Lpc2000
Question on VICVectAddr
2006-02-24 by Gopalakrishnan
Hello
What is the purpose or use of this register
Vector Address Register.
When an IRQ interrupt occurs, the IRQ service VICVectAddr routine can
read this register and jump to the value read.
Is it used for OS priority scheduling purpose or for some other reasons
Re: Question on VICVectAddr
2006-02-24 by brendanmurphy37
Check out the ARM document:
http://www.arm.com/pdfs/DDI0181E_vic_pl190_r1p2_trm.pdf
(This link may be found in the Links section of this forum).
Very comprehensive document, that's easy enough to read.
--- In lpc2000@yahoogroups.com, "Gopalakrishnan" <naray23@...> wrote:
> Hello
can
reasons
Re: [lpc2000] Question on VICVectAddr
2006-02-25 by Saravanakumar S
Hello gopal,
               In VIC, we can configure the interrupts according to the
priority.
Maximum we can configure 16 interrupts.It will vary from 0 to 16.
For ecah interrupt,they already defined some predined address.
If you write the code like this means,
        VICVectAddr1 = (unsigned)EXTINTVectoredIRQ;
This ISR function will be call from the Predefined address.
It means we configure certain tasks,if the interrupt is rised.
Hello
Yahoo! Groups Links
