Lpc2000
Embedded Artist Education Board + Embest IDE and UNetICE?
2006-02-18 by w6ezy
I really like the doodads that come on the EA education board, and the price is great.  I am
thinking about getting this instead of the Olimex/Keil/IAR LPC2148 boards unless
someone here can pursuade me why one of the other boards is better (I'm all ears!).
I'm also contemplating spending the extra money to get the Embest IDE and UNetICE JTag
debugger combo to round out my development environment.  I'll hold out hope that one
day a free toolchain will be available on OS X that can talk to the UNetICE, but until then, I
can work with XP.
I can justify the cost of the Embest IDE+UnetICE (about $1400).  I would have an
unrestricted development platform with this (I think?).  I have looked at what IAR and Keil
offers, and I cannot afford their unrestricted IDE options, only the code-size restricted
compilers.
Given that my primary goal right now is to be experienced programming and debugging
device drivers for FreeRTOS and uCOS/II (running on ARM), what advice can you guys give
me as far as the pros/cons of purchasing the Embest product versus spending less and
going with the more restricted setups from IAR and Keil?
I want to buy software/hardware with room for me to grow into, but I'm limited to about
$1500 right now.
Thanks!
-Jeff
Re: Embedded Artist Education Board + Embest IDE and UNetICE?
2006-02-18 by rtstofer
> $1500 right now.
> Thanks!
> -Jeff
I don't know anything about the merits of various boards but I am
happy with my Olimex LPC2106 board from Sparkfun.  I also have the
LPC2106 header board and I'm looking at the LPC2148 development
board.
I really think you should spend time with James Lynch's tutorial
before you commit to spending a ton of money on development tools.
I'm certainly not a 'professional' developer but I find the Eclipse
IDE and the GNU toolchain more than adequate.  Now, others will feel
the IDE is unnecessary and I'm ok with that.  If they want to work
from the command line then the toolchain works that way as well.  I
just like the way it keeps my projects organized.  It is easy to
copy and paste modules between projects.  Furthermore, the setup is
exactly the same on my Linux machine and my XP machine.  My next
project is to put dual monitors on my Linux machine.  That will
happen next week.
I would put the money into a JTAG debugger only and I'm not sure I
would do that.  JTAG is great but ISP will get the code transferred
with no complications or cost.  Debugging can certainly be done
without JTAG.  I use printf quite a bit.  But, if you have the money
to spend, this is the place to put it.  Get something that works.
The tutorial is here: http://www.olimex.com/dev/pdf/ARM%20Cross%
20Development%20with%20Eclipse%20version%203.pdf
There are other points of view...
Richard
Re: [lpc2000] Re: Embedded Artist Education Board + Embest IDE and UNetICE?
2006-02-18 by Tom Walsh
I would agree with that.  Maybe there are some pretty frills with
purchasing a packaged development system, along with someone to hold
your hand for you when you run into difficulties, but aside from that, I
would spend the money on a decent JTAG unit.  If you've allocated $1500
for tools it sounds as if you are not doing this as a hobby but have
some serious project in mind.  For $1500 you probably could purchase
something like the ARM Multi-Ice or other ethernet based JTAG unit.  I'm
not sure what a LauterBach unit would go for...
You may want to consider the EPI Majic-LT as it is in your price range:
http://www.epitools.com/products/probes.php
Another interesing unit appears to be the * GUARDIAN-SE*  Plus GDB:
http://www.etoolsmiths.com/GDB-JTAG-Debug-Tools.html
I'm sure that a little time on google and you can find more potential
solutions.
Unfortunately, the Abatron BDI2000 costs more than that and their
BDI1000 model doesn't support gdb.  Otherwise I would recommend the
BDI2000 @ USD$2700.  I use gcc-4.0.2, bintools-2.16.1, and Insight-6.4
for my development toolchain.  I'm well satisfied with the GNU tools +
BDI2000 running under Linux.
However, if you are not that serious about the project, and are willing
to put up with some occasional frustration with the wiggler, you should
be able to follow Lynch's Eclipse Tutorial and get a cygwin development
together for less than $30.
TomW
>Richard
>Yahoo! Groups Links
