Lpc2000
lpc2000 flash utiltiy source code
2006-02-18 by Mukadder CEYHAN
Is there any document or source code to explain the
procedure of activating the bootloader and loading the
code algorithm in lpc2000 devices???
regards
mukadder
Do You Yahoo!?
http://mail.yahoo.com
Re: [lpc2000] lpc2000 flash utiltiy source code
2006-02-18 by Rajnikant ghodasara
No ideas but u can use www.hites.co.uk for detail
> the
> regards
> mukadder
> Do You Yahoo!?
> protection around
Do You Yahoo!?
2006-02-18 by Robert Adsett
The documentation is in the user manual.  There are several programs with
source around that implement it.
         lpc21isp http://guest.engelschall.com/~martin/lpc21xx/isp/index.html
         lpc2k_pgm http://www.pjrc.com/arm/lpc2k_pgm/
Both can automatically control the reset and ISP  mode pins and supporting
that can be as simple as adding the standard ISP header
http://www.open-research.org.uk/ARMuC/Standard_ISP_Header.html and using a
simple adapter like
http://www.aeolusdevelopment.com/Articles/InSystemProgramming.html
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
