New updated LPC2148 USB examples from Keil's website, Working !
2006-02-14 by Carsten Grøn
Hello all, I had some mixed results previously with the USB samples from Keil. There was a note here about new examples following the 2.42 version of the Keil tools. These samples are also now available for download from their website as seperate samples (no need to download the 2.42). I just downloaded them, and briefly tested the USBMem sample on a Embedded Artist LPC2148 board, and they works now !!! The problem with the old example was the whenever I would try to write anything to the board, it would hang forever (was also mentioned here I think at some point). So far, I'm able to also write files to the board. (I'm still running on the v 2.20 of the Keil tools) I will check the USBHID and USBAudio samples later..... Regards, Carsten Groen
