Lpc2000
Trouble with LPC2148 P0.2 and P0.3 pins
2006-02-11 by blasteriokas
Hello everyone.
I am having problems with P0.2 and P0.3 pins.
The trouble is that I can't define them as outputs. I have wrote a
small program:
#include <LPC214x.H>
void main(void)
   PINSEL0 = 0;
   IODIR0 = 0xFFFC;
   IOPIN0 = 0x00FC;
   PCON = 1;         // IDLE mode
When program is executed, on pins P0.4..15 is logical '1', but on
these P0.2 and P0.3 - nothing. I connected a pull-up resistor to Vcc -
pins does not refuse it, so, I think, these two pins works like
inputs. But WHY?
I use KEIL µVision software.
P.S. sorry for my english ;)
Re: [lpc2000] Trouble with LPC2148 P0.2 and P0.3 pins
2006-02-11 by Karl Olsen
---- Original Message ----
To: <lpc2000@yahoogroups.com>
Sent: Saturday, February 11, 2006 11:32 AM
Subject: [lpc2000] Trouble with LPC2148 P0.2 and P0.3 pins
> small program:
> void main(void)
>    PINSEL0 = 0;
>    IODIR0 = 0xFFFC;
>    IOPIN0 = 0x00FC;
> inputs. But WHY?
Read the pin descriptions in the datasheet or manual, including the
footnotes.  They are open drain.
Karl Olsen
Re: Trouble with LPC2148 P0.2 and P0.3 pins
2006-02-11 by martinbrendes
Karl,
I think the reason is that P0.2 and P0.3 are I2C pins and have an
open drain characteristic. Working as outputs they are able to
output a strong 0, but a weak 1 only. Let the pullup connected to
VCC and set the pins to 0 or 1. You should get the correct logic
levels then.
Martin
www.arm-emulator.com
> From: "blasteriokas" <blasteriokas@...>
a
> > small program:
> > void main(void)
> >    PINSEL0 = 0;
> >    IODIR0 = 0xFFFC;
> >    IOPIN0 = 0x00FC;
Vcc -
> > inputs. But WHY?
> Karl Olsen
> > small program:
> > void main(void)
> >    PINSEL0 = 0;
> >    IODIR0 = 0xFFFC;
> >    IOPIN0 = 0x00FC;
> > inputs. But WHY?
> Karl Olsen
Thank you very mutch, atlast my binary clock (RTC test) is working
properly :)
Sarunas
