Lpc2000
Which LPC2000 board to get?
2006-02-16 by w6ezy
Hello all, this is my first post to the group.  I'm a firmware test engineer for one of the
major hard drive vendors.  We use an ARM966E core in some of our drives.  I wish to move
over to the firmware development group in about a year, and am presently taking an ARM
course to get my feet wet with the instruction set.
Unfortunately, the class only uses a software emulator.  I want to get some real hardware
to play with (a board with lots of interfaces and devices, plenty of memory to run an RTOS
on, and a JTAG debugger).
I prefer to code using my Mac, and I have a keyspan USB->serial cable that I can use with
my AVR STK500 MCU.  Hopefully I can use it (or buy something else) to program an ARM
eval board from my iBook.
I've started collecting the GNUARM components, as I will need to use a free compiler/
debugger.
My goals are to master the ARM instruction sets (ARM/Thumb), get proficient at writing
device drivers for the board's devices, and get experience writing code that runs on an
RTOS.
It seems the LPC2000 series is widely supported by groups such as this on the net, so it's
probably a good platform to start with.  The question is, what do you guys recommend as
far as picking a specific board, JTAG debugger, and development tools?
Ideally, I'd like to keep total expenses under $500 for the board, JTAG debugger, and any
software I might have to purchase.
Although I want to develop using my Mac, I do have a Win XP box in the closet as a back
up.
Your suggestions and advice is much appreciated!
In summary, my requirements for the board:
- ARM7 is sufficient, I see no need to go ARM9 at this point
- Enough memory to run an RTOS, with a little left over for my programs
- A good selection of devices (LEDs, switches, LCD or VGA interface, USB, serial, Ethernet
would be awesome)
- JTAG debugger recommendations
- Tool recommendations
Thanks!
-Jeff
Re: [lpc2000] Which LPC2000 board to get?
2006-02-16 by Tom Walsh
>debugger.
Someone took my scripts and built the GNU toolchain on an 0SX Apple:
http://www.openhardware.net/?title=ARM%20Thumb%20tools%20for%20LPC2000&dir=ArmTools&file=ThumbToolchain.html
>RTOS.
Ow, well, I would suspect that you are going to be quite limited in your
choices given your O/S preference.  For me, I'm a consultant, I put
together the GNU toolchain + Insight debugger for the only cost of my
time.  Where I spent my money was on a good JTAG debug unit: Abatron
BDI2000.
This unit is an investment, I've done too much ARM code as a hobby
without it and know how badly I needed it.   I paid USD$2700 for the
thing and it has proven to be a very reliable and robust tool.
For the low-bucks entry level, you have Cygwin, Eclipse (IDE) and an
Olimex Wiggler.  Wigglers are finicky things and can be a source of
infinite frustration to get reliable operation out of them.  Try a debug
session where you are wading through a lot of code / data only to have
the wiggler decided to take a vacation for a few minutes.  :(
I would suggest that avoid a wiggler, save your money by building your
own toolchain, then invest in a good ethernet based JTAG unit.  Stay
away from USB JTAG, these things need special drivers and the
manufacturers are convinced that Windows runs the world.
The reality is that if you want it cheap, it will have to run on Windows.
TomW
>up.
>would be awesome)
>Thanks!
>-Jeff
>Yahoo! Groups Links
2006-02-16 by Stephen Pelc
> From: Tom Walsh <tom@...>
Not quite. Our JTAG widget
  http://www.mpeforth.com/jtagwidget.htm
is a USB device. All it requires is an FTDI virtual COM port
driver. These drivers are freely available for a range of
operating systems. Yes, Ethernet and TCP/IP would be nice.
Another point I would make is that what you need to use JTAG at
hardware bring-up time is NOT the same as what you need for
debugging your code.
Stephen
Stephen Pelc, stephen@...
MicroProcessor Engineering Ltd - More Real, Less Time
133 Hill Lane, Southampton SO15 5AF, England
tel: +44 (0)23 8063 1441, fax: +44 (0)23 8033 9691
web: http://www.mpeforth.com - free VFX Forth downloads
Thank you for that url, I will keep that in mind the next time someone
asks for a recommendation of a jtag unit.  At USD$404 it is fairly priced.
TomW
I did notice that no mention of gdb is in your manual.  One shouldn't
assume that Remote/TCP (or other) connection for gdb to use, is the GNU
gdb supported (as Insight)?
TomW
2006-02-17 by Stephen Pelc
> Tom Walsh <tom@...>
> >driver.
Not yet, but it is on our to-do list.
When someone produces a C debugger that concentrates on bottom
up testing rather than top-down testing ("crash and burn" in our
terminology) we'll be *very* interested in supporting it.
We come from an application domain that includes bomb-disposal
equipment and anaesthetic ventilators.
Stephen
Re: Which LPC2000 board to get?
2006-02-18 by Eric Engler
I do some work on debuggers in my spare time, but I don't understand
what you mean here? Please elaborate, and give me an idea of what
you'd like to see in a debugger, or how would you like to use a
debugger that is different from "normal" breakpoints, single-stepping,
etc?
Eric Engler
