Lpc2000
Rowley software and LPC2144 doesn't work
2006-02-20 by Gus
Hello,
I am testing a new design that have LPC2144 on it. I can load
programs into RAM and run them but when trying to load in FLASH
rowley tools fail. I tried a different board with LPC2148 and it
worked fine.
I can even load a program in RAM and this program writes to FLASH
and my program works fine so IAP works fine.
Has anyone used rowley tools with LPC2144?
Is it possible that I have something wrong?
Gus Issa
RE: [lpc2000] Rowley software and LPC2144 doesn't work
2006-02-20 by Paul Curtis
Gus,
We haven't seen an LPC2144--have you checked the part ID of the 2144?
According to the loader sources it should be 402ff12.  Can you also
check your loader sources to ensure that the 2144 is supported in the
version you have?
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and now MAXQ processors
> From: Gus [mailto:gus_is_working@...]
> Sent: 20 February 2006 18:12
> To: lpc2000@yahoogroups.com
> Subject: [lpc2000] Rowley software and LPC2144 doesn't work
> Hello,
> worked fine.
> Thanks,
> Gus Issa
Re: Rowley software and LPC2144 doesn't work
2006-02-20 by Gus
This is the first chip where we had to set the JTAG divider and
the "loader parameter"!!! We have never set these values before and
everything worked great on LPC2103, LPC2114, LPC2134, LPC2138!
It is still not rock solid as the other chips but I will look more
into it.
Thanks for the great product
Gus
--- In lpc2000@yahoogroups.com, "Paul Curtis" <plc@...> wrote:
> Gus,
2144?
> version you have?
> > Hello,
> > worked fine.
FLASH
> > Thanks,
> > Gus Issa
> > Yahoo! Groups Links
RE: [lpc2000] Re: Rowley software and LPC2144 doesn't work
2006-02-21 by Paul Curtis
Gus,
The loader parameter is required to define the crystal frequency (in
MHz, IIRC) so that the ISP flashing works.
If you are using a CrossConnect you should not need to set the JTAG
divider because the LPC series uses adaptive clocking (the RTCK signal),
hence you should set the Adaptive Clocking property of the target
interface to "Yes".  In this case the CrossConnect interface will go as
fast as the chip allows, assuming you have a CrossConnect.  If you have
a Wiggler, RTCK isn't supported and you do need the JTAG divider.
> Sent: 20 February 2006 23:44
> Subject: [lpc2000] Re: Rowley software and LPC2144 doesn't work
> into it.
> Gus
> > Gus,
> 2144?
> the
> > version you have?
> > > Hello,
> > > worked fine.
> FLASH
> > > Thanks,
> > > Gus Issa
> > > Yahoo! Groups Links
