NC Pin's
2006-02-10 by philipphk
Hi @ all I have an problem because I cant find description what I have to do with NC (unused) Pin's at the LPC214x because I'm just using USB one UART and perhaps 1 or 2 GPIO Pins? Regards Philipp
2006-02-10 by unity0724
Umm... May be setting them all as output and force to low?? That's what I will do... - Believed to be less power consuming. Leave it as input will be hi-Z and easily picking up noise signals. - Lo-Z output will have lower chances of chip get zapped by static charge... It's too troublesome to pull all pin to high or low by resistors! :) Regards --- In lpc2000@yahoogroups.com, "philipphk" <philipp1024@...> wrote: > > Hi @ all > I have an problem because I cant find description what I have to do > with NC (unused) Pin's at the LPC214x because I'm just using USB one
> UART and perhaps 1 or 2 GPIO Pins? > > Regards > Philipp >
2006-02-10 by rtstofer
--- In lpc2000@yahoogroups.com, "philipphk" <philipp1024@...> wrote: > > Hi @ all > I have an problem because I cant find description what I have to do > with NC (unused) Pin's at the LPC214x because I'm just using USB one > UART and perhaps 1 or 2 GPIO Pins? > > Regards > Philipp > I thought I read in the datasheet to define unused pins as outputs to minimize power consumption. Richard
2006-02-10 by Xtian Xultz
Em Sex 10 Fev 2006 13:22, philipphk escreveu: > Hi @ all > I have an problem because I cant find description what I have to do > with NC (unused) Pin's at the LPC214x because I'm just using USB one > UART and perhaps 1 or 2 GPIO Pins? > > Regards > Philipp > Set them as GPIO, as output, and in firmware put em at low level. And on the board, dont connect them.
2006-02-10 by Guillermo Prandi
I think I read somewhere that most unused pins should be set to output *HIGH* rather than low, because some of them have internal pull-ups and therefore a low would draw some current. That doesn't apply of course to open-collector outputs. Guille --- In lpc2000@yahoogroups.com, Xtian Xultz <xultz@...> wrote: > > Em Sex 10 Fev 2006 13:22, philipphk escreveu: > > Hi @ all > > I have an problem because I cant find description what I have to do > > with NC (unused) Pin's at the LPC214x because I'm just using USB one > > UART and perhaps 1 or 2 GPIO Pins? > > > > Regards > > Philipp > > > Set them as GPIO, as output, and in firmware put em at low level. And on the > board, dont connect them. >
2006-02-11 by Tom Walsh
Guillermo Prandi wrote: >I think I read somewhere that most unused pins should be set to output >*HIGH* rather than low, because some of them have internal pull-ups and >therefore a low would draw some current. That doesn't apply of course >to open-collector outputs. > > > Good point, thanks. I guess a little study would need to be in order to see what pins are pulled which way. TomW >Guille > >--- In lpc2000@yahoogroups.com, Xtian Xultz <xultz@...> wrote: > > >>Em Sex 10 Fev 2006 13:22, philipphk escreveu: >> >> >>>Hi @ all >>>I have an problem because I cant find description what I have to do >>>with NC (unused) Pin's at the LPC214x because I'm just using USB one >>>UART and perhaps 1 or 2 GPIO Pins? >>> >>>Regards >>>Philipp >>> >>> >>> >>Set them as GPIO, as output, and in firmware put em at low level. And >> >> >on the > > >>board, dont connect them. >> >> >> > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
2006-02-11 by Xtian Xultz
Please, correct me if I am wrong, but LPC210X have pull ups??? I founded nothing talking about that, I understood that there are no pull ups in these chips. Em Sáb 11 Fev 2006 07:34, Tom Walsh escreveu:
> Guillermo Prandi wrote: > >I think I read somewhere that most unused pins should be set to output > >*HIGH* rather than low, because some of them have internal pull-ups and > >therefore a low would draw some current. That doesn't apply of course > >to open-collector outputs. > > Good point, thanks. I guess a little study would need to be in order to > see what pins are pulled which way. > > TomW > > >Guille > > > >--- In lpc2000@yahoogroups.com, Xtian Xultz <xultz@...> wrote: > >>Em Sex 10 Fev 2006 13:22, philipphk escreveu: > >>>Hi @ all > >>>I have an problem because I cant find description what I have to do > >>>with NC (unused) Pin's at the LPC214x because I'm just using USB one > >>>UART and perhaps 1 or 2 GPIO Pins? > >>> > >>>Regards > >>>Philipp > >> > >>Set them as GPIO, as output, and in firmware put em at low level. And > > > >on the > > > >>board, dont connect them. > > > >Yahoo! Groups Links
2006-02-11 by Karl Olsen
---- Original Message ----
From: "Xtian Xultz" <xultz@...> To: <lpc2000@yahoogroups.com> Sent: Saturday, February 11, 2006 3:28 PM Subject: Re: [lpc2000] Re: NC Pin's > Please, correct me if I am wrong, but LPC210X have pull ups??? I > founded nothing talking about that, I understood that there are no > pull ups in these chips. All LPC2xxx chips have pull-ups on some pins. See the datasheet, search for "pull". Karl Olsen
