Lpc2000
Serial Programming Keil MCB 2140 boards
2006-02-14 by dodge1955
Has anyone had flaky problems getting connection to either the 2130 or
2140 eval boards?  I have 2 2140 boards and 1 2130 board and all three
have the same issue.  After entering ISP mode (Hold INT1 and press
RESET), when pressing READ ID, sometimes it connects fine.  Other
times, when pressing READ ID, it jumps out of ISP mode and starts the
code again, like a hard RESET.  Sometimes entering the ISP mode again,
and pressing READ ID works fine.  Other times, I have to press READ ID
first, then quickly enter ISP mode and it connects.  It seems one or
the other process works all the time, but I don't know which one.  If
it doesn't work you get 'Cannot communicate with test board'.  This
happens on multiple computers.  Any ideas?  Not a major problem.  But,
it would be nice to know exactly which ISP sequence will connect in
all instances.
