similar problem like yours. I have been able to solve the problem partly.
  i.e.
  1. The miror image problem. can be solved by using the opposite modes in the master and slave side i.e if master is MSB the slave should be LSB.
  I am still facing a similar problem like yours, which i have not been able to solve as yet.
  I am unable to get the SPI working on power up reset, i.e all the other peripherals work perfect other than SPI. I have used SPI interrupts, & I have to short the reset pin momentarily to ground and reset the controller to make the SPI start working. I hope some one can help me with this problem.
  SPI is really nagging me. Its been over a month now, and i have not been able to get the SPI work on power UP.
  Jerome
johnleerberg <johnleerberg@...> wrote:
  Hi All
working until now.
master.
port on the master.
loop)
  SPONSORED LINKS
        Microcontrollers   Microprocessor   Intel microprocessors     Pic microcontrollers
  YAHOO! GROUPS LINKS
 Jiyo cricket on Yahoo! India cricket
Yahoo! Messenger Mobile Stay in touch with your buddies all the time.
2006-02-13 by sig5534@hotmail.com
I had problems with the SPI port months ago as well.  I gave up and wrote my own bit banging code to do the same thing.  SPI is very easy to implement manually.  All I recall right now is that it did not seem to handle 8, 16,  and/or 24 bit data correctly.  Different word sizes seemed to be a problem.  I was very unhappy with the SPI port overall and finally dumped it, switched the pins to I/O, and handled it myself.  That worked right from the start so I never went back to the built-in SPI mode.
Chris.
---- Original Message -----
  Sent: Sunday, February 12, 2006 8:44 PM
  Subject: Re: [lpc2000] LPC2138 SPI Problem
  Hi John,
    i.e.
    Jerome
    Hi All
  working until now.
  master.
  port on the master.
  loop)
    SPONSORED LINKS
    YAHOO! GROUPS LINKS
  SPONSORED LINKS Microcontrollers  Microprocessor  Intel microprocessors
  YAHOO! GROUPS LINKS
    a..  Visit your group "lpc2000" on the web.
    b..  To unsubscribe from this group, send an email to:
    c..  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Re: LPC2138 SPI Problem
2006-02-13 by Guillermo Prandi
I've been using SPI0 in master mode to control a MAX3100 serial port
with no problems at all. Never used it in slave mode, though.
Guille
--- In lpc2000@yahoogroups.com, jk jlkj <njad2002@...> wrote:
> Hi John,
>   i.e.
should be LSB.
>   Regards,
>   Jerome
>   Hi All
and
> working until now.
one
> master.
SCLK0
perfect
Yes
and
SPI
> port on the master.
VicVectAddr.
(1)
> loop)
>   SPONSORED LINKS
>   YAHOO! GROUPS LINKS
Service.
time.
