Lpc2000
first time programming
2006-02-13 by caspervegt
Hi, i've got a LPC2138 wich i use to test the ARM7 for use in other
devices.
I've got WinARM to compile some examples, and the LPC2000 Flash Utility
(V2.2.1 and V2.2.3) to load it into the flash. As said on the user
guide,
http://www.keil.com/support/man/docs/mcb2130/
the jumpers are set correctly, the device ID is read correctly on COM1,
19200 baud, and the Flash Utility says: File Upload Succesfully
Completed.
Though the board still comes up with the standard software,
saying "TRIIING This is the Keil 2138 evaluation board" etc...
and everything i do, i can't change this standard software.
Does someone know what im doing wrong, or can I maybe have a Blink-LED
program that definitely works?
many thanks for all the help,
Casper
Re: first time programming
2006-02-13 by scrappystuff64
Make sure the Xtal frequency is set the the correct frequency for
your board.
other
> devices.
Utility
> guide,
COM1,
> Completed.
LED
> Casper
