I try to write the FIQ interrupt program for LPC2138-MT.
Input EINT1 is used for generate the
interrupt with button and pull-up resistor at P0.3.
Output P0.31 is connected to Led. The simplest FIQ Handler is
written for switching off Led, when
the interrupt comes from EINT1 ( P0.3) , Hex-file and led.elf
created by CrossWorks v 1.5, all necessary startup and system files
are connected. The Compiler and Linker does not give any errors in
report.
That can be wrong here? Thanks.
/* Target board OLIMEX LPC2138-MT */
#include <targets/LPC21xx.h>
void EXTintFIQ (void) __attribute__ ((interrupt("FIQ"))); //
Declare FIQ ISR
IO0SET = 0x80000000; // Set 1 to LED pin P0.31
EXTINT = 0x00000002; // Clear the peripheral interrupt flag
int main (void)
IO0DIR = 0x80000000; // Set the LED pin P0.31 as output
PINSEL0 |= 0x000000C0; // Set P0.3 as EINT1
VICIntSelect = 0x00008000;
VICIntEnable = 0x00008000; //Enable a Vic Channel as FIQ
IO0CLR = 0x80000000; // Led On
__ARMLIB_enableFIQ();
while(1); //Loop here forever
Section _vectors in output file led.elf contain :
ldr pc, [pc, #fiq_handler_address - . - 8] /* fiq handler */
E59FF014 ldr pc, [pc, #20]
<fiq_handler_address>:
234 andeq r0, r0, r4, lsr r2
Section _start contain :
orr r1, r0, #0x11 /* FIQ mode */
E3801011 orr r1, r0, #0x00000011
msr cpsr_cxsf, r1
E12FF001 msr cpsr_cxsf, r1
ldr sp, =__stack_fiq_end__
E59FD150 ldr sp, [pc, #336]
At the beginning of EXTintFIQ in output file led.elf
located next operators :
E52DC004 str r12, [sp, #-4] !
E1A0C00D mov r12, sp
E92DD80C stmfd sp!, {r2-r3, r11-r12, lr-pc}
E24CB004 sub r11, r12, #0x00000004
User code
And at the end of EXTintFIQ :
E89D680C ldmfd sp, {r2-r3, r11, sp-lr}
E8BD1000 ldmfd sp!, {r12}
E25EF004 subs pc, lr, #0x00000004
